Question about Vtech Lands Phones
MY CALL CANNOT BE COMPLETED AS DIALED FROM THE RESTRICTED ACCESS PHONE YOU ARE USING USING V TECH PHONE.
My phone will NOT let me call out when i dial a number it says its restricted. how do i fix this problem???
Here's a phone system lesson. Panasonic discontinued your TD phone system about 8 years ago, so you either got a super deal or the system has been installed that long ago. Restrictions are programmed into the system by an installer and manager. There's a Class of Service override access by dialing 47 on the intercom and a code. Since the 7436 is a special phone, it's probably the one attached to extension 101. If that phone is restricted, clearly whoever owns the system doesn't want whatever you're dialing to be dialed.
Now you wouldn't be asking "someone on the internet" for instructions on how to beat the restrictions would you?
I didn't think so. Check with the system owner or installer.
Carl
May 18, 2011 | Panasonic KX T7436 Corded Phone KX-T7436
Htc sense keeps pulling up theerror code 67. registration failure
call 1-888-211-4727 to have them reactivite phone OR dail ##3282# access code from the Sprint Tech FOR phone reboot Once everything IS Completed phone will work. LET ME KNOW if you have any more issues.
THANK YOU
Jan 09, 2011 | HTC Hero Smartphone
I got error message on 2 Avaya 5610SW IP phone: one is showing: incompatible Disc and another shows:Call Barred Disc. I have no clue to issue. is there anyone can help me out?
Incompatible means that what you dialed is not recognized by the system.
Call barred means your phons is restricted from dialing whatever you are trying to dial (900 numbers etc)
Aug 11, 2010 | Avaya 5610 IP Phone
Says call cannot be completed as dialed when trying to make any call
This can be fixed by servicing your cordless phone.by servicing ,the problem will be stopped.
Aug 11, 2010 | Uniden DECT 6.0 Cordless Telephone...
Using home phone causes comcast wireless internet to disconnect
Wireless internet runs at 2.4ghz. Your portable phone is probably also 2.4ghz and is knocking out your internet connection when in use. Look for an 800mhz or 5.8ghz phone as a replacement.
Oct 09, 2009 | Panasonic KX-TG2357 Cordless Phone
INCOMMING CALLS
Check with your carrier to make sure your service has not been disconnected/suspended. This could be the problem or your device may need to be reprogrammed which also your carrier can assist you with. Thanks.
Mar 26, 2009 | Samsung SCH-u340 Cellular Phone
Unable to make and recieve calls
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
Jul 21, 2008 | Motorola Mobility L6 Cellular Phone
Faxing Long Distance
To my knowledge, if the unit can send a fax message to another fax machine then it is safe to assume that there is nothing wrong with the fax.
Perhaps your problem may be more related to the type of phone subscription that you may have. Some phone providers have subscription for local calls only and restricted long distance. Alternately, there are some phones that would need a series of numbers to be pre-dialed before long distance access is granted.
Pls check with your local phone company. Additionally, you can try by calling long distance using your regular phone and see if it works. If it does, then long distance restrictions has been imposed/enabled in your Canon 3300. The procedures are better explained in the users manual. A copy of the user's manual for Mac users is here, all other downloads including those for Windows, is here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Problem when dialing phone
Yes, I have had nothing but trouble with my V-Tech ia5823.
Slow to dial, dropping out going calls and now the base light is flashing at a rapid pace and will not charge the handset.
I want to return it to Wal-Mart but have misplaced the recepit.
I will never buy another V-Tech..Uniden is the way to go!
Jun 02, 2007 | Vtech ia5823 Cordless Phone
Lands Phones Logo
118 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
