Question about Panasonic KX-T7633 Corded Phone
I want telephone number to be display when there is a call from outside
  • Panasonic Master
  • 2,460 Answers
Well, you need about 3 things for that to happen. Hardware, programming, and a ringing phone. If others in your system have CID or you see CID when you're talking on the phone line, then it's probably just ringing. If nobody gets CID, then did you buy the CID card (part number ending in 93)? Once you get the card, you still have to tell the system that you're using CID.
Carl
Posted on Dec 30, 2010
Change the display name?
Administering a 1400 Series Digital Deskphone
Perform the following steps for each 1400 Series Digital Deskphone:
1. Log into the Avaya Aura Communication Manager administration interface.
2. Perform one of the following steps:
? If you are adding a new extension and want to assign a specific extension number, use
the add station nnnn command, where nnnn is the new extension you want to assign.
? If you are adding a new extension and want to assign the next available extension
number, use the add station next command.
? If you are installing the 1400 Series Digital Deskphone at an existing extension, use the
change station nnnn command, where nnnn is the existing extension you want to
modify.
The Station screen appears.
3. Perform one of the following steps:
? If you are administering a 1408 telephone, type 2410 in the Type field.
? If you are administering a 1416 telephone, type 2420 in the Type field.
4. In the Port field, type the port address.
5. In the Name field, type the name to associate with this telephone. Administering 1400 Series Digital Deskphones
20 Avaya 1400 Series Digital Deskphones Installation and Maintenance Guide
6. Configure the remaining fields on the Station screen pages. Keep in mind the following
information:
? If you are administering a 1408 telephone, the first eight call appearance/feature buttons
displayed on the Station screen are administered on the 1408 telephone. (Since the 1408
telephone is aliased as a 2410 telephone, the Station screen displays 10 call
appearance/feature buttons.) The remaining buttons displayed on the Station screen are
not administered.
? If you are administering a 1416 telephone, the first 16 call appearance/feature buttons
displayed on the Station screen are administered on the 1416 telephone. (Since the 1416
telephone is aliased as a 2420 telephone, the Station screen displays 20 call
not administered.
? If you are administering a 1416 telephone with a DBM32 Button module, the first 16 call
appearance/feature buttons displayed on the Station screen are administered on the
1416 telephone. The remaining eight call appearance/feature buttons displayed on the
Station screen are administered on the first eight buttons of the DBM32 Button module.
The 24 buttons of the EU24 expansion module displayed on the Station screen are
administered for the remaining 24 buttons of the DBM32 Button module.
For more information about administration and features, see:
- Administering Avaya Aura™ Communication Manager, Document Number 03-300509
- Avaya Aura™ Communication Manager Feature Description and Implementation,
Document Number 555-245-205
- Avaya Aura™ Communication Manager Screen Reference, Document Number
03-602878
7. When finished administering this extension, save your changes.
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Dec 19, 2014 | Avaya Ip Office 1416 Digital Deskphone -...
How do i dial long distance with a corporation code?
Solutions for : How To Send a Fax Solution : Insert a Pause When Dialing a Fax Number With some telephone systems, an access code must be dialed and a second dial tone will then be heard. For example, a "9" might need to be used to get an outside line.
In such cases, a pause in the telephone number needs to be inserted.
Pauses can be inserted when setting up speed dial numbers.
To insert a pause, press [Pause / Redial] button at the appropriate place when entering the telephone number. A dash "-" appears on the display at the corresponding location.
May 21, 2014 | Xerox WorkCentre 3315
I am using 'Ativa D5765 cordless phone
You must have caller ID provided by your local phone company for Call ID to work. This is an additional charge on your phone bill.
Feb 21, 2012 | Lands Phones
Do I have to dial 9-1 before the area code when faxing?
Hello, If you are in an office or corporate environment where the phone system is on a PBX you need to dial 9 usually to get outside the office. If you just have the unit setup at home or to an analog phone jack (not going thru a PBX) then just dial 1 + area code + number. If the number is local then don't use a 1, just the phone number and area code.
