Question about Seagate (ST3160827AS) 160 GB Hard Drive
My segate hard disk got corrpted . Want to recover my data
  • Seagate Master
  • 27,725 Answers
You could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
then run your antivirus program
hope this helps
Posted on Dec 30, 2010
I have 250GB segate internal hard disk but framework is corrupt how i upgrade or recover my date (Disk not detected)
if its not detected this solution maybe crazy but sometimes it will work.. cover the hdd with polythene (air tight) and keep the hdd inside the refrigerator - freezer for 4 - 6 hours and try to connect as secondary hdd (not master) in linux os installed computer and try to recover the files.
Aug 16, 2013 | Seagate Barracuda 7200.12 250GB Hard Drive...
My 310gb transend hard disk all foders became shortcut lnk files size shows 2kb,please guide me to recover data?
Hi there,your external hard disk may be infected by virus.Firstly,remove the virus with anti-virus software in your computer.Then you can recover your files from hard disk with third party data recovery software.I have succeed to recover files from hard disk with Tenorshare data recovery.It can recover data after deeply scanning your hard disk to look for lost data.
By the way,you can download a trial version and scan your hard disk for free to preview whether your files can be recovered. http://www.any-data-recovery.com/index.htm
Jun 24, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
My segate 80gb IDE harddisk Board power and header Problem. Please Help me How to recover my data in that hard disk.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Nov 18, 2010 | Seagate (ST980811AS) 80 GB IDE Hard Drive
Hard disk upgrade
I faced the same problem i asked to the ibm people they said that non ibm hdd's are not supporting x3400 servers and they are hanging when we work with non ibm hdds. when I use segate 1 TB sata hard disk the server working fine the only problem is little bit slow for booting and programme running, this not a broblem. so pls use 1 TB sata hdds with your x3400 servers.
Jan 15, 2010 | IBM x3400 Server
Remove the bad sector from samsung sp0411n
Although A format could help it sounds more like you have some bad sectors on the harddrive.
Right click on the drive, select properties, then select the tools menu and initiate a disk check. it will give you an option screen before it proceeds, select the option to scan for a recover bad sectors/clusters. This will write off and mark the bad sectors so they will not be used again. If the problem comes back again soon then your palette media is failing and you should replace the drive.
Good luck and let us know how you make out,
Chris
Jun 03, 2009 | Samsung (SP0411N) 40 GB Hard Drive
My segate 300Gb HDD keeps asking to format it when i recently pluged it into a new computer to transfer data to and it said that the driver didnt install correctly. since then it keeps asking to forma
I'm assuming that this was functioning at one point. If you are using Windows, Right click on my computer and click "Manage" Then go to disk management? Does it see the drive at all. If so, has a letter been assigned? It is possible that the operating system will show the drive even if it can't read the data. Look to see what file system and how it sees the disk having been partitioned. It is possible that your partition table has been corrupted. This can possibly be fixed using a tool like disk doctor or fdisk.
If, on the other hand, the drive is also making funny noises, you may have a mechanical failure on the drive.
May 29, 2009 | Seagate 300GB USB 2.0/FireWire Hard Drive...
160GB SEGATE freeagent external harddisk is not detecting in computer
it seems your hard drive is having problem, just ask your vendor from whom you have purchased the hard drive to help you.
Apr 21, 2009 | Computers & Internet
What to do with unreadable but recognised hard disk segate 400GB
Your Windows Xp bootable CD should have an option called "Format his file system using FAT32" while installing the OS. Use the option to format it. The only prob is that it creates only a single partiotion. After installing windows you can re-partition using a third party software such as Partition Magic(please note that it will not affect your windows installation as you can first re-size the windows drive to a lower capacity and then partition the un-allocated space.
Nov 29, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
After data is recovered, it should be moved to another drive to keep safe. The drive that was recovered has to be reformatted and checked for errors before storing more data.
Nov 28, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Seagate (ST3160827AS) 160 GB Hard Drive Logo
44 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
