Question about Samsung LN32A330 32 in. LCD TV
Can you use a blueray dvd player with this tv? thanks.
  • 11,361 Answers
My onn tv Model tl1939 BDTP refuses to read DVDs. I replaced the DVD with a new player, but the fault's the same. Any ideas?
Could you be inserting a BD instead of DVD. DVD players will not play Blueray. Bluerays will play DVD.
Nov 03, 2014 | Televison & Video
Tip
DVD Player Quick Connect Tips
There has been a lot of confusion lately about how best to connect your new DVD or Blueray player to your TV set. For many this has been a nightmare since the introduction of the new Component and HDMI versions of Higher Priced DVD and Blueray disc players.
Remember that your new Blueray player will play DVD's as well as Blueray Disc format movies.
For the common connection that most people use, there are only 3 wires to consider. Yellow for Video, Red and White for Stereo. Always use the line out jacks on the back of the player to connect to the TV. Use the Line in (Video In) jacks on the TV set.
The only thing to remember here is to match the colors exactly and select the video source from your TV remote control. If all those numbers and buttons are confusing to you, just memorize where your Source button is on the remote, and choose one input at a time until your DVD welcome screen appears.
The next higher quality Video source will be the component Video outputs on your DVD or BlueRay player. These will be Red, Green And Blue.
Also note that you will need a red/white audio cable for sound with these connections since the component outputs only transmit Video.
You will be able to see the audio connectors close to the red blue and green component outputs on most players. All connectors on your player will be outputs, unless you bought a DVD recorder and player.
We will reference only the player type at this time.
As mentioned before, you only need to match the wires from the DVD or BlueRay output to the exact input connectors on your TV, but now the audio connectors need to be used as well.
Component to component cables/
Stereo Audio Cables/
Use your source selector on the remote as before to View your movie.
The easiest connector to hit the market so far is the HDMI version, which combines the Video signal as well as the audio signal into a single manageable cable. If your TV set doesn't have this connector you will need to use one of the above methods to connect your system.
To use the HDMI you need only plug it in to the connector designed for its use on both the TV as well as the player.
There is very little chance you will connect this to the wrong port, but just in case your HDMI TV and DVD/Blueray player are equipped with an Optional USB port, you should read the panel closely to be sure you have the right port. Remember, these connectors should never be forced on. If they are too tight to connect, you may have chosen the USB port by mistake.
Thats my Tip o the Day
Please Vote for this Tip if you found it helpful.
Bob S.
on Mar 23, 2010 | Audio Players & Recorders
How to connect netflix with sony blueray disc player?
Switch on the blueray player. Switch on your TV set. Connect your blueray player to the TV with an appropriate cable. Press HOME on the blueray player. Navigate with the blueray player remote control to NETFLIX and press OK. After a few seconds NETFLIX should start.
Jun 22, 2014 | Netflix
SONY BLUERAY FULL HQ1080
you want to watch hd 1080P? what is your question? to watch full 1080p you need you bluray player a bluerays disk and a tv that can actually handle 1080p, just because a tv is new and "big" wont ensure it can handle 1080p
Mar 30, 2013 | Televison & Video
I have up dated a sharp BD HP22 blueray player so it plays new bluerays, but now it doesnt play normal dvds, what can i do. thanks
Check the DVD code written at the back of the player ( 1,2,3,4,5 or 6 ) and see if your disc code matches if not it will not play once you update the firmware. You see many of the players sold in the market have the DVD codes unlocked, but once you update the firmware it automatically goes back to its native region.
Sep 11, 2011 | Sharp BD-HP22U Player
DVD 30 turns off when I put a disc in and it reads it.
I understood your problem...Harman Kardon BDP1 BluRay Player generally it cause due to lens problem and data processor it may be creates a problem.
you have one option to use lens cleaner CD which removes dust from the lens it may be helpful to you.
Thank you for giving me opportunity to solve your problem.
please give me your Ratings!!
Jun 20, 2011 | Harman Kardon BDP1 BluRay Player
Does this model have the capability to handle a blueray dvd playe
Yes,u can hook up a normal DVD player in this tv before right?A Blu-Ray DVD player not much difference,just a better form of a DVD player.
May 22, 2010 | Televison & Video
Unable to play Blueray dvd James Bond
try pressing the topmenu/title list button prior to the disc loading - my copy of quantum of solace would not load on my sharp blu ray player and this worked.
Feb 06, 2010 | Sharp AQUOS Blu-ray Disc Player
When tv is wired to media center and then to blueray dvd , disc will not play. Non blueray disc will play. When tv wired directly to blueray player, blueray disc runs fine. Cables are hdmi
Hi.
When you say disk will not play I assume the BRD player does not start playing.
If the Blue ray unit does not start at all and stays in stand by , then the HDMI cable you are using to connect to TV, or HDMI port on TV may be defective.
Try replacing cable and swapping HDMI ports.
Oct 24, 2009 | Bose Audio Players & Recorders
Samsung LN32A330 32 in. LCD TV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
