Question about Zenith Z56DC1D 56" Television
Detailed instructions how to replace the bulb/lamp in Zenith model # Z56DC1D ALSO how to reset the lamp hours counter and indicator light.
Slinteriors
  • 8617 Answers
SOURCE: Reseting lamp counter (LG)
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) Come back to this blog and post your HOURS on our site
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Posted on Jun 30, 2008
SOURCE: how to reset lamp hours
try holding the enter button on the tv and the mute button on the remote. a reset screen will pop up and then just press the center direction button twice.
Posted on Sep 06, 2008
  • 3 Answers
SOURCE: reseting the end of lamp life indicator
Hold down mute button on remote and enter on TV
at the same time for a few seconds, you should get
a screen promt asking if you want to reset the timer
for the lamp.
Posted on Apr 13, 2009
SOURCE: How to reset the DLP TV Lamp Counter
Press and HOLD the ENTER (or OK) button on the TV
Press and HOLD the MUTE button on the REMOTE
(hold both until the LAMP LIFE HOURS appears on the screen)
Let go of the REMOTE button first, then release the button on the TV
We suggest writing your lamp hours on a peice of masking tape and taping it to the back the TV for future reference.
To reset the lamp counter, press SELECT (or the button in the middle of the direction arrove buttons). Hit SELECT a second time to confirm clearing the lamp counter For certain models, you might have to tweak these steps slightly…offer your inputs!
Posted on May 17, 2009
  • 586 Answers
SOURCE: how to replace NEW ZENITH LG 31419SN984A DLP LAMP
Please see link and find a thread click here. Here you can find the instruction that how to install the lamp.
For amp hour reset click here.
and for new part order click here.
thanks for using fixya.
Posted on Nov 08, 2009
Lamp timer near 10K
just go through the manual it will guide you to solve your problem..........
Aug 23, 2008 | Zenith E44W46LCD 44" Rear Projection...
I have a Zenith D60WLCD, I have replaced the lamp and it still will not power up. I there something I need to reset.
You need to reset the lamp counter if it reaches 16,000 hours. The tv will not turn on once this limit is reached. With the tv remote, and the tv off, push the ? Button on the remote, then 9876, then push the enter button. The three lights on the front panel will flash indicating the counter has reset.
Dec 11, 2012 | Zenith D60WLCD Television
How to replace lamp on Z56DC1D 56 inch television
as a tip Get it done professionally It is not just a matter of popping onhe out and another in. tHThe lamp has to be set up correctly and the hours reset on screen and at the lamp site as well on many models. Many on here have done the DIY option and found they have halos around the objects on the screnn, the lamp blew in 10 mis after installation and many other problems of not being able to set the lamp hours despite it seemingly being easy from the menu.
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Zenith Z56DC1D 56" Television
How to replace NEW ZENITH LG 31419SN984A DLP LAMP BULB LIGHT. I want to reset also my lamp hrs.
Nov 08, 2009 | Zenith Z62DC1D Television
Zenith 56" DLP Z56DC1D won't turn on
Replace Lamp and CK both Fans to make sure they are running.If Fan behind Lamp does not run TV will not light LAMP.
Jul 20, 2009 | Zenith Z56DC1D 56" Television
Replacing lamp
try this to see if it works!
If you replace the DLP lamp out of your Zenith or LG, you will need to reset the
counter…Otherwise you may get an annoying reminder every few days if you’re
surpassed the predetermined hour mark.
Ensure the TV is powered on.
Press and hold the MENU button on the TV
Press and hold the MENU button on your REMOTE
(hold both these until the service menu pops up 5-10 secs max.)
Press and hold the ENTER (or OK) button on the TV
Press and hold the MUTE button on the REMOTE
For certain models, you might have to tweak these steps slightly… offer your inputs!
Apr 26, 2009 | Zenith E44W46LCD 44" Rear Projection...
Reset lamp counter for zenith z52dc2d
Go to stand-by mode press "?" key on remote. then press 9 8 7 6 and the ok button. the 3 led lights will flash to verify the lamp timer was reset
Oct 30, 2008 | Televison & Video
Lamp reset.
there are 2 clocks 1 for lamp and 1 for total, the total you cant change. dark picture, make sure your got same wattage lamp for replacement, I find original Philips lamps the best. if it continues follow manufacture instructions on cleaning mirror and lens.
Apr 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith Lamp Light on
When the lamp is replaced the lamp timer must be reset. The timer is set for just so many hours and then the warning lamp is illuminated. The only way to reset the lamp that I am aware of is with a zenith programmer remote. Perhaps you can find a local lg/zen service center to allow you to use a programmer and instruct you on resetting the timer.
Jan 29, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith Z56DC1D 56" Television Logo
44 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
