Question about Acer Veriton M265 Minitower Desktop 160GB (PSV8803010)
Acer veriton m265 no video display after a short time, cpu remains on but inactive keyboard. Have re-installed vga drivers and bios update but problem still persists. No error logs. Power led on vga turns red. have changed Ram, Vga , cleared bios but problem still persists.
    Sergeant:
  • 210 Answers
Hi, Please check the processor heat sink and cooling fan if is seated properly. If yo have the motherboard cd yo might need that later to reinstall drivers. Go to device manager and check if there is a question mark or exclamation mark. right click and click property and uninstall the driver. if you do not have motherboard cd, you may use device doctor software to scan the pc this software is a freeware and or donate few dollars if you wish. It nice to have this to your computer. I hope this will help to solve your problem.. HAPPY NEW YEAR..... HRH
Posted on Dec 30, 2010
How can i make the lan work with windows 7 on acer veriton m265
is setup is right for os version then try to instal device manager add new hardware tab and locate driver file
May 13, 2012 | Acer Veriton M265 Minitower Desktop 160GB...
How to restore the operating system of acer new veriton m265 once corrupted?
Do you have the CD's that came with your system? If so there should be a rescue disc.
Nov 24, 2011 | Acer Veriton M265 (PSV880Z001) PC Desktop
Should an ACER 5900 veriton, processor cooling fan, vary in speed ?
Yes all computer fans will vary their speed in order to conserve power. They will speed up when the processor is being used as it generates more heat and needs to be cooled more but if the tower is inactive the fan will slow as it does not need as much cooling.
Aug 29, 2011 | Acer Veriton M265 Minitower Desktop 160GB...
During running operitng system my pc acer veriton m420 leave the display on TFT but CPU remain On. This problem starte after 1 mint, 5 mint and some time 1 hour.
First you re-install the chipset driver. If same issue showing, change the VGA cable. If problem remains, connect your system with other working monitor (if it is working, it'll be the problem with the monitor). Again problem showing, it should be the problem with the chipset. Take the motherboard to a chip level service centre...
Good Luck
Aug 02, 2011 | Acer Veriton M420 PC Desktop
Want a mainboard driver for acer veriton m265
heres the link where you can download your driver
http://support.acer.com/acerpanam/desktop/2009/acer/veriton/VeritonM265/VeritonM265sp2.shtml
Feb 14, 2011 | Computers & Internet
Acer Veriton M265 and M275 Desktops shutoff video without any apparent reason. CPU continues to run, CPU temp ok, no scheduled tasks, no screensaver, no power options, no hibernation, nothing logged into...
If there are no error logs, seems to be a hardware problem.
Could be the monitor or the video card.
Try updating the video drivers and BIOS from the Acer website.
Nov 16, 2010 | Acer Veriton M265 Minitower Desktop 160GB...
Acer Veriton M265 chassis intrusion alarm
Depnding upon model Acer use one of the following to enter the bios settings:-
F1, F2 or CTRL+ALT+ESC
Apr 04, 2010 | Acer Computers & Internet
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
Can not start acer veriton 5600g with ati 1650 pro agp card ? The bios doesn't seem to recognise the card and it beeps when i disconnect the onboard vga. Any help will be appreciated... thanks
How did you disconnect the onboard VGA?
The onboard VGA device must be disabled in the BIOS and the ATI graphics card inserted in the computer.
When you bootup it should default to a standard Windows VGA configuration, then install the ATI video driver o you can get high resolution graphics.
Jun 24, 2009 | Acer Veriton 5600G PC Desktop
Display problem
The most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
the vga board has failed, its a very common problem in acer laptops, you can get a replacement part from www.acerparts.com im not sure if they ship into us but for europe thats where I get my parts.
my acers vga failed two times, ones within warranty and 12months after that, I have to say that acer products are really bad quality, I'm not sure about the latest models but from what I've seen the vga chipsets have real issues with the motherboards and keep failing over and over again.
I have not looked inside your model but the vga is either integrated into the motherboard = that means the repair will cost the whole motherboard, better to buy a new one.
if your model has a removeable vga like mine does, then you can consider changeing it to a new one. contact acer parts.
One of the covers in the bottom is the memory, one is network and last one I don't remember.
here are the contact details if your acer is out of warranty
http://www.acerparts.com/contact_us.php
The parts for your model are at http://www.acerparts.com/index.php?cPath=561_562_1064
you will have to contact acer parts directly, it may be that the vga is build into the motherboard or then the vga parts are not listed.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 29, 2008 | Acer Aspire 5570-2758 Notebook
Acer Veriton M265 Minitower Desktop 160GB (PSV8803010) Logo
412 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