Chris
May 11, 2011 | Ricoh Aficio CL3500N Laser Printer
How do you display caller name and not just telephone number
Caller ID (caller identification, CID), also called calling line identification (CLID) or calling number identification (CNID), is a telephone service, available in analog and digital phone systems and most Voice over Internet Protocol (VoIP) applications, that transmits a caller's number to the called party's telephone equipment during the ringing signal, or when the call is being set up but before the call is answered. Where available, caller ID can also provide a name associated with the calling telephone number. The information made available to the called party may be displayed on a telephone's display or on a separately attached device.
Apr 24, 2011 | Innovage Touch-panel Phone 1502084
Talkswitch caller ID from outside calls not working
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
May 06, 2009 | TalkSwitch CT.TS001.124001.US...
How to find unknown incaming calling location
I can think of 2 possible causes:
1) The call originated from an International location and you are seeing a partial originating telephone number.
2) The originating caller has a type of telephone service that allows their telephone system to generate the digits that appear on Caller ID displays. Their telephone is creating that strange looking telephone number.
My guess is that the first cause is the correct one.
You can try googling the numbers on the display to see if anyone else has had this happen to them. Your telephone service provider could run a trace on the call, but that would require going through a legal process that, if this is a one time event, would really not be worth the hassle.
Dec 24, 2008 | Uniden Cordless Phone
Speed Dialing KX-T7453
Part of the number you store in your speed dial has to include a "9" or 8x access code to get an outside line.
Carl
Sep 18, 2008 | Panasonic KX-T7453 Corded Phone
Cannot receive faxes
Step one: Check the fax number
Make sure the fax number is correct; include any numbers that you have to dial to use the telephone, such as an area code, access codes for outside lines or long-distance services, and so on. If you have to dial a particular sequence of numbers to make a telephone call from that telephone line, you also have to dial that sequence of numbers to send a fax.
If the issue is resolved, you do not need to continue troubleshooting.
If the number is correct, continue to the next step.
Step two: Dial the number manually
Instead of using a speed dial setting or sending the fax from the computer, dial the number manually from the product control panel.
If the fax sends when you dial the number from the control panel, follow these steps to recreate the speed dial setting and insert pauses in the number.
On the product control panel, press the Setup button.
Press the Left Arrow button ( ) or Right Arrow button ( ) until Speed Dial Setup appears on the control panel display, and then press the OK button.
Press the Left Arrow button ( ) or Right Arrow button ( ) until Individual Speed Dial appears on the control panel display, and then press the OK button.
Press the Left Arrow button ( ) or Right Arrow button ( ) to select an unassigned speed dial entry, and then press the OK button.
Use the product keypad to enter any numbers that must be inserted before the fax number, such as an area code or access codes for outside lines or long-distance services, and then press the Redial/Pause button to insert a pause.
Enter the rest of the fax number, using the Redial/Pause button to insert pauses between the numbers, and then press the OK button.
Enter the name of the speed dial setting, and then press the OK button to save the speed dial setting.
Try to send the fax again.
If the issue is resolved , you do not need to continue troubleshooting.
If the issue is not resolved , continue to the next step.
Step three: Run a fax diagnostic test
Press the On button ( ) to turn on the product, and then make sure the product is correctly connected to the telephone jack.
Make sure that there is plain white paper in the input tray.
On the product control panel, press 6 , and then press 6 again.
This selects the Tools menu and then selects Run Fax Test .
The fax diagnostic test page prints.
Review the results of the test.
If the result of the fax diagnostic test is All Pass , skip to Step four: Reinitialize the fax.
If the result of the fax diagnostic test is a failure, a page prints that describes the issue and offers possible solutions. Follow the solutions on the printout.
If the solutions on the printout resolve the issue, you do not need to continue troubleshooting.
If the solutions on the printout do not resolve the issue, continue to the next step.
