Hello, i have a Glen (hot air) downflow bathroom heater which worked for years and it was also cleaned regularly, but the other day it stopped, does it have some kind of trip switch inside or a fuse? that can be changed? Thank you for your help
    Genius:
  • 1,015 Answers
I'm not 100 percent for sure on those its been awile since I worked on one but I think that there is a fuseible link inside that may be your problem Hope this helps you. Thanks
Posted on Dec 30, 2010
Dimplex bathroom fan heater cord problem
take the cover off and clean the inside and were the cord is and use some wd 40 turn of the supply first and that should loosen it for you
Jan 06, 2014 | Dimplex Fx20ve 2kw Timer Wall Mounted...
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
Dimplex Fx20ve 2kw Timer Wall Mounted Bathroom Downflow Fan Heater Pull Cord is stuck
turn of the powere and take the cover off and clean the pull cord and the use a bit of lubricant to keep it free that should loosen it
Sep 24, 2013 | Dimplex Fx20ve 2kw Timer Wall Mounted...
Started cold truck display says engine hot turned off a/c
Hi Glen I'm glad to help!
Glen, I have know way of knowing what type of vehicle or engine you have because there is no information about your vehicle. BUT, the engine controller is seeing something it doesn't like so its turning of everything that will cause the engine to run hotter. My first guess and this is only a guess but, I would say possibly you may have a coolant sensor that's stuck in the hot range telling the computer your engine is hot. The second guess would be, NOTE: only if you have an electric fan. Sometimes the motor will blow a fuse and stop working and the computer see that and stops everything from working that will cause a hotter engine. NOTE: but in the case it would most likely turn on the "Check Engine Light" Hope this helps and have an awesome day Glen.
Apr 21, 2013 | Cars & Trucks
Ducane furnace is always problem with gas valve lockout at fault code blink two times.
use sand paper clean that flame sensor that should take care of your problem
Dec 28, 2012 | Heating & Cooling
I need to know where my blower in my furnace is. I am sure it needs to be cleaned. The duct work in in the crawlspace , and it is a down force unit. Its cramed in a small furnace room with the hot water...
Hello,The blower motor on downflow furnaces will be located at the top panel of the furnace, so when you are looking at the furnace it will be the solid panel on top. The down flow furnace is the one on the left hand side of the diagram.
Jan 31, 2011 | Heating & Cooling
Brivis Upflow/Downflow fan on continuously, no heat
depending on the year of the unit
if its between 1992-1999 it would be caused by the either the pilot not staying alight, or a faulty gas valve not opening,
These models start the fan on a time delay not tempreture so you will only get cold air circulating and when the thermostat is off the fan will stop.
(All models) if the fan is running regardless of the thermostat position an over heat sensor is faulty.
May 17, 2010 | Heating & Cooling
Intertherm Air Handler Coil leaking water
replace it it's junk - going to do that this time because this is the fourth year of the same problem on the hottest days this intertherm junk downflow ac unit condensates where it will not and con not be captured by the pan - built by relatives of the guy who designed the titanic -
Apr 07, 2010 | Intertherm P3RA-024K Air Conditioner
We used to have hot extremely hot water in both bathrooms. One day, the water became warm and ultimately cold in one of the bathrooms. Now, the water is also freezing in the bathroom where the water used...
Your check-valve has most likely failed at the switch.
The flow check valve works by opening when you turn the water tap. When it opens it closes a switch which turns on your heating elements. When this switch fails you will still have water flow, but no heat. Titan has parts for this but you will need to call their service Dept.
or call
Toll free support pesonnel hours (EST): Monday-Friday: 9:00am - 5:00pm
They also have an online support operator during normal business hours here
http://www.titanheater.com/livehelp/livehelp.php?department=2
Mar 24, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Open Questions:
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
