Question about Pool & Spa
Not a problem just want to turn it into a 110 pump from 220
    Guru:
  • 46 Answers
Not all pumps can be converted.
If you open the back of the motor that you are trying to wire, there should be a wiring diagram on how to wire the pool motor either 220 to 110. Its relatively simple to follow, since you are only going to be connecting 3 wires.
Without knowing the manufacturer of the motor, the size, or the style, it is nearly impossible for us to walk you through or provide an alternative schematic.
Take a look and see if there is a wiring diagram, if not, go ahead and gather the additional information off the motor and come on back to us.
The Ugly Pool Guy www.WeFixUglyPools.com
Posted on Dec 30, 2010
Installed turboflush300 in the Philippines and need to change 110 to 220. Can the wiring terminal be changed?
Don't forget the heating element it's 110 will burn out quickly on 220 also the electronic control same
Jan 19, 2015 | Dishwashers
How to rewrite Polaris pomp from 220 to 110
see insructions on side of motor they come wired for 220 if wiring 110 you have to change either the knob to 110 or move the white and brown wires as shown on side of motor then green wire goes to the case
Aug 31, 2014 | Pool & Spa
I need to install a new AOSmith 1 1/2 horse pump for my pool. The to lines that come from the house are both 110 volt. The pool is wired for 230 volt. Will attaching the 110 lines work for the required...
There is nothing that you can do with respect to the 220 volts vs. 230 volts and fortunately, it does not matter. There is no voltage adjustment that you can do.
The 220 volts comes from TWO DIFFERENT 110 volt lines. Typically, your breaker will handle that correctly for you, be sure that both breakers are bridged, mechanically, so when you turn one off, both go off (prevents electrocution).
Mar 30, 2011 | Pool & Spa
Its a water pump for our house and barn pumps probably close to 300 to 400 gallons a day over the course of the day was wondering if it is wired for 220 if using it with 110 will ruin it
Unless the pump motor has provision on it specifically for running on 110, then yes, running a 220 motor on 110 will ruin it. It will cause the motor to overheat, if you can get it to work at all. Some 220 motors are designed so that you can run them on 110. If yours is, it should have instructions and a wiring diagram for that. Even if it IS designed for 110 or 220, running it on 110 WILL cause it to run hotter, and will shorten its life.
Mar 04, 2011 | Plumbing
My pump (pentair whisper flow 1 hp) has been making noise for about a year. Then it started making a clicking noise on top of that, and I knew it wouldnt last but a week. A day later it never came back...
Based on your description of the breakers you should have 230VAC to the pump motor. Even if it is only 115VAC you should still get a response from the unit when powered on. A 230-connected motor will run on 115 for some time but will overheat and eventually fail. If you are getting nothing you have issues with the power as well as the pump. Get the $40-$50 multimeter and check your line voltages to ground and line-to-line. You will find a problem somewhere.
And to answer your other question...yes, connecting 230VAC to a motor setup for 115 will burn up the winding.
John
Jan 16, 2011 | Pentair Pool & Spa
Pool pump turns off after 1/2 hour or so but I can turn on manually after it sits for a while. Timer is working fine. Hayward Super II around 5 yrs old. Do I need to replace this motor? This problem just...
Your pump is protected by a thermal device that shuts it off when over heated. Are you running 110 or 220? In my experience, your pump will run cooler on 220 ... consider coverting if appropriate.
Aug 28, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Need wiring diagram for 1081 motor,1.5hp.I want to change from 220 to 110.
What is the reason you want to change? 220 is not only stronger ... it is cheaper to run. If wiring is a problem, (this pump should be on its own circuit) simply replace the single pole breaker with a double pole and take the existing white wire and turn it into a "red" wire for your 220, (put the white (red) wire on the second pole of the new breaker.)
If you will remove the cover on the back of the motor, you will probably find a plug that you move from the 220 position to the 110 position. Change the plug from 220 / 20 amp to 110 / 20 (or what ever the motor will require) Normally, when you change the voltage in this direction (down) you send the amps up by 2 times. What I mean is if the motor uses 7.5 amps at 220, you will be using 15 amps at 110. Make sure you have at least #12 wire for a little extra safety.
Thanks for your interest in FixYa.com
Aug 09, 2010 | Century Pool & Spa
A o smith b854 motor schematic diagram 115v . How do I hook up 115v to the factory set 230v?
Remove the back of the pump housing ... inside you will find the 110 volt connection place.
If your pump is on a dedicated line (as it should be) run it on 220 VAC ... To convert your line from 110 to 220 all you need is a double pole breaker of the proper amperage ... take the white wire presently on the ground bus bar and put it on the other side of the new double pole breaker. Then you will have 220 ... and you will save a few bucks on electricity.
Jul 11, 2010 | Smith Pool Pump Motor Square Flange - 1 HP
Does it matter if use 220 or 115... looks like i have 25 amp in the box with gfi.. need connect the wire to back of the motor.. outside i have the big circular 3 pronged connection to the outlet... do i...
220 VAC is more efficient ... so there is some cost savings in the money department. Volts X amp = watts generally ... there is still a savings because you will actually consume fewer watts at 220 (watts is what you are purchasing form the power company)
Wiring depends ...you going to use 110 or 220? if 110 ... black is hot and goes to L1 ... white is nutral and goes to L1.
If 220 ... black is hot and goes to L1 - white is hot and goes to L2.
Your owner manual has a good picture and description of this.
In the plug ... 110 - neutral should go to the left slot.
Is your breaker 110 or 220 (single pole or double pole - one slot or two slots)
These voltages are not compatable!
I suggest you use this pump at 220.
Jun 04, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
I need the instruction manual for a Sears submersible pump model M4D02B-01. I would like to use it to pull water from a lake and about 25 feet in elevation. It is rated at 230 volts but I currently only...
Assuming that your Sears submersible pump Model
M4DO2B-01 can pump water at more than 25 feet
elevation. You can run it even without a manual. Just connect your discharge hose up to the point of discharge. Use a 220/110 volts transformer with a rating of at least 3KVA. Connect your 110 volt line to 110 outlet of the transformer and the submersible pump to 220 outlet of the transformer. This 3KVA transformer can handle up to 1HP pump.Send your
e-mail for further assistance.
Jul 07, 2009 | Plumbing
Pool & Spa Logo
277 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
