Question about Peavey PV8 8Channel Compact Live Sound Mixer
For PV8 .no matter how detailed the hook ups , I can not get any sounds even from the headphone, all the lights are lit. no sound from mic, cd player..It's very frustrating.
  • Peavey Master
  • 5,603 Answers
If ALL the lights are lit at once, including the clip lights, it is likely there is a failure in the power supply.
Posted on Dec 30, 2010
How can I repair np-11 wont sound
Hi, The reason for no sound could be many things.
Do you have power to the keyboard ( Red light, display lit up ? ) If not could be power supply or power input socket ( these fail and need repairing frequently on older models )
If you have power then check nothing stuck in headphone socket as this would stop sound.
If nothing stuck in headphones, does it work on headphones. If it does it is probably the amplifier that has stopped working.
If you can provide more specific I may be able to help further.
Dan
Oct 30, 2014 | Yamaha Music
I am hooking up a Behringer xenyx 1002B Mic/Line Mixer to my Toshiba Satellite c885-S5194 laptop to broadcast online via meridix. I'm using Audio technica BPHS1 Headset Microphones with XLS plugs and 1/4...
IF your Laptop has a stereo LINE 1/8" INPUT jack, you can take the Stereo ( Left & Right ) LINE outputs on your mixer and feed into this jack on your PC. You will need a 1/4" dual plug for the mixer end to a single 1/8" stereo plug on the PC end. I suspect the problem you are having is either related to your PC only have a MIC input jack or you have something set wrong in your PC's sound config. file. More information is needed to properly solve the problem.
Oct 18, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I just received my RSQ-echo 2000 karaoke machine. When I plug a mic into the front 2 mic inputs, they both have echo, even tho I turned off the echo volume in the back. I assumed that by turning it all...
The control supposedly controls the mix of the echo... this is a reverb type sound. Please note that room acoustics AND if the mic's "hear" the speaker in this, it may create an echo that is NOT under control of the adjustment. Make sure the mic's cannot "hear" the speaker or a reflection off a wall.
Aug 17, 2011 | RSQ NK 2000U
Behringer europower pmp1000, mixer unit, has all leds lit ,is responding to mic. input, bur is not producing any ourput to speakers, can you advise please.
ALL LED's should NOT be lit all the time. If thsy are, there is a failure in the power supply.
plug headphones into the 1/4 inch main output jacks on the top... you will only hear sound in the left side headphone for each. This would verify the preamp is working.
Jun 25, 2011 | Behringer Europower Pmp1000 Powered Mixer...
I can`t get any sound from my pv8 mixer i put the speaker cable i have put the red & white phonos into the mixer from my laptop getting on sound from the clip at all please can you tell me where i am...
Several things to do: Plugging into the tape type inputs... say the 7/8 channel.
The little button below the set you plug into needs to be pushed to the down position. This selects the "B" set which are the RCA jacks.
Below the set you are plugged into. Turn up the top knob "Gain" until the "clip" LED just isn't quite flashing.
At the bottom of that same column Turn up the "level" as needed for the mix.
Then of course, advance the Master level as needed.
May 13, 2011 | Peavey Electronics Peavey Pv8 6-input...
Fender Hot Rod Deluxe has very little sound, stuck and need help! Turn it on and all of tubes light up. Has a horrible muffled sound with volume at 5. Master volume can be put to any level, and it doesn't...
Just because tubes light up does NOT mean they are good or working... While heaters not lit are an indication of failure, teh reverse is not necessarily true.
Time to troubleshoot this... Plug a set of headphones into teh preamp out. See if audio there is clean... it will be low level using headphones and ONLY from one side as the output is mono and your headphones are stereo usually... If audio is clean here and not muffled, then problem is in power amp section else in the early stages of the unit.
Report back the results of this test...
Nov 09, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Digitech Vocalist Live 4 blead through
You need a directional microphone, and then it needs to be pointed away from the guitar. Another technique would be to provide some acoustic insulation between the mic and the guitar, like a wall or a partition like what is used to set up office cubicles.
Feb 23, 2009 | Digi-Tech Digitech Vocalist Live 4...
Roland MV 8800 No inputs, phono
Hi, post on mvnation.com, they will be able to help.
Jan 26, 2009 | Roland Mv8800 Production Studio
Sounds like only one amp is working. Then after a few minutes the red light goes on and the unit shuts down.
90 % of these types of problems are caused by faulty leads .... make sure that you have correct speaker cables and not just a regular guitar cable
Nov 08, 2008 | Fender Passport Deluxe 500watt Sound...
My acoustic guitar sounds choppy when played back.
Try Using A Condenser Mic Or Making Sure That Your Phantom Power Is Turned Off When Using A Regular Mic.\www.Myspace.com/CrossRoadsToNowhere2007
Nov 06, 2008 | Boss Micro BR Digital Recorder
Peavey PV8 8Channel Compact Live Sound Mixer Logo
139 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
