Question about Whirlpool GGW9250PL Gas Dryer
I have a whirlpool duet ggw9250pw3 dryer that is working intermittently for a few weeks. When it's not working none of the buttons work and none of the leds light up. If I unplug it for about 5-15 minutes it starts up fine all buttons are operational and will run complete cycles. It eventually stops working after a few hours. Is there anything that will cause the control panel to "lock up" and only cutting power off will "reset" it. If I don't unplug the dryer it stays locked, even if I leave it alone for a few days. If I unplug it and replug without waiting 5 minutes or so it will not work. Only works when I unplugg and come plug it after waiting at least 5 minutes later. I have opened up dryer and checked both connections going from ERC to controll panel and continuity seems fine. What are the chances that the problems is the controller panel? Or is it a problems with ERC? Is there something else that can be causing this issue.
3 Suggested Answers
  • 949 Answers
SOURCE: Whirlpool Duet gew9250 - Control Lock
The most common reason for this type of complaint would be a failure in the user interface board (UI), if the portion of the board has a short circuit across the lock trails it will demonstrate this symptom.
The fix would be to have the UI replaced. Part number is
8558753 Platinum
8558755 Biscuit
8558756 Pewter
The cost for the part alone is around $160.00 plus labor to install.
I know this is not good news. sorry....
Posted on Apr 19, 2010
  • 3074 Answers
SOURCE: how do you replace an idler pulley on a whirlpool
http://www.partselect.com/dryer+inspect-pulley+repair.htm
Posted on Feb 27, 2011
How can I get my dryer running?
You need a new machine control board
Oct 02, 2016 | Whirlpool Dryers
My duet dryer model GGW9250PW3. front loading,won't start.
It is probably the thermal fuse (start fuse) located on the blower wheel it's white about 2" long with two blue wires going to it. Try that first.
Aug 02, 2015 | Whirlpool Dryers
Whirlpool duet dryer GGW9250PW3?
On thing I have learned as a WP tech for some models the service manual does not explain the error code has to be reset to get unit to operate for dryers normally the tech sheet is up in the control panel
Aug 28, 2014 | Whirlpool Dryers
Whirlpool duet dryer model number gga9200lw2 says control lock how to fix problem
follow this steps and fix it. God bless you
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Oct 05, 2012 | Washing Machines
My whirlpool duet dryer will not start , lights come on but will not start none of the buttons work
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 20, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My whirlpool (ggw9250pw3) gas dryer loud squeak
THIS SOUNDS LIKE AN IDLER PULLEY THAT KEEPS THE TENSION ON THE BELT. SECOND CHOICE WOULD BE DRUM ROLLERS.
Apr 24, 2010 | Whirlpool GGW9250PL Gas Dryer
Gas duet. Mod: GGW9250PWO Ser: MR3604435. Front panel under Status: "Control Locked" light is lit..nothing else works, including Control On button. Dead. Can the dryer be reset??
is the other lights DIM(partially lit)?
If so it could be one of the following.
1.) Intermittent ribbon cables between the control board and the Interface board (one with the buttons) Reseat all four cables.
2.) faulty control board.
3.) faulty Input board.
Nov 11, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet dryer
look for a button with lock symbol beside it press and hold button 3-5 secs lock light should go out and control resume operating
Aug 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
Strange issue with my gas dryer and the control panel I am having a strange issue with my dryer. I have a Whirlpool gas dryer, Model: GGW9250PW0; and am having issues with the Electronic Control (mfg part 8558753). Yesterday, I went to go use the dryer and I press the "Control On" button like normal, but nothing happened. I did not get any lights or anything, yet when I open the door, the inside light comes on. I have a similar model washer plugged into the same electric outlet and everything there works fine. After researching the issue out a bit, I took off the toe panel and took off the duct-lint (mfg part W10128606) so that I could reach the wires connected to the dryer thermister and dryer thermal fuse better. I then took the wires off both of those as well as disconnected the sensor wiring harness (mfg part 3406653) and used a vacuum to clean out any lint as well as compressed air to clean off those connectors. I re-hooked all the wires back up and plugged the dryer in. I pressed the "Control On" button and all the proper lights lit up. I then pressed the "Cancel" button to turn it off, unplugged the dryer, and put the duct-lint back on. I plugged the dryer back in and tried the "Control On" and "Cancel" again, and it still worked. I then put the toe panel back on, pushed "Control On", then turned on the dryer using the "Hold to Start" button and everything worked like it used to. Here is the strange issue I am having. I ran a load in the washer and when done, I put in the dryer and tried the "Control On" button. Everything came up, but when I pressed the "Hold to Start", nothing happened. I then tried to press the "Cancel" button, and nothing happened. I could turn the knob and the different lights lit up, but none of the buttons seemed to be working. After holding the "Cancel" button for a few seconds it turned off the panel lights. I then pushed the "Control On" button again and had to press it a few times before the panel lights came on. After a little bit of playing with the buttons and knob, I was able to start the dryer. I stopped the dryer (didn't want to run it the whole time in case something is wrong) and tried to start it again. I can get the panel lights to come on, but it seems like the buttons are sticking and not fully working like they should. I don't want to have to buy an expensive part unless I absolutely need to and wanted to see if anyone can think of anything else that might be going on or that I could try before paying almost $200 for a new Electronic Control, especially if I will still have the same problem after replacing this part like some other people have reported. Thanks!
Jun 14, 2013 | Whirlpool GGW9250PL Gas Dryer
See all Whirlpool GGW9250PL Gas Dryer Questions
Whirlpool GGW9250PL Gas Dryer Logo
225 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
