Scanner could not find required user interface files
  • 5 more comments
  • sidsnow Aug 08, 2008
    message "sorry could not find required useer interfase files
    Please reinstall scanning software."
    I have reinstalled the printer several times. have done unistall level 2,3, & 4s.
    I do not know how to just install the scanner.
    printer is a HP 2610
    computer is a HP Pavilion a1355c windows xp
    I down loaded rub_wol_Americas_Euro1 from HP's web site.
    I have done every thing listed on HP's site.
    now what?
    hp 2610
    how many did you send?
    same salution again
    soft ware does not give taht as a choise
    again and again
    the soft ware does not give that choise
    i did exactly what you said.
    the wizzerd said i already had the newest drivers,
    let me add that when i boot i get this error mesage
    "value cannot be null
    parameter name path1"
  • sidsnow Aug 09, 2008
    the brand as stated in my original text is HP 2610
    did you read my original text?
I've had the same problem although with a HP Laserjet 3392. In order for the scanner to work it needs two services to run. (In Windows Xp goto CONTROL PANNEL, then ADMINISTRATIVE TOOLS and then SERVICES.)
The following two services was dissabled 1) HP CUE DeviceDiscovery Service and 2) HPQCXS08
I've changed the STARTUP-TYPE to AUTOMATIC for both services and the start them also manually.If you system is not using these two files go into the SYSTEM Event Viewer and look for error messages from the DCOM source just after you have tried a scan. These errors should give you an idea where to search
scanner
Posted on Jun 04, 2009
    Master:
  • 521 Answers
While installing the software it will ask you whether you want to install the full version or just the printer .you select the long procedure of full version so the whole software can be loaded properly and you can use each function easily and properly.
Posted on Aug 08, 2008
  • tech expert12 Aug 08, 2008
    is the cd you are downloding the orignal version or down loaded from internet.
    Master:
  • 623 Answers
Go to my computer then properties then hardware then device manager click printer action scan for hardware changes
  • ritchie dempacco
    ritchie dempacco Aug 08, 2008
    i'm sorry click scanner,action then scan for hardware changes
  • 13,433 Answers
Try reinstalling the software for the scanner?
  • 6,487 Answers
What is the brand and model of this unit so we can help you further??
  • Mark Gil
    Mark Gil Aug 08, 2008
    Follow this:
    Right click MYcomputer>Properties>hardware>Device manager then look for the scanner there and if it has a exclamation mark just Right click on it then click update or reinstall driver then after that put the setup CD for the printer/scanner then let the wizard search for the software..
    Good luck........
Error code f70
F70 Error code means Central Control Unit Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
F71 error code meansUser Interface Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
In both the above situations the following things are required to be checked and replaced where required:
1. Continuity of the User Interface harness.
2. Wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving.
Oct 04, 2010 | Whirlpool Duet WFW9550 Washer
I power on my hp pavilion laptop and its in korean how do i change it
You are going to have to flash the bios to the english version and/or reinstall windoze to reset the language.
pls rate 4 stars
Nov 29, 2009 | HP Pavilion dv6000z Notebook
How to change my laptop language to english from espanoil {acer extensa 5630EZ}
With additional language files, you can change the display language on your computer so that you can view wizards, dialog boxes, menus, Help topics, and other items in Windows in a different language.
There are two types of language files:
Windows Vista Multilingual User Interface Pack (MUI).‌ Windows Vista MUIs provide a translated version of most of the user interface. MUIs require a license to be used and are only available with Windows Vista Ultimate and Windows Vista Enterprise. If you are using Windows Vista Ultimate, you can download MUIs by using Windows Update. If you are using Windows Vista Enterprise, contact your system administrator for information about installing additional languages.
Windows Vista Language Interface Pack (LIP).‌ Windows Vista LIPs provide a translated version of the most widely used areas of the user interface. LIPs are freely available to download, and most LIPs can be installed and used on any edition of Windows Vista. Because not all of the user interface is translated, LIPs require at least one parent language. The parts of the user interface that are not translated into the LIP language are displayed in the parent language. When you download a LIP, you get the parent language requirements for that language. The parent language pack needs to be installed before the LIP can be installed. For more information, including a list of languages available for downloading, go to the Microsoft Local Language website.
http://www.microsoft.com/industry/publicsector/government/locallanguage/default.aspx
Nov 28, 2009 | Acer Extensa 4620 Notebook
How do I set up the scanner to send to a location? One got erased.
depends on the model
if your device has isend
use the remote user interface
type the device ip address into internet explorer address bar
click on address tab
and setup the file option
"\\computername\filename"
the file must be shared
and the computer must have a username and password
Aug 07, 2009 | Office Equipment & Supplies
F-70 f-71 what do they mean
Hi!
F71 error code means User Interface Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 16, 2009 | Whirlpool Washing Machines
How do I change the sleep timer settings on a Motorola MC9090
A - From the Windows Mobile user interface:
1. Tap Start (the Windows Logo), then Settings.
2. Tap the System tab.
3. Tap the Power icon.
4. Tap the Advanced tab.
You can change the number of minutes before power is turned off when on battery and when on external power from there. You can also uncheck the "Turn off device if not used for" check box to disable the timeout entirely.
B - From the registry (useful for deploying the setting as a .reg file to the device, in case you have many MC9090 guns you are supporting or you are wanting to set it to a value the user interface does not support):
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Power\Timeouts]
"BattSuspendTimeout"=dword:00000000
"ACSuspendTimeout"=dword:00000000
The above values are in hex and represent the number of seconds before timing out when on battery or AC power. For example, to set the BattSuspendTimeout to 180 seconds, you would set it to dword:000000B4. To disable it entirely (the equivalent of unchecking the checkbox in the user interface), set the value to 0.
Thanks,
Brad Radaker
Radicomm, Inc.
(makers of QuickTalk - push-to-talk over WLAN for MC9090)
www.radicomm.com
May 12, 2009 | Zebra Symbol Technologies MC909X-G Series...
Scanner : could not find required user interface
I just turned off my firewall protection with CA security center (virus software) and my scanner came back to life. I've had nothing but problems with CA so it's back to Norton for me!
Mar 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
Having HP scanjet 3200 C scanner. Its interface cable is required. Also pl make available its guide/manual
This scanner uses a parallel port interface, so you need a db25 cable, both sides male.
Support and drivers? http://www.hp.com
Mar 07, 2009 | HP ScanJet 3200C Flatbed Scanner
My new PC with the new Vista Vision will not except the software that came with scanner for my Epson Perfection 1260 Model J121A.What can you do ? Sincerely Gunter !
In Vista there is a feature called UCI (user access interface ) that won't allow you to run or install system software.
To install software you need to put CD in, if it goes autorun stop it.
  • Then you click on computer ,
  • click right button of mouse on cd and chose OPEN or EXPLORE, dont double click as it will go autorun again and you'll need to stop it.
  • Locate the installer file (setup or something.exe) in the CD contents.
  • Click right button of mouse on installer file (within cd files) and chose ' run as administrator ' from drop down menu
  • Grant access to installer file whenbever required by Vista.
It should be installed normally. If you still get problems after this it is probably a faulty CD.
Jul 23, 2008 | Office Equipment & Supplies
861 people viewed this question
jasbo
jasbo
