When i close the lid to started washing the washer machine did not start i have to hit the lid hard for the washer to started washing
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Dec 30, 2010
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
Tip
The washing machine will not spin?
There are many possibilities for this problem, but the most common and regular problem seen is as follows:--
There is a lid switch in the washer. The washing machine will not start spinning till the lid is closed. In some cases it has been seen that lid is closed still the washer does not spin. in this cases the lid switch has to be checked. if the lid switch is faulty then the closed lid will not be detected by the washing machine, and it will not start spin cycle.
This will help. Thanks.
on Mar 18, 2010 | Washing Machines
'LD' on display and lid closing won't get the washer started
Hi just read your posting.Now I know you supplied the model number in your posting but could you please supply the name of the machine which should be written on the control panel.Is it an ENDURO or an ESPRIT --etc--?Please reply with additional information and I can help you rectify this problem.Looking forward to your reply.
Jul 27, 2010 | Fisher Paykel Eco IWL16
I can't get washer to start. I believe the top
Washing machines have a safety switch on the lid. If the lid isn't shut, if won't run. You may have upset the safety switch. Depending on the machine, it should either have a micro switch that is tripped by the lid or the lid will have a tab that hits a switch as the lid closes... be sure to listen for a positive click ... you may try bending the hinge a bit to make proper contact too.
May 26, 2010 | Washing Machines
Loses power in spin cycle
First lid must be down before washer start spinning. Remove any obstructions in drain hose and or straighten drain hose to remove kinks. Lid or other object hit timer knob and turned the washer off - Make sure the Timer knob is pulled out.
If the lid was opened with too much force when adding clothes, it may have hit the timer knob, pushing the knob in.
If a laundry basket or other object hit the Timer knob, the Timer knob may have been pushed in shutting the washer off.
Washer lid is not locked (Not on All Washers) - The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
If the washer has not drained, it will not go into spin.
Use a flashlight to inspect the holes in tub for foreign objects like screws, nails, bra wires, etc. and remove if present.
Apr 03, 2010 | Kenmore HE2 Plus Front Load Washer
Washer won't start unless you hit the lid with
Somewhere the connections is loose OR the lid is not closing properly
Nov 16, 2009 | Kenmore 23812 Top Load Washer
Kenmore elite will not start
the lid or door must close to start the washer.. check the lock and the striker on the door... hope it helps..
Sep 18, 2009 | Kenmore Elite 45986 Front Load Washer
Washer will not start without hitting lid.I have a Super Capacity Plus Top Loading Washing Machine, Model #LSQ954PW2 and it will not start the agitation without me hitting on the lid.It seems like whatever...
If you look at the lid while opened,you will see a small pin that when closed,goes into a small opening on the washer and contacts with the lid switch.
Jul 29, 2009 | Washing Machines
Washer will fill but won't start cycle
you need to take the 2 lid switch wires from the lid switch and wire them together this will bypass the lip switch,should fix it,let me know-mike
Oct 20, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
