Question about Protron PLTV3250 32 in. LCD Television
The t.v. just went off while I was watching it. And will not go back on. We changed outlets and unplugged it and plugged it in. there is a switch next to the cord outlet on t.v. and we flipped it off and on and still no change.
    Sergeant:
    Champion:
  • 233 Answers
If you take the tv back off there is a buss fuse inside that will be blown, look around carefully and leave tv unplugged for 48 hours before you take back cover off or it can shock you, or buy new tv. good luck and hope this helps
Posted on Dec 30, 2010
Went to turn on tv switched on plug nothing happening no lights on tv power going to
Either your electrical outlet went dead or the power supply in your television went dead. Verify operation of the outlet by plugging a light or other known-working appliance in and, if that is working, unplug your television for a minimum of one hour, plug it back in, and test. If it still does not operate, it will require further service.
May 12, 2015 | Televison & Video
Screen went blank while still on. unplugged power cord and when I plugged it back in the power on light went green. Problem remains
Resolution:
Follow the steps below to troubleshoot this issue.
Verify that the AC power cord is connected securely to a working wall outlet.
Unplug the power cord of the television from the AC outlet.
Let the television remain without power for 1 minute.
Plug the power cord back into the AC outlet.
Attempt to turn on the television.
NOTES:
If the issue is still unresolved after completing all of the troubleshooting steps, service will be required.
Make a note of the STANDBY or TIMER flash pattern when referring the television to service.
Aug 13, 2008 | Televison & Video
My screen turned blue and I can't change it back.
Try unplugging it from the wall outlet. Press the power button once to release any stored power. Plug it back into the wall outlet and turn power back on to see if this helps. If it is connected to a cable box make sure all the cables and connections are not loose. Check to see if the cable box is loose from the wall outlet.
Mar 31, 2015 | Samsung UN46D7000 46 Inch 3D 1080p Smart...
Frozen screen
Unplug your cable box from the wall outlet. Wait 3 or 4 minutes and plug it back in.....TV should now be normal.
Sep 06, 2014 | Televison & Video
I have had2 tvs this week that suddenly turn off and wont come back on
sounds to me like its a problem with whatever outlet your plugging your tvs into. I would check to see what voltage the outlet is putting out. Good luck.
Mar 04, 2014 | Televison & Video
Hi,Iwas watching TV and the screen went black.No lights on,I unplugged and plugged again but anything happened. My TV is a Toshiba Regza model 42RV530U. Can you help me? Thanks
If there was a popping noise of any kind when the tv screen went black there's a high possibility that one of the fuses in the tv popped and there is no power to the tv. It could also just be the outlet itself and try plugging the tv to different working outlets.
May 24, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
I was watching television when it switched off and went to standby. I now cannot get it to turn back on.
unplug the tv from the ac outlet for about 20 seconds plug it back in and it should work
May 03, 2010 | Televison & Video
My TV won't turn on
Unplug it plug it back make sure it does't have a main switch on it at the bottom. If your a novice call a lg service center.
Apr 25, 2009 | LG 50PC3D 50 in. Plasma Television
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
Hp 1315 all in one
The all-in-one product does not turn on If the all-in-one product does not turn on at all, try the following actions in order to determine the cause:
  1. Unplug the power supply from the wall outlet.
  2. Unplug the power supply from the back of the printer.
  3. Remove the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  4. Wait at least 20 seconds, then, plug in the supply back into the wall outlet.
  5. Plug in the power supply back into the printer.
  6. Press the power button to turn the printer on.
  7. For models that have an external power supply module, verify that the power supply module is plugged in correctly. Some power supply modules have a green LED built into the connector end or on the power supply module. This LED will be lit if power is present. If the LED is not lit, replace the power supply module.
  8. Plug the power cord into a different electrical outlet. If the all-in-one product has an ADF with an external cable plugged into the back of the product, use the following procedure:
    1. Turn off the unit.
    2. Unplug the power cable from the wall outlet.
    3. Unplug the ADF cable from the back of the product.
    4. Plug the ADF cable to the back of the product.
    5. Plug in the power cable to the wall outlet, and turn on the power.
      1. If no change, the problem is not the ADF.
      2. If the problem clears, turn off the all-in-one, unplug the power cable, and reconnect the ADF.
      3. If the error returns, the ADF is defective. Contact HP Customer Care to get the ADF replaced.
  9. Disconnect the computer parallel cable from the back of the all-in-one product and try to turn on the product again. The computer might be grounding out through the parallel port. If this corrects the issue, check the grounding of the computer and outlet.
Jan 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Protron PLTV3250 32 in. LCD Television Logo
49 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
