Question about Raymarine RL70CRC GPS Receiver
Have a Raymarine C60 Chartplotter w/ GPS. I am trying to install a new Standard Horizon radio that has GPS. I have taped the wires, red; yellow; and bare into the wires leading to the GPS. When I connect them, the Chartplotter shows the GPS signal lost. Do I need to use an interface block of some type? All the leads from the GPS now, come out of this block, one from the GPS unit, one to the C60 Chartplotter, and one to the Autopilot. Also the power to the GPS is shared by the Autopilot, same cir’t breaker. Can you help me?
4 Suggested Answers
  • 4090 Answers
SOURCE: standard horizon 155c not acquiring signal
If the signal is good statement seems to imply that it is working, perhaps this is my misinterpretation of what you mean by this.
Signal refers to the abi;ity to connect to satellites
4 are requied for triangulation.
If the unit is fully charged and not connecting , then it is quite possible that the unit has a damaged SIIRF chip or whatever chip was used in your model to acquire satellite connection. The cost of repair is costly, it means total replacement of the M/Board.
Never start car with the unit connected into DC car power, spikes will damage the chip
Posted on Jun 30, 2009
  • 43 Answers
SOURCE: I Have a Raymarine Radar RL70CRC HSB2 the
If both plotter works but they have no comunikation
RESET the RL 70 AND L760
This is how it works
press the powerbutton when you have picture press the menu bottom
than systemsetup and than four seconds the menu bottom.
Do this on both plotter normaly after this it works again
Posted on Oct 22, 2009
  • 43 Answers
SOURCE: GPS antenna
If your old antena is a Seatalk or NMEA antena you can use it for your C80
If you GPS antenna is older than five year change it.
Posted on Oct 31, 2009
Wiring to standard horizon eclipse GX 1 300E
It is more than likely green and yellow for one and blue and brown for the other with white being redundant ground.
May 04, 2016 | Cars & Trucks
Raymarine a50d continuously resetting itself?
If there's a memory card installed for maps, try starting up the unit with it removed. It's possible that the card might be corrupted and stalling the start-up sequence.
May 10, 2014 | Raymarine A50D 5" Fishfinder /...
Need to reconnect a c-80 system. I think the MFD, radar, GPS, and depthsounder are connected via Seatalk
I think your best bet here would be to post your query on the Raymarine forum.
There are actual technicians over there to look after you.
http://forum.raymarine.com/
Hope this helps you out.
Aug 01, 2017 | Raymarine C80 GPS Receiver
Can it take ais?
A Standard-Horizon CP180 Chartplotter can recieve information from an external AIS device with a NMEA data wire connection. The cable from the NMEA output of the AIS would be connected to "Port 1" (Page 18 of the CP180 user manual) on the CP180 and then the CP180 menu settings configured to show AIS targets, data, etc. (Page 21 on the CP180 user manual)
Nov 19, 2010 | Standard Horizon Cp180 Chartplotter
I need an operating manual for a Standard Horizon CP155c chartplotter
please call Standard Horizon Marine Support 800-767-2450 and they will email you the manual.
marinetech@vxstdusa. com
Sep 10, 2010 | Standard Horizon CP155C GPS Receiver
MY RAYMARINE A65 CHART PLOTTER/ FISHFINDER HAS NOT BEEN WORKING , THE CHARTPLOTTER WORKS FINE , BUT THE FISH FINDER WONT PULL UP BOTTOM OR ANYTHING . I LOOKED AT THE LITTLE BOX THAT CONNECTS TO THE...
Likely your DSM25 (that little box that connects the transducer to the display) will need to be rebuilt. The red LED is saying that there is an internal fault with the unit. You would need to send the unit in for repair through Raymarine (as there really is not anyone else who can do it), and they would have to replace the main circuit card in the box. I believe that they are charging either $150 or $175 to repair those now... but likely the only way you will get that one to work again.
Jul 27, 2010 | Raymarine A65 Combo GPS...
Standard horizon 155c not acquiring signal
Jun 30, 2009 | Standard Horizon CP-150 WAAS GPS Receiver
Sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Jul 14, 2008 | Raymarine A65 Combo GPS...
GPS antenna
If it is an RS 120 or an RS112 antenna you do not need to change it.These are both active antennas in other words they do all the gps computing in the unit itself. You need to look at the wire from the antenna. If it is a coax cable(2 wire) it will not work.If it is 3 or 4 wires it will work. If 3 wire (red ,silver yellow) just hook up color for color.If 4 wire you are going to have to figure out the wiring for it from the units wiring diagram.That could be a big enough pain that you might be inclined to change to the new antenna. If you wire the new RS125 antenna you must wire it to the seatalk buss. The seatalk wires are Red Silver and Yellow.The wire from the RS125 are red yellow silver green and brown.Wire as follow to your sea talk cable.Yellow to Yellow, red to red , silver to silver, green to red, brown to silver.
Hope this helps.
Jun 04, 2008 | Raymarine C80 GPS Receiver
Raymarine RL70CRC GPS Receiver Logo
611 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
