PC100 BIOMETRIC FINGERPRINTING CLOCK - Office Equipment & Supplies
Bizhub c224
In order to enable this function, you will need AU-101 / AU-102 Biometric Finger Vein Authentication Device. These biometric finger vein readers connect directly to the MFP and work in conjunction with the machine's internal authentication capabilities, or integrate with Konica Minolta's PageScope Enterprise Suite.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 19, 2014 | Konica Minolta Bizhub C224 Color Copier /...
I forgot password of ls-838 lonestar biometric
The password is present to prevent the usage of it by a thief after it has been stolen.
May 25, 2014 | BestPriceCables Lonestar Biometric Time...
Where i cant get biometric software for win7, because i have biometric software for win xp, thanks & regards
better solution you can run the software in compatibility mode and it will work fine with win 7.right click on the instillation icon click properties on the window you will see a compatibility menu click on it and select the winxp you were using b4 then run the installation
May 21, 2014 | APC Biometric Mouse Password Manager...
I have a Adel Trinity 788 biometric fingerprint handle that I need to install. I lost the screws and I am trying to find the 3 long bolts that connect the 2 halves together. Does anyone know where to...
Trinity Keyless Biometric lock:
I can't answer your question directly, but I can steer you to their website, which includes a support phone number that you can call, as well as links to Customer support and Frequently Asked Questions:
http://www.axxisbiometrics.com/products/locks/latch-style/trinity788/
I'm sure they can answer your questions. Good luck!
Apr 10, 2011 | Trinity Keyless Biometric Fingerprint Door...
Unable to obtain authentication input/output error has occurred. Error while loading applet Module is not registered.
Check to see if more than 1 biometric scanner is enabled @ device manager>Disabled all leaving only 1 supported finger print scanner enabled.
This error is most common if you have on-board or integrated biometric Reader...Try this 1st;still got answers if this doesn't work but it's been proved as remedy for this particular error :) Thanks
The Rule is:Help others without charge :)
Jan 10, 2011 | DigitalPersona UareU 4500 Fingerprint...
T22 Doesn't boot on Memory upgrade
First make sure the memory is the same PC 100 , then make sure the chips are fully seated. and try rebooting computer. If you mismatch the Dimms the memory wont be recognized by the computer.
Sep 02, 2009 | IBM ThinkPad T22 2647 Notebook
Umax AstraPix PC100 Webcam diver problem
catalin_yo_vlad@yahoo.com
email me ..with the need specified ..and I will send the driver for you ...
Apr 07, 2009 | Umax AstraPix PC100 Webcam
SentrySafe DA3930 Biometric Fingerprint Safe Item Number 681814 will not recognize my finger print!!!! I have been trying to get into it on and off for 3 months. Is there a reset code???
contact sentry
biometric scanners DO NOT WORK
prove your ownership
and they may assist you
and
Sep 14, 2008 | Sentry Fireproof Safe
k24674
jasbo
jasbo
