Question about Health & Beauty
On Walgreens Model HD503 I'm getting Err 0 on my left arm and Err 3 on my right arm.
3 Suggested Answers
evista_win
  • 10 Answers
SOURCE: err 3 is displayed
Wrist blood pressure monitors must be used with the arm above heart level. You can do the pledge of allegiance while doing a reading to make sure this is done. Usually this error occurs when inflation takes too long or the placement of cuff is wrong.
Posted on Sep 10, 2009
  • 4736 Answers
SOURCE: Can't find the instruction book
You can obtain one by calling the manufacturer's (HoMedics) Customer Service Dept 800-466-3342. Mon - Fri, 8:30am - 5pm ET.
Posted on Apr 14, 2011
Why does my Walgreens digital blood pressure monitor keep giving an ERR4 message?
Here are the top 3 reasons for getting errors: 1. You're using the wrong-sized cuff. If you are extra large, you need a larger cuff. 2. You've incorrectly positioned your body. Ideally, your arm should be at the level of your heart. 3. You've placed the cuff incorrectly. Make sure the cuff is on your upper arm and the stethescope is placed over the place you feel the strongest pulse. I hope that helps!
Mar 30, 2017 | Walgreens Health & Beauty
My Walgreens HD 303 will only give Err code 3. It will not give pressure. What remedy do I have
Doesn't the book give codes? Is the battery fresh? Is the cuff tight on your arm? Is the tube clear of obstruction like you arm resting on it?
Jan 31, 2015 | Walgreens Health & Beauty
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
Walgreens HD303 Blood Pressure Monitor error 3
measurement.
Error Codes
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
Err 3 is displayed
Sep 10, 2009 | Walgreens Wrist Blood Pressure Monitor
Err: no sign chng
When you get the sign change error it is either that you have mixed up the left bound and the right bound or that you are marking the left and the right bound both above the x-axis or both below the x-axis. That's why you get the sign change error. Your range values must have different signs.
Aug 19, 2009 | Texas Instruments TI-84 Plus Silver...
How can the rear suspension be adjusted?
REAR WHEEL ALIGNMENT
TOE-IN : 0±2 mm (0±0.08 in.)
note_icon.gif 1. The rear suspension lower arm mounting cam bolt should be turned an equal amount on both sides during adjustment. Right wheel : Clockwise direction : toe-in Left wheel : Clockwise direction : ton-out Maximum difference between LH and RH : 3mm 2. The cam bolt should be adjusted within a 90° range left or right from the center position. CAMBER Standard value : 0°±30´ Maximum difference between LH and RH : 3mm : 0±2 mm (0±0.08 in.) note_icon.gif 1. The rear suspension upper arm mounting cam bolt should be turned an equal amount on both sides during adjustment. 2. Install the left and right springs which have the same identification color. 3. The cam bolt should be adjusted within a 90° range left and right from the center position.e55b100.gif TIRE WEAR 1. Measure the tread depth of the tires. Tread depth of tire [Limit] : 1.6 mm (0.06 in.) 2. If the remaining tread depth is less than the limit, replace the tire. note_icon.gif When the tread depth of the tire is reduced to 1.6 mm (0.06 in.) or less, the wear indicators will appear.
Jun 16, 2008 | 2004 Hyundai Santa Fe
Health & Beauty Logo
87 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
