Sennheiser ew 135-p G2 Professional Microphone
Problem for Sennheiser ew 135-p G2 Professional Microphone
Distortion sound
By raveay on Jul 07, 2008
i buy two senheiser and when on the mic the level of AF is full and sound bad.
Solution #1
posted on Aug 07, 2008
Not Rated)
freak1c
Rank: Wiz
Rating: 83%, 14 votes
turn down the gain at the mic pre, first plug in the mic then put the channel fader at optimum level, the 0 mark, then use the mic gain adjustment at the mic pre to set the level on the channel/ input meter, if recording using a digital platform keep the level as high as possible without going into red at all on the channel/ input meter, use the master fader to adjust listening volume and use the channel fader to make fine adjustments if needed but the point is to primarily use the mic gain knob to adjust the input level. If you are recording a loud instrument or cabinet with it then you may want to use the pad on the mic or the pad on the console/ mixer if after going through the above steps the level at input is still too hot, should be a switch on the mic or console wich says pad, if the mic has one then use the one on the mic instead of the one on console.
Was this helpful?
Yes
No
Popular Solutions for Sennheiser ew 135-p G2
Questions and Unsolved Problems for Sennheiser ew 135-p G2
Do you recommend Sennheiser ew 135-p G2 Professional Microphone?
Answer
Answer
i have a telex pro star body pack..ug12 can i get a new one
Answer
Hi, I have an MK5 Magic Mike and when I plug it into the T.V, the screen is just green and it is... (More)
Answer
Hello, I have an MXL 9000 tube microphone w/ power supply. When I turn the mic on, it sounds normal,... (More)
Answer
how spesial price for sennheiser EW 135 PG2? and where we can found it? particularly in indonesia.
Answer
I have this same mic and last night was the first time I used it and all night it kept making this... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microphone Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
