Question about E-Machines eMachines Desktop PC
Sound I fooled around with the sound settings on my computer and now there is no sound comming from the speakers. I checked and made sure everything was plugged in and on and thats not the cause. How can I reset my sound settings or make sound come from the speakers?
    Problem Solver:
  • 5 Answers
You will want to check a few settings in the control panel of your computer.
1. Click "Start" --> "Control Panel". If your using Windows XP, I recommend you click "Switch to Classic view". Double-click on "Sounds and Audio Devices". First, make sure the volume is not muted. Then click on the "Audio" tab. Make sure there are devices listed, and that they are not grayed out. You may try clicking "Use only default devices". Click apply and test the sound again. If this does not work, uncheck the box and click apply again.
2. The problem may be with your audio drivers. Do a google search for "realtek generic audio driver", or click this link Realtek '97 audio driver.
Download the driver and install it. This will install generic drivers for sound cards, which work with many different brands. Try the sound again and see if this works.
Posted on Jul 10, 2008
SPEAKERS DON'T WORK WHEN I PLUG THEM IN.
desktop or laptop computer ?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Sep 19, 2012 | Audio Players & Recorders
Brand new out of the box Dell 560 set everything up and plugged in the speakers to the USB and the jack in the back and nothing no sound. the speakers are on, but the machine says no device detected. ...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 11, 2011 | Dell Audio Players & Recorders
I have a set of Bose computer speakers and they seem to have just stopped working, everything on my computer says they are working fine and when I plug them into my laptop they work, so what could be the...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
hope this helps
Jun 24, 2011 | HP Audio Players & Recorders
No sound comming from my speakers
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
try swapping the speakers around if the problem still persists either the speaker is faulty
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jun 21, 2011 | Computers & Internet
Occasionally i cant get any sound to come out of the speakers, i unplug everything and still not working.what is the problem?
if you are having problems with your sound
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Apr 12, 2011 | Bose Companion II Computer Speakers
Everything connected, but no aound
also
hope this helps
Mar 31, 2011 | Insignia 2.1 Speaker System (3-Piece)
My speaker are not working. everything ishooked up, it says on my vloume control that there is sound but i hear nothing
also
hope this helps
Mar 15, 2011 | Cyber Acoustics CA-3090 Computer Speakers
Speakers
Plug the speakers into your iPod. Any sound?
You may need to maximize the volume-control on the iPod *AND* on your speakers, but you should hear some sound, if the speakers are working.
Try a different set of speakers on your computer.
Make sure that you have not "muted" nor "minimized" the sound on your computer.
Make sure that the speakers are plugged-in to the "green" socket on your computer.
Sep 14, 2009 | Audio Players & Recorders
No sound output at all
check your A-B speaker button. some have a small fuse inside.
Sep 08, 2009 | JVC RX-8010V Receiver
Boston acoustic BA735 speaker problem
Dear oneeyemike77
I am sure that it is not due to one line around. Just check weather the power is on and also check the sound settings on ur pc, it may have been muted or the sound level must have been reduced. You can also check your speakers by connecting it to a mini player or a mp3 player. Dont worry pal, this will surely get u working....!!! Please rate me.
Thankyou
Feb 10, 2008 | Boston Acoustics MicroMedia Computer...
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
