Question about Polaroid TDA-03211C 32 in. LCD HDTV
TV shuts down for a few weeks/months and then comes back on. Why?
  • Polaroid Master
  • 1,212 Answers
Very likely that you have bad capacitors. They will work intermittently. You will have one or two bad capacitors in the power supply, and you can also expect some capacitors are aging in the signal board. I have seen many of the Polaroid TVs with bad capacitors as the first reason they go down. Thanks for asking and show a few hands of support!
Posted on Dec 30, 2010
Tv will power on not picture
I would have the power supply checked for the screen and then have the power button checked it may be faulty.
Sep 20, 2017 | Panasonic WD65638 Mitsubishi WD65638 65""...
Le2412 power on problem
The power supply is failing.
Dec 20, 2013 | Apex Digital LD4088 LCD TV
LG 47LE5400 loud POP, shuts down, immediately comes back on OK. Happened 4 times on two months. Dangerous?pman407@
That is interesting.
Only thing I can think of is electrolytic or other non-essential filter capacitors bursting.
It is hardly dangerous for you, but it is most likely dangerous to the TV itself.
I'd open and inspect the boards for signs of bust components.
Dec 09, 2010 | LG 47LE5400 47 in. TV
I have a GE model 46GW945 and it will work fine
I have a 1997, 19inch GE TV it comes on for about 10 to 15 minutes then shuts off and will not come back on until a few hours go by or so?? Anything will help Thank You
Dec 18, 2009 | GE Televison & Video
TV turns off because of air flow
It is probably a bad temp sensor inside the TV. My 73" started shutting down before it was a year old. I moved it way out from the wall and it got a little better. A tech was just out to change the bulb under an extended warranty and he said there is a service bulletin about the temp sensor. If your TV is out of warranty you might call Mits and see if they will cover the sensor replacement. Tech said it takes about a 1/2 hour in the home to change it...
Apr 20, 2009 | Mitsubishi WD-62525 62" Rear Projection...
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
After turning on the 42" Vizio, the sound turns off
One week old? did you ever think about taking it back to the store where you bought it?? would be my first choice. unless you want a bunch of crazy answers or taking it to an authorized repair shop and waiting a few months for parts to come in and more time for the repair to take place.
Nov 29, 2008 | Vizio 42 in. LCD TV
Won't turn on
those tvs will try 3 times before completely shutting down. you can try and take the back off and check CP150 it is a large capactior located near the middle of the board on the left hand side(looking from back) if it looks and feels like the top is vented or puffed out then that could be the problem. if not i suggest having a qualified service tech take a look because there are too many things that could be the root cause.
Apr 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 51F500 Shuts down during summer months
I am finding out that these sets have almost the same problems mostly going back to middle power supply broad ck all connections,then try looking for leaky caps.
Nov 08, 2007 | Hitachi 51F500 51" Rear Projection...
TV shuts off and red standby/timer lights blinks red until I power the set off. When it shuts down it does so with a very loud snap. When I turn it back on the screen is blue and has light blue...
The most common cause for what you are seeing is a shorted gun in the picture tube. When 2 elements (heater and cathode) of one of the guns inside the neck of the picture tube touch, that gun goes full on and overloads the flyback (high voltage) transformer. If it is in the blue gun, the screen will go bright blue with light blue "retrace" lines in it. The computer senses the overload and shuts the set off. At 2 years old the tech most likely tried removing the short by arcing between the elements. This works sometimes but the short often comes back a few months later. Another attempt at removing the short could be tried, and it might work this time, but it may or may not work for long. The ony other solution is to replace the picture tube but that would cost much more than the set is worth. A qualified tech will be able to tell you if this is the problem in your set.
Aug 21, 2007 | Sony KV-35S36 35" TV
Polaroid TDA-03211C 32 in. LCD HDTV Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
