Hi my bush mp002 docking station keeps displaying usb error do you know why this is ??
  • 24 Answers
SOURCE: IBM Thinkpad T41 docking station USB ports
Try removing all the USB devices in Windows Device Manager with the laptop docked. To do this: Right-click My Computer, left click Manage. On the right side of the window, click Device Manager. On the right side, click the + sign next to USB Devices. Highlight each device under this heading and hit Delete on your keybaord to remove all the devices in order. Then right-click Computer at the top of the list and click Scan for Hardware Changes.
Hopefully Windows will re-detect your USB devices and get them back operational.
Hope this helps!
Posted on Jan 31, 2008
coolcat_12
  • 259 Answers
SOURCE: my printer has a parallel plug and my new docking station...
You can buy a cable that goes on your old printer cable to convert to USB most computer shop will hav these or can get one
Posted on Jan 26, 2009
SOURCE: USB ports in docking station stopped working suddenly
I was having the same problem - the USB ports seemed to have stopped working so I could not use the mouse, keyboard, or printer, even though the monitors and power could still operate through the docking station. Finally, I just unplugged the docking station for 30 seconds, plugged it back in, and everything resumed working. I was surprised it was that simple, but it's working for the moment.
Posted on Mar 23, 2009
SOURCE: Docking Station problem
I had the exact same problem. When i undocked the laptop i had to reboot it when i put it back, in order to get the USB devices working. By updating the System Interface Driver, located here: http://www-307.ibm.com/pc/support/site.wss/MIGR-67228.html , the USB devices now power back up when you redock the laptop without having to reboot the machine.
Posted on Apr 30, 2009
  • 357 Answers
SOURCE: Dell Latitude 630 docking station USB ports no longer work
Try removing the laptop, unlug the power to the dock and wait a few minutes, then connect the power now put your laptop back on the dock.
I hope this helps.
Have a good day and good luck.
Posted on Nov 20, 2009
HSTNN-I11X
Hi
you have two options
1. Use Docking Station, more USB peripherals use USB port.
2. Docking Station also replaced by new.
Apr 18, 2014 | HP Docking Station
Ipod Dock no longer works...
Have you checked the contacts where the device slides into it? First thing I'd try is flipping the dock upside down and sweeping a small paint brush along those little metal contacts, to make sure there's no debris in them, keeping them from making contact. Make sure that the metal contacts are in proper alignment to fit with the contacts in your device. Also if the contacts aren't shiny metal, a piece of fine sandpaper run gently along them will pull the corrosion off.
Nov 08, 2017 | Panasonic SC-HC3 Mini Stereo Audio System...
Hi, I connected my monitor and my ethernet cable to the dockingstation SD400V, But there is no connection at all. No internet access and no image on my monitor. Can you help me?
Hi
I had trouble with this Docking Station.
Use USB 3.0 and try this:
1) follow this instructions: http://support.euro.dell.com/support...l=pl&s=gen&cs=
2) restart, unplug docking station
3) install this software: http://www.displaylink.com/support/downloads.php, version 6.1
4) restart
5) plug docking station
After all, it should working.
In any questions, write: pawel_surowiec (at) o2 (dot) pl
Mar 30, 2011 | Kensington SD400V USB Docking Station with...
Hi, My 2.5" laptop hard drive
If the hard drive fails to seat itself in your docking station, then the docking station is not suited to communicate with that drive. Never break off portions of the drive as they contain the wired contacts necessary for communication. Get a USB drive extension from TigerDirect.com
Sabrent EC-UST25 - Storage enclosure with data indicator, power indicator - 2.5" - SATA 3Gb/s - 480 MBps - USB (EC-UST25)
Feb 08, 2018 | Kingwin Inc. Kingwin 2.5? / 3.5? EZ-Dock...
USB port on docking station does not work
Power. You may find that the ower managment settings need to be changed or an external supply is needed.
May 28, 2009 | Motion Computing LE1600 Tablet PC
How does a USB docking station work w/ a regular docking station
the older pc probably needs a usb 2.0 port to run docking station. the manual on the docking station should tell you. you may need to install a usb 2.0 pci card in your older computer for it to work.
Mar 18, 2009 | Dell Inspiron 5160 Notebook
What is the docking station for?
a usb cable will work... the docking stations are handy as you just put the camera/camcorder into the docking station ... no extra cord... often has the charger built in as well
Robert
Jan 19, 2009 | Sony HDR-SR11 Flash Media Camcorder
Viewsonic VX 1945-wm-3 not detecting iPod Mini 4GB 2nd gen
USB device not recognised" - means windows needs driver to function. As soon as you connect USB device it check driver in cache it is available it detect smoothly you can perform else it generate errors.
first to instal driver from CD
May 24, 2008 | Gateway FPD2275W LCD Monitor
Casio Exilim ex-z40 won't down load
Try reinstalling your camera drivers. You need to uninstall it first while docking station is removed. Then reinstall your camera software through the cd that comes with it then try plugging it in again either on the same usb slot or a different usb slot. Then try docking the camera again if theirs any interruptions. Usually if you transfer the docking stations usb cord plug to a different usb slot, the transfer goes haywire. Try transferring to a different usb slot...
If all else fails, get a card reader for your cameras memory card, it is way faster...
Feb 08, 2008 | Casio Exilim EX-Z40 Digital Camera
354 people viewed this question
 Grubhead
Grubhead
