All i know is that it indicates f6 - Heating & Cooling
  • 2,133 Answers
F-6 out door unit high temp.Check condenser blocked? clean it If fan speed less rpm, replace capacitor. And then reset your unit. Now unit will run and no error code..
Posted on Dec 30, 2010
  • armin Jun 16, 2013
    Hi.I have got F6 error in my board I have checked out door unit sensor but i think that is ok.please tell me where is problem.thank you very much
Setting up a formula. I am comparing amounts for the last 3 years of raises and want to figure 5 different ones this year.Example of what I am trying to do. =(F6:F18*1.12%+F6:F18) Can this be done?
in excel ?
=sum(f6:f18)*0.012+sum(f6:f18)
if each row has to be individually * 0.012 add a column and put in this column each row cell * 0.012. example new column G then g6=f6+f6*0.012
a screen print of what you are trying to do would give a clearer indication of exactly what you want to achieve ?
Mar 26, 2017 | The Computers & Internet
What does an F6 error code mean?
The F6 message is an error code that indicates the microwave relay has failed. This is an internal component that will require service.
May 10, 2015 | Kenmore 69682 Microwave Oven
My onida split ac shows F6 . What can I do?
onida 1 ton split ac F6 earror how problem retified
Mar 10, 2012 | Heating & Cooling
What does a F6 error message indicate?
"F6" Motor fault · Check wiring to motor · Replace motor if necessary
Oct 12, 2011 | Asko W6461 Front Load Washer
Getting an "F6" error on
HELLO.
An F6 error code typically indicates a controlpanel problem. Disconnect power and wait several minutes before plugging itback in. If the F6 error code comes back within a minute of restoring power,the control switch pulse return line is not connected properly. This willgenerally require professional repair.
Thanks.
Sep 21, 2011 | Kenmore Microwave Ovens
Im getting a f6 code on my digital control topside pack. what is this and how can i fix it
F6 typically doesnt indicate an error. This is usually a programming code that tells you spa to filter every 12 hours.
If it is a FLo code that just looks like an F6, then you need to either replace the filter, replace the flow switch , or make sure the pump is pushing enough water.
Mar 18, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
Sensor shows F6
The F6 error is indicating a stuck relay on the microwave control board.
Without knowing the age and frequency of usage,
It may just be a pitted contact on the relay, but usually they are soldered in place, and are not serviceable unless you are handy with a soldering iron and the safety factors with taking the metal shroud off a microwave.
sometimes... and this is sometimes...a good jarring will shake the contact loose.
I don;t know if this is a electro-mechanical relay or a solidstate relay... either way... if it sticks once, it will stick again...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 17, 2010 | Kenmore 60654 Microwave Oven
Mistral Air-con split system shows F6 fault! What does it mean?
F6 INDICATION MAY MEAN THAT THERE IS A PROBLEM WITH THE BLOWER MOTOR. WHEN THE BLOWER MOTOR GETS HEATED UP (WHEN ITS WINDING BECOMES WEAK) THIS MAY HAPPEN. SO U GET UR BLOWER MOTOR AND PCB BOARD CHECKED.
Nov 23, 2009 | Heating & Cooling
Whirlpool Diswasher 6th Sense - Flashing Error F6. Do you know that this means?
i had this problem - it indicates a water flow problem - i discovered that the top wiper arm jets were blocked with bits of rice/food - took it off and cleaned it out as best i could , and machine working fine again
Jun 14, 2009 | Dishwashers
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
