Question about AT&T DECT 6.0 Cordless Phone System with Digital Answering Machine
Phone: at&t dect 6.0 says " BASE NO LINE" how
Phone: at&t dect 6.0 says " BASE NO LINE" how do I fix it? It has no dial tone, can't call out or receive calls. Have tried unplugging it and leaving it for hours, but no success.
pctech1
  • 1940 Answers
SOURCE: On one of the 3
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
6. Set the phone on the desired base when the phone's display says to.
Posted on Mar 06, 2011
SOURCE: There was a power surge, and now my phone is stuck on pulse dialing, how do I get it back to tone?
You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
After moving the admin switch, and before dialing Ftr 7 -
From station 10 press intercom,
Press speaker,
Dial *0,
Dial 1,
Then Press Ftr 7.
Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
dialing.
To change the dialing type for a line or lines, press the line button(s) and dial the
appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
Be sure to turn the admin switch back off when you’re finished.
Posted on Aug 05, 2008
SOURCE: My DECT 6.0 is giving a message of ¨line in
battery problem.solved.
Posted on Mar 25, 2010
greg411
  • 45 Answers
SOURCE: phone line won't hang up
I would check the DSL filters. Your phone should not interfere with the DSL. Make sure there is a filter on any line going into your phones. If there is a filter replace it and see if that works. Also, check other equipment on the line, fax, computer, credit card machine. They will need filters from the DSL too. Remove these other devices and check the line for the problem then add them back one at a time.
Posted on Apr 17, 2010
  • 1196 Answers
SOURCE: i have a AT&T model
You can try reset your phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if this fix the problem.
Posted on Mar 14, 2011
At&t dect 6.0 all 4 handsets say no line
check base unit .
Check phone line is plugged into base and wall
Check base unit has power going to it
If it all looks ok try plugging a normal landline phone into the base unit locations phone line to see if there is dial tone .
Jan 28, 2017 | AT&T Lands Phones
I not have manual for Uniden dect 6 cordless phone on my phone I can't get any dial tone,I think I pressed a button on the phone either mute, intercom or redial, how to reset phone
If you have no dial tone the problem is most likely the base station has failed, nothing you can do will kill the dial tone (no button you pushed etc.) except a failed base station.
Dec 19, 2016 | Uniden DECT 6.0 Cordless Phone
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
Panasonic DECT 6.0 shows "in use" but it's not. Why?
When I get this error, it's often a problem with the phone line wiring. Sometimes, it is the phone itself.
I like to use a spare corded phone and a new RJ-11 cord to localize the problem. First, try using the spare phone at the jack where the Panasonic base is plugged in. If you get a dial tone with the spare phone, try the new RJ-11 cable with the phone. If there is still no dial tone, then the phone needs repair or replacement.
If you do not have dial tone with the spare phone, try the test phone at another jack on that phone line.If there is dial tone, there is a problem with the first jack. You will need to open the jack and check the wiring. These are either keystones jacks or screw terminals. The keystone type require a special tool to press the wires into the terminal block. This is available at many hardware stores in the electrical wiring aisle (with the keystones and wires for whole house video/telecommunications access).
If you still have no dial tone, find the telephone access box. If you are lucky, that box has RJ-11 jacks so that you can test the line. If there is still no dial tone, contact your phone company. Outside line problems will be fixed by your provider.
If you have dial tone at the access box, you have a wiring problem somewhere inside.You can try to track the wires in any exposed area for signs of damage. You might want to call a professional to check the wires in the wall. Your phone company will do this for a fee.
I hope this helps.
(my own phones gave "Line In Use" when a contractor damaged a wire digging in the wrong spot and when mice got to the underground lines outside. Those problems were fixed by the phone company.)
Jan 29, 2013 | Panasonic DECT 6.0 Expandable Cordless...
No dial tone...line in use appears on screen
you may have a broken wire somewhere or a bad jack
Jul 31, 2012 | Vtech DECT 6.0 Digital Cordless Phone
On one of the 3 phones I get no dial tone and the message "Unable to Call Try Again"
Mar 06, 2011 | AT&T DECT 6.0 Cordless Phone System with...
Phones show line in use. Can not find a phone where this is the case. What do I do?
This indicates an off hook condition of the telephone line, to test it you could disconnect the telephone cable from your wireless system base and connect to it a standard wired phone, if you have dial tone and can make and receive calls, the line is OK and the failure is at the base of your wireless telephone system, if you don't have dial tone with the stardard telephone there's a telephone network failure (the telephone wall plate, internal or external cables, etc) and this should be reported to your phone company to be fixed.
Mar 01, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Aug 01, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
AT&T DECT 6.0 Cordless Phone System with Digital Answering Machine Logo
1,786 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
