Question about Panasonic CW-1406BU Air Conditioner
When we turn on the unit with the remote after about 3 minutes it switches off and the timer light flashers then nothing happens
  • 2,133 Answers
Remove battery from remote for resetting timer. Now you can operate with remote. And also reset your unit power isolating power and re plug it. Thanks.
Posted on Dec 31, 2010
Mitsubishi air conditioner flashing timer light flashes twice
Switch the polarity of the control voltage...make sure it matches with the indoor & outdoor unit
Dec 18, 2013 | Mitsubishi Heating & Cooling
Turn on the car then click the signal light and nothing!!! no tic to light nothing could it be the signal light switch or a fuse?? please help!!
Try the flasher unit first, checking it costs nothing. Turn on your emergency flashers and if they work, get your owners manual and find the fuse panel locations. Inside the manual or the panel cover there will be a legend as to what is what. You will have two flasher units, one for turn signals and the other emergency flashers. They are the same units so just switch them, if your turn signals now work, but your flashers don't, then you have a bad flasher unit. Go buy another at any auto parts store and put it in the correct socket, you rarely use the emergency flashers so you want your new one in the turn signal circuit.
If that does not do it then you may have a broken switch which requires pulling the steering wheel off to fix. That is not an owner service thing. One bad light bulb is not going to knock them all out.
Jan 05, 2011 | Mercury Cougar Cars & Trucks
My Split system Centrex CTAR60GW turns off about 10 minutes of cooling, the actual unit flashes on the timer button, have cleaned it replaced batteries and had 4 technicians out to have a look all of which...
Dear friend. the timer problem is very common. Remove battery from remote and also remove power to unit. Again plug power on unit and start with remote and try to cancel the timer on and off. Press set.
And also cool setting must be minimum 3 degree less than room temperature. Helpful advise?
Dec 31, 2010 | Danby DPAC12031 Air Conditioner
The operation and timer lights on my Fujitsu split system are flashing on and off several times when the unit is switched off I noticed this after the system had stopped blowing air & I knew the room...
I have same problem like yours to my newly installed Fujitsu multi-split system (the first time use since system installed 1 week ago). I rang the electrician who did the installation; he said it must be the units themselves nothing to do with electricity.
Okay, then I rang Fujitsu and their local service agent. They suggested me to switch off C/B for an hour to reset the units. I followed the instruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired to the outdoor unit). So I used a multi-meter to test the power terminals of indoor units (Danger! If you have no idea about this, don't even try! ): it seemed no power supply even C/B is on. I turned to the isolator which next to the outdoor unit. The isolator was making arcing noise when I switched it on and off. The indoor units suddenly turned on for few minutes then died again.
So I figured out the problem is that crooked isolator. I called the unhappy electrician to replace the isolator. End story....
I hope my experience will help you a little bit.
Jul 11, 2010 | Fujitsu 24C1 Air Conditioner
Left turn signal works / don't work, brake light
possibly flasher unit faulty
or turn signal switch
Feb 22, 2010 | 2000 Jeep Grand Cherokee
Ignition key turns on but car will not start
I suspect the ignition switch is malfunctioning.
Nov 19, 2008 | 2000 Ford Focus
96 chevy lumina sedan
for both issues, could possibly be the flasher unit for the blinkers.....which could be separate from the hazard flasher unit...(happened on my 92 chevy lumina) or the actual turn signal switch which is located in the steering column....not the stick you push, but the part inside that the lever controls (also happened on my lumina............3 times)
TIP:
start by checking the flasher....its cheap maybe 3-4$ for a new unit.....if thats not it and you figure out its the switch, go to a junkyard.....its wayyyy cheaper
Aug 04, 2008 | 1992 Chevrolet Lumina
MDB7100AWB STOPS AFTER 3 SECONDS OF RUNNING
1. The Maytag sevice centers, if close, are "great". You describe the problem and they supply the part. If far still give them a call.
2. The problem is probably the control. It's a simple fix. Just replace the part. And you can order the part from the service center. Takes 10 minutes.
Tango
Feb 09, 2008 | Maytag MDB7100AWB Dishwasher
Panasonic CW-1406BU Air Conditioner Logo
489 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
