Question about Nikon COOLPIX L100 Digital Camera
Even with brand new batteries camera will take 2-3 pics then stop and say battery exhausted, HELP!
  • 536 Answers
From the reviews on Amazon.com, it is unusual for this camera to eat batteries like this.
I would try to do a "reset all" as described on page 109 of the user manual.
Additionally on page 111 of the user manual, there is a menu selection for the type of batteries that you are using. You can choose from alkaline or lithium. Make sure that you have the type of battery that you are using selected. The battery case will tell you whether the batteries are alkaline or lithium.
If that does not resolve the problem, the I would inspect the battery compartment for any signs of corrosion on the battery contacts.
If the contacts look fine and there is no debris in the battery compartment, then you'll have to take the camera in to a service center to have them figure out what is causing the camera to eat batteries.
Posted on Dec 30, 2010
  • Jeffrey Groves
    Jeffrey Groves Dec 30, 2010
    After further research, I have found that there is a firmware update for this camera that allows for the use of Ni-MH rechargeable batteries. You might try installing the firmware update to see if it resolves your battery eating problem.
    Link to firmware update:
    http://support.nikonusa.com/app/answers/...
Why does my camera keep saying battery exhausted even when I change the batteries?
If batteries leaked in the camera the connections IN the camera may be dirty. Putting in a new battery takes care of the battery connection but not the camera connections. This is why it is very important to take out batteries when you are done taking photos. When you want to shoot again you put the batteries back in and set the time and date. You MAY be able to clean the connections with a pencil eraser. If you use a pencil eraser please blow out the dust from the eraser. If you are positive the camera then I cannot help you here.
Jul 20, 2014 | Nikon COOLPIX Cameras
Low battery
The manual says:
The camera turns off immediately even when battery power is full.
The remaining battery power is low even if new batteries are inserted.
•The remaining battery power may not be displayed accurately, and the camera may suddenly stop working, when the type of battery and the settings on [BATTERY TYPE] are not identical. However this is not a malfunction. Depending on the battery
brand and the operating temperature, or if exhausted batteries are used, the remaining battery power may not be displayed accurately.
and:
Use sufficiently charged batteries when using Ni-MH batteries.
You also should set the correct battery type in the setup menu. So put in alkaline / NiMH or oxyride. According to what you are using.
Before you panic, buy a set of alkaline batteries, to make sure your camera is ok. Perhaps you are using rechagable batteries who are not ok anymore.
Nov 09, 2013 | Panasonic Lumix DMC-LZ7 Digital Camera
Every time whn i insert new batteries, after 2-4 pics camera turn off with warning battery exhausted
Use only Nickel -Hydride battery for your camers.Dont use pencil battery that we are using for remotes ,clock etc
Sep 27, 2010 | Nikon Coolpix 3200 Digital Camera
My Fuji Finepix S5800 tells me my brand new batteries are flat.
It sounds like you have bad batteries. I have had rechargeables that have suddenly done the same thing. I have learned that buying really cheap ones doesn't work out. If you buy a good branded set, I think you will find that they are much better. :)
Jul 17, 2010 | Fuji Finepix S5800 Digital Camera
Camera says "change batteries" even with new batteries
Hi, Has anyone resolved this issue yet, I have a powershot s2 IS with the same issue - i replace the batteries with brand new duracell's and it says replace batteries i reseat the batteries and it works for a few pics if im lucky then says replace batteries again - any help would be appreciated - Canon offers no solution.
Oct 13, 2009 | Canon PowerShot A720 IS Digital Camera
Blurry Photos & Batteries Exhausted
I may be able to help with the battery problem. Two suggestions: 1) With a WHITE eraser (preferably at the end of a pencil) rub the metal tabs in the camera that makes contact with the batteries. They may be slightly corroded. DON'T use a pink eraser. A fine sandpaper will also work, but is more difficult to work with inside a small space. 2) The metal tabs may be pushed in too far. You may need to pry them out with a small flat-head screw driver or needle nose pliers. Do so gently.
GregM23
Sep 07, 2009 | Nikon COOLPIX L12 Digital Camera
I keep getting "Battery Exhausted" messages, with new batteries
you have to use only very good quality batteries ...I have a philips..and if I do not put alcaline quality bateries in it ..it do not even power up ....and even with this expensive ones it eats 'em like snacks...
by the way ...keep the batteries inside only when you shoot cause all this new cameras with display and so ...consumes the batteries even when they are powered off ..
my advise is to buy some accumulators the kind you charge on the home power plug.....so in this way .. you will always have strong power into them ..and the cost its worthily ..
Jun 08, 2009 | Nikon COOLPIX L18 Digital Camera
Says low batteries and shuts off. Batteries are brand new.
1. clean and adjust the springs in the battery compartment
2. use the right batteries, alkaline or NiMH, etc.
this tips may help
Why my camera keeps saying ‘change battery’ even with new batteries?
May 18, 2009 | Panasonic Cameras
Nikon COOLPIX L100 Digital Camera Logo
193 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
