Question about RCA Televison & Video
RCA MOD# 20-f-514-TD Chassis#ATC-116 SER#1054e6j09 c231 Will not power-on. There is a led red light blinks and makes a audio noise every time the light blinks
    Top Expert:
  • RCA Master
  • 75,581 Answers
Hello
Either your RCA tvs LOT [Line Output Transformer] or its drive transistor [horizontal output transistor is faulty. First replace the Horizontal Output Transistor. It can be located very near to the LOT said above, be screwed onto a metal heat sink to radiate heat away from it while it works. It is a three terminal device, black in colour. Unscrew and desolder it out of the printed circuit board and check whether it has caloctor to emitter or collector to base leak . If it found leaky there is a possiblity of LOT damage. Anyway replace the said transitor first. After replacing, switch on the set for a short period of time, say 3 or 4 seconds only, unplug it from the power socket, and feel the heat effect of the replaced transistor. It may get warm, but not too hot. If it heats up abnormally, surely the LOT said about is faulty, and should be replaced with same type and number.
When selecting LOT, insist on orginal replacement, as substitutions will detereate the picture quality and its life time. If you wants further assistance, feel free to get me through Fixya. OK.
Posted on Dec 30, 2010
Hitachi 50"comes for about 10 seconds then cuts off.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 03, 2016 | Hitachi 50V500 50 in. HD-Ready LCD...
Picture tube will not come on.... rca mod f35731 mb chassis ctc169j56 ser 707261399h green light comes on but no picture.... help fuse?> bad picture tube...?
Bad grounds on the power supply are common on these TVs. The power supply will have the flyback transformer. Resolder the flyback, horizontal driver transformer, power resistors etc. Check and study the vertical IC and see if the pins will need resoldering as well. Inspect the small board that is connected to the CRT, and solder this, as necessary. This is a good start for repair, thanks for asking and show all hands of support!
Jul 28, 2011 | RCA Televison & Video
42 inch lcd with blinking red light
I just fixed mine, I am not exactly sure what did it, but I held the power button down while pushing and holding each button for a few seconds after going through each button I unplugged power cable and then plugged it back in and it powered it up and it worked
May 21, 2010 | RCA L42WD22 42 in. LCD Television
I have an RCA D52W20 with chassis ATC 221 that no longer works. When plugged in, the green power light blinks twice and then goes out. When the power button is pushed the light blinks twice, then about 4...
The tv is going into protection shutdown. It will try to power up three times, but each time it tries, the microprocessor recognizes an overvoltage, or overcurrent draw, and after three attempts it will place the unit into protection shutdown. There can be many causes of this, but the most likely one is that there is a short circuit in the high voltage circuits. You probably have a shorted flyback and associated components.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD50LPW42 problem
Your chassis is the ATC311 the capacitor issue is with the ATC336 chassis. How many times does the led blink?
Jun 26, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
Rca dlp tv
I would need the model number as the ATC chassis DLPs have different code structures. Buzzing could be the ballast, lamp DM3 or the light engine, but if you post the model number I will be able to help you out with the problem
May 21, 2008 | Televison & Video
RCA HD50LPW175 50 in. HDTV Television
Yes I should be able to help you figure it out. First look on the rear of the set to check what the chassis number is. Should be an ATC 336 but it might be a ATC323 let me know the chassis number and we can go from there on diagnosing the problem
Feb 15, 2008 | Televison & Video
Televison & Video Logo
170 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