While the product is on, disconnect the power cord from the back of the product and from the electrical outlet.
Make sure that the telephone cord is fully inserted into the port labeled 1-Line on the back of the product.
Connect the power cord to the back of the product, and then connect the power cord to the electrical outlet.
When the product is in the ready state, try to send and receive a fax again.
Step five: Test the send/receive functions
Use the product keypad to send a fax. Watch the product control panel display and listen to the sounds the product makes.
If the product is working correctly, the following events occur.
When the product begins to dial, a dial tone is audible, followed by the sound of the product dialing. A Dialing message appears on the control panel display.
When the receiving fax answers the call, the product and the fax exchange tones. A Connecting message appears on the control panel display. During this phase, the product and the fax compare capabilities, exchange information about how to send the fax, and try to establish a reliable transmission speed.
After the connection is established, the product sends the pages of the document. Messages appear on the control panel display that indicate the status, such as Sending page 1 .
Review the results of the fax.
If the fax is transmitted successfully, continue to the next step.
If there is no audible dial tone or the receiving fax does not answer the call, try sending the fax to a different destination. If this second attempt also fails, continue to the next step.
If the receiving fax answers the call and begins beeping, but the Connecting message does not appear on the product control panel display, the product is not detecting the tones from the receiving fax. Continue to the next step.
Step six: Use an analog telephone service
HP Fax and All-in-One products are designed to work with analog telephone services and might experience some difficulties when they are connected to phone lines with digital services. Make sure the product is connected to an analog telephone service.
To obtain digital services information or support, contact the telephone service provider or system administrator.
Step seven: Check the phone cord and fax connections
Disconnect the telephone cord, and then examine the connector on the end of the cord. Make sure the cord only has two wires.
Figure 1: Telephone cord with two wires
Figure 2: Telephone cord with four wires
If the cord has four wires, replace it with a two-wire telephone cord.
If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
Make sure the fax is connected directly to the telephone jack by a telephone cord. Connect the cord to the 1-Line port on the back of the product.
Figure 3: Fax only
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
If other devices need to use the same telephone jack, make sure they are connected to the 2-Ext port on the back of the product.
Connect a single-line telephone to 2-Ext , and then pick up the receiver and listen for a dial tone. Make sure you are able to dial out using the telephone keypad. If you hear a dial tone and are able to dial out using the phone, the product is properly connected to a working telephone cord and telephone jack.
Figure 4: Fax and telephone
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
5 - Telephone
Figure 5: Fax and PC or modem
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
5 - PC or modem
If you change any cable connections, try sending and receiving a fax again to make sure that the issue is resolved.
Step eight: Remove any other devices from the telephone line
If any other devices, such as a telephone, an answering machine, or a modem, are connected to the telephone line, remove each device.
NOTE: Remove each device even if it is in another room, connected to another telephone jack, or connected using a line splitter.
Connect the product to an analog telephone line by connecting one end of the two-wire telephone cord directly to the telephone jack and then connecting the other end of the telephone cable directly to the 1-Line port on the back of the product.
Try to send a fax again.
Step nine: Perform a partial reset of the product
A partial reset of the product returns all fax settings to the default values. It might be necessary to reset the language and country/region settings after the partial reset is complete.
Disconnect the power cord from the back of the product.
Wait 20 seconds, and then press and hold # and 3 on the product control panel.
Connect the power cord to the back of the product, and then release the buttons when the product turns on.
The product is reset to factory defaults.
Try to send and receive faxes again. If the problem still exists, continue to the next step.
Step ten: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Aug 05, 2008 | HP Office Equipment & Supplies
Cleer ID display on NEC Ranger DK824 telephone system
I have a DK824 I bought in 2000 which did not have called ID capability - that was explained to me on purchase - if yours is 2 years old they must have kept the models the same for a long time though
Jun 25, 2008 | Lands Phones
Panasonic KX-T7633 Corded Phone Logo
87 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
