I have been refilling a HP 97 [C9363W] printer cartridge. After the third time, the printer [HP photosmart 8750] gives an error message, "Cartridge failed, replace it". I replaced the cartridge with rebuilt/refilled cartridge and get the same error message. Is ther anyway to reset the printer or the cartridge?
  • 1234212 Dec 30, 2010
    I have already viewed the video. I do not believe the 8750 has a battery.
    Perhaps there is a better solution than>>>>It cannot be done!
  • 17,130 Answers
Sometimes it is possible that the contacts on the cartridges get out of alignment , get dirty or damaged. if so there will not be any return signal to indicate the status of the cartridges. Also old and used ones may also tend to show bad results.
So ti will be good to remove and clean the cartridges, the contacts . Now after the printer is removed from the PC, un-install and reinstall printer driver on the PC so as to remove all the old errors.
Now connect the printer to the PC to be detected and installed.
The printer should reset now and show the ink levels to allow you to take a test print. If not you might have to try with an original new cartridge.
Posted on Dec 30, 2010
  • 6,826 Answers
OK, first of all, the HP.com website recommends that users do not use refilled cartridges when encountering the errors described, in order to provide trouble free operation of the printer.
I admit that it can be expensive to buy new cartridges that haven't been refilled, but the refilling process is not as good as getting a new cartridge every time.
And, refilling can only be done a few times before the cartridge can't be used anymore without errors.
There is no way to reset the printer or cartridge to make it work with a used cartridge which is past its service life.
Good luck with printing on your hp printer.
  • 4,924 Answers
Http://photoprinterink.org/reset-hp-expired-printer-ink.html
this is a movie that explains how to reset it to factory defaults and the counters too by removing the CMOS battery ..
I think this is the best method cause it works for any printer from HP ..
Am using HP 8750 photosmart printer in east timor.I brought 344 cartridges for 97 which the vendor said its equivalent.How to replace cartridges with 344 for a old 97 cartridge.Settings required to change...
Easiest thing you can do to use old ink cartridges:
Move your system Date back to one year before the
Expiration Date(s) before clicking on [PRINT]
(Don't forget to reset the time back after your printing
is finished.)
If you need to print the same job multiple times, set
the date back, print to a File (instead of directly to the
printer), reset the date back and use CopyTo Printer
software to send the file(s) to your printer.
Jul 18, 2011 | Office Equipment & Supplies
I have a HP PHOTOSMART 2610 all in one printer and have developed a printing problem. This printer has been working as it should up until just recently. I have been using the Walgreen's photo service...
Because is refill.When refilled a small gap is detached to make the refilling and it no longer recognize as the brand it use.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 16, 2010 | HP Photosmart 2610 All-In-One InkJet...
Hp c5810 printer error message oxc18a0107 have changed ink but still have error message. what next?
Are you using HP Cartridges?
More than likely if you went to a refilled cartridge or a third party ink and cartridge, that's your problem.
Don
Jan 20, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP photosmart 8750 - cartridge cradle jamb error
You need to check the encoder strip, the clear plastic behind the carriage, ink or grease will stop it from reading and give that error. Also ink buildup on the clean station will slow it's travel.
Dec 22, 2009 | HP Photosmart 8750 InkJet Printer
My hp printer c4580 won't accept refilled ink cartridges how do i do this rodney
> won't accept
Error-messages? What happens? What does not happen?
Did you refill the ink-cartridges yourself, or did you take it to a company that does the refilling?
Dec 11, 2009 | HP Photosmart C4580 All-in-One InkJet...
Error "remove and check color cartridge" after cartridge was refilled.
try cleaning the contacts opd the color cartridge
with a wet towel
if the problem is not solve return the cartridge in the shop you get it and ask them to replace it
Apr 13, 2009 | HP Photosmart 2610 All-In-One InkJet...
HP photosmart 6188 Ink Failiure System
Not sure how to help you. Ink failure I would think is cartridge failure. Are you original virgin cartridges or refills? I need the actual error message that the printer is giving.
Nov 14, 2008 | HP Photosmart C5180 All-In-One InkJet...
Paper jam
is paper crinkled or is printer just giving a jam error/
Jan 15, 2008 | HP Photosmart 8750 InkJet Printer
Remove and check color cartridge error.
Remove and check both cartridges. Make sure you removed the tape and that all the contact points are clean. If that fails, I would recommend taking the cartridges back and exchanging them or replacing them (make sure you get the OEM cartridges, not third party refilled cartridges).
Nov 10, 2007 | HP Photosmart 2575 All-In-One InkJet...
165 people viewed this question
jasbo
jasbo
