Question about Sony KV-36FS16 36" TV
My tv got dropped when we moved it. now i have sound but no picture and the red light flashed 5 times. am I screwed?
    Top Expert:
  • Sony Master
  • 74,106 Answers
Hello
Five continous blinks of standby light on Sony sets denotes the fault in its [AKB], Automatic Kin Bios circuit. During the fall there must have a break in the printed circuit board, especially on its LOT [Line Output Transformer] side. Just open the TV and check whether the printed circuit board have any cark or any other type of break, whic cause the circuits tracks to open circuted. The above said LOT is a bulky and heavy one, can cause break to that portion, if the fall is hard. Check it. As far as sound is good, its tuner, video IF and most of the other portions are Ok. Just keely check for this trouble I mentioned above. If you need further assistance, feel free to get me through Fixya. Ok.
Posted on Dec 30, 2010
PICTURE ON LCD TV GOING IN AND OUT
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
when your tv blanks out, turn off the tv and then it back on. below the power button usually flashes green light. does yours flash red? if so you need to count how many flashes. the number of flashes will help in resolving your problem. then google red flashing light sony and you will find what the red flashing lights mean.
Oct 04, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony wega kdf-e60a20
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I noticed a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
hope this helps.
Aug 22, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
KDF-E55A20 red light blinks 5 times
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV. if this does not work it is time to replace the bulb.
hope this helps.
Jul 27, 2008 | Sony KDF-E55A20 55 in. LCD Television
Blinking power light
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some research, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
hope this helps.
Jul 08, 2008 | Sony KDF-E55A20 55 in. LCD Television
KDF-E60A20
do this for me turn off tv hit the follow hit this button display,5,vol down, power and till me the error code for this set this a have a
cpu in them ever time the led blink on front of set that mean thear is some pu with tv. so chech it and git back to me with code
thank you. bob..
Jun 12, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
No picture on tv but have sound
how many times it flashes?? if its more than 6 times you have a problem. just lick the red wire that goes to the picture tube.if it does not kill you, you are lucky
Jan 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
KDF-E60A20
hope this helps.
Aug 21, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KV-36FS16 36" TV Logo
152 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
