Question about Maytag SDE5401AYW Electric Dryer
Inteli dry regular cycle, timer gets stuck and won't advance. other cycles work fine. thanks
  • 42 Answers
An unusual noise coming from a running clothes dryer can cause concern, although these noises are rarely indicative of a more serious problem. Once the source of the noise has been located, a few simple repairs or adjustments will usually solve the problem and restore peace to your laundry room.
    Gas
  1. A gas dryer may emit an occasional clicking sound. This noise is caused by the gas valve and is a normal operating sound. The clicking sound coming from the gas valve can not be eliminated and it does not indicate any mechanical problem with the dryer.
  2. Warm Up
  3. A newly installed dryer, or a dryer that has been left unused for a period of time, may exhibit a thumping noise during the first few minutes of the drying cycle. According to the Maytag company, this noise is normal and should not be a cause for concern. If the noise continues for more than a few minutes or repeats on subsequent loads, however, then steps should be taken to locate the origin of the noise.
  4. Clothing
  5. Clothing can become knotted and balled up in the clothes dryer. This can cause vibration or a load thumping noise. When this happens, open the dryer and remove the knotted clothing. Separate the articles of clothing and place them back in the dryer. The thumping noise should not continue unless the clothing has become knotted again.
  6. Vibration
  7. Place your hands on top of the dryer and push down firmly; if the dryer tilts to one side, the clothes dryer is not level. This can cause the dryer to vibrate during the cycle and if the vibration is severe enough, the surrounding walls could be damaged by the dryer. Maytag dryers have four leveling legs installed into holes on the bottom of the dryer. These legs are included with the dryer and should have been screwed into the holes during installation. A wrench can be used to adjust the legs until the dryer is stable and level.
  8. Foreign Objects
  9. Small objects such as coins, buttons, or paperclips can become lodged between the drum and the sides of the clothes dryer. These items usually end up in the dryer after being left in clothing pockets during laundering. Turn the dryer off and remove any clothes to a laundry basket. Allow the dryer to cool down so that you won't burn your hand on any metal surfaces inside the dryer which may be hot. Look inside the dryer and pay special attention to the front and rear edges of the dryer drum. Run your fingers along the grooves where the drum connects to the dryer to locate any foreign objects. These objects could be bouncing around the dryer causing noise during the cycle, and then settling into the grooves when the dryer stops making them difficult to locate. Remember to remove all items from clothing pockets before laundering in the future to avoid this problem.
  10. please comment on these solution on how helpful
Posted on Dec 30, 2010
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
Kenmore 110.60812990 will not stop
if it's not advacing in time dry you have a bad timer,that timer should count down no matter what the dryer is doing,if you have it in auto then it could be no heat,when it's in auto or more or less cycle the heat comes on and the timer won't move until the heat shuts down,when the heat is off timer advances,when the heat starts the timer stops,it will do this until the clothes are dry and then timer will shut off but in timed cycle,timer isn't counting down get a new timer.
Apr 05, 2013 | Washing Machines
Timer won't advance on autosense,seems to work normally otherwise. timer advances fine on all other settings. was thinking it was the cycling thermostat, but the blower seems to be cycling. puzzled
when on auto the heat comes on and then shuts off and then the timer advances,when the heat comes back on the timer stops advancing,when on time dry the timer will advance no matter what's happening with the heat.next time send the brand name and model number so i can help you better,if it's gas you could have bad gas coils,you'll have heat for like the first 15 to 30 minutes then when the coils get hot they fail and no heat until they cool down,also if the vent line and the duct that the lint filter goes into hasn't been cleaned out the heat will shut down and if that happens the timer isn't gonna move.check that out and let me know what you find and send the brand and model number.
Sep 24, 2011 | Roper Dryers
Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Eric
Oct 23, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
Frigidaire Ultraquiet III
hi there,
can you supply me with the exact model # off your d/w please?
Mar 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Timer stuck on cycle will work if manually moved
The timer has a small motor that advances it through the cycles. It either works or it's DOA. unfortunately you probably have to replace the timer complete.
Nov 01, 2007 | Roper RAS8445KQ Top Load Washer
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Aug 31, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Maytag SDE5401AYW Electric Dryer Logo
121 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
