Question about Labtec LVA7330 Consumer Headset
I own a Labtec LVA-7330 Mic. When I plug it in, my computer doesn't locate it. I tried to open up the sound recorder to test it, but it tells me that there is no audio device to be read. It came without a disk, only an instruction manual which had no working troubleshooting options. What could I do to fix it?
SOURCE: Mic is not recognized
Just had the same problem occur on a laptop with same mic. Did the exact same thing yours did, I turned the mic boost on and ran the hardware test three or four times and it finally picked it up. Hope this helps.
Posted on Oct 25, 2007
SOURCE: Install?
poop
Posted on Jan 27, 2008
  • 40 Answers
SOURCE: labtec microphone
try to adjust the line in volume when you double click the volume icon, it may be muted
Posted on Jul 28, 2008
SOURCE: Labtec Wireless desktop 1200 not working- win xp sp2
Seen to be a problem with power manager.
On Linux the solution what
echo -1 >/sys/module/usbcore/parameters/autosuspend
I find it here:
http://www.linuxquestions.org/questions/linux-hardware-18/usb-error-usb-2-4-device-descriptor-read64-error-71-643022/
Posted on Feb 10, 2009
SOURCE: labtec verse 504
If you are using skype, go to the upper left hand top and click on call. Then click on audio settings and make sure your microphone is listed as the mike to use in the window of the drop down menu. It should say logitech something in the window that says microphone.
Posted on Apr 24, 2009
I have just brought a Logitec Webcam C120 and cannot get any sound. Do I have to get a microphone? When I do the sound test can't get any recording back.
Hi lynne_law ,
Many people mistakenly think that webcam can be used for audio as well as video transmission.
  1. Webcams don't usually come with microphones , therefore you would require a separate microphone for your voice recordings and voice chats.
  2. I would suggest you get a headset which would have the microphone option as well , or you can get a hand held mic.
  3. Once you get a new mic, you need to connect it to your computer by plugging in the mic in the appropriate slot , and by default the mic should work.
  4. If it does not work , you just need to change the microphone settings using the volume control option or audio settings via control panel.
Hope this helps ... ) Your feedback would be appreciated.
May 17, 2011 | Labtec Logitech 1200 Webcam
Cant adjust microphone
Make sure your webcam mic is set as default
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Plug the webcam and launch the Logitech dashboard ( toolbar )
Open Settings menu ( 2 gear wheel pic )
Adjust mic to suit
Sep 05, 2010 | Logitech Webcam
People cannot hear me
If your webcam has a built in mic make it the default mic
XP
Plug in your webcam
Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your webcam mic the default device in the 'Sound recording window'
Vista
Plug in the webcam
TEST SPEAKERS
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
Restart computer
Configure your webcam to the chat program
Aug 22, 2010 | Logitech Webcam
Is there a microphone on a labtec 1200, the box says there is, the webpage doesnt say anything, my windows xp with service pack 3 cannot detect any microphone,
To check
Plug in the webcam
TEST SPEAKERS
Restart computer
Aug 02, 2010 | Labtec Logitech 1200 Webcam
I have relocated my PC (HP Pavilion a1604n) which necessitated disconnecting everything. Now I'm trying to connect speakers etc. but cannote locate manual. Where do all these plugs go?...
On the Back of the Case there are connections for the Mic and the sound look for the In or Out Connections You may have plugged the speakers into the wrong plug go to this page FOR A MORE DETAILED test
http://www.5starsupport.com/faq/sound.htm#1-6
Jun 02, 2010 | Labtec Arena 530 Computer Speakers
Computer will not recognize my labtec am-242 microphone
Rt. click the volume control icon from your notification area or the control panel and choose advance settings and make sure the microphone line in level is not at zero. Open your recording program (like sound recorder from Accessories>Entertainment) and you should be able to record sound input from your microphone.
If you're still having trouble, follow the steps here or here (http://www.logicaltips.com/LPMArticle.asp?ID=610)
Also be aware that there's a great freeware recorder available online called Audacity available from here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 01, 2009 | Labtec AM-242 Microphone
Labtec mic plugged in but not working
• Check all connections for the "(type of microphone)" , make sure the microphone switch is set to the microphone button. • If you are running windows® 95 or later, check the microphone volume settings. 1. Go to the start button, All programs, Accessories, Entertainment(multimedia), then Volume control. 2. Make sure the microphone volume isn't set to mute.
3. go to options, then Properties..., select the button next to Recording
4. go to start button, All Programs, Accessories, Entertainment(multimedia), then click on Sound recorder to test your microphone.
Hope that helped! ~xiviogwiffi
Mar 15, 2009 | Labtec AM 242 Desk Boom Microphone...
Labtech 524 microphone does not pick up sound
I have written a guide on How to convert Records and Tapes to CD. I have found that when someone asks me a question like yours here is what I tell them. Go to http://audacity.sourceforge.net/ Download the program Audacity. It is a completely free program. It works great for many audio applications. It does not have spware or adware or anything like that attached to it. In fact many studios use this program. Click on the Download Audacity 1.2.6 link to download the program. Install the program and open the main window. In the middle of the window you will see a field that is labeled Microphone. If the field is not set to Microphone then change it by clicking on the drop down menu. There are two slider controls to the left and right of the small microphone icon. Click on the sliders and set them at about 1/2. These 2 controls are your microphone input level and your Audacity main volume control. Now simply click on the round red record button. Talk into your microphone. If your mic is recording you should see recorded sound waves in the middle of the window. Click on the square stop button and then click on the rewind button. Next click on the green play button. Make sure your computer speakers are turned up. If this doesn't work your sound card may not have recording capabilities or you may have your mic plugged into the wrong connection on your tower. You can move the mic to a different connection and try recording again. Just don't plug into your speaker connection this could damage the microphone. You can check to see if your sound card has recording capabilities by competing the following On your desktop click on start - control panel - sound, speech, and audio devices then click on sound and audio devices. When the small Sound and Audio Device Window opens, click on the audio tab. Under the title sound recording, you should have a sound card listed in that field. For example my card is a SoundMaxDigital Audio. The field is right next to the small microphone icon. If there is no card listed you can buy a cheap one online or even at Wal - Mart. They are very easy to install. You just find an empty slot on *********** board and your computer should recognize the card.
Mar 13, 2009 | Labtec Verse 524 Consumer Microphone
Labtec LVA7330 Consumer Headset Logo
177 people viewed this question
Top Labtec Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
aravind shet
aravind shet
Are you a Labtec Radio Communication Expert? Answer questions, earn points and help others
