Dear Experts, My Air con is not working, cant be turn on, there is blinking on the power . Tried to cancel the timer, it didnt work. Thanks Sri
  • 2,133 Answers
To cancel the timer remove batteries in remote and reset it. and also reset the power with a/c unit. now you can operate with your remote.
Posted on Dec 30, 2010
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Blinking power light
Make sure voltage and polarity is good
Dec 17, 2013 | LG Heating & Cooling
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
My panasonic airconditioner c9kkzw timer is always blinking and automatically turned off every hour. its driving me crazy becasue my kids won't asleep.. please please help me, tried turn and off but to no...
I think, you have set the timer for one hour. No problem, remove battery from remote and reset it and same way isolate the power to your air conditioner for 5 seconds and reset it. Now all pre programmed would have been canceled. Now you can set your temp as you like.
And another reason may be your compressor getting heated after an hour, due to dust blocked in your out door coil. Hence, please serive the unit at once. Thanks.
Dec 15, 2010 | Panasonic CS-A12C Air Conditioner
I have 2 units of 2 hp mitsubishi split type air-con. both units are having problem with timers. the timer will blink after 20 to 45 minutes of operation and then it will turn off by itself but the light...
the timer may have been activated at installation or by someone not fully conversant with the operation
use the remote and follow the instructions in the owners manual to turn the timer off
Sep 06, 2017 | Mitsubishi MSZ12UN Air Conditioner
Timer set on remote, cancels out after use
I have discovered that a 7 day timer is available, but it is a fixed and separate box and will need to be programmed into the wall unit, at a cost of $500.As i am a pensioner and unable to afford this cost, I must persevere with the remote I have. Why can't the so-called experts provide a top of the line product in the first place?The last aircon unit I had was a Fujitsu, and that DID Have a very good remote enabling a programme of ON - OFF, On - Off in a 24 hour period. Thanks for trying to help.
Apr 21, 2008 | Heating & Cooling
Program timer light blinking
The timer light blinks when the AC power has been disconnected and the clock is not set. This is how the set warns you that it can no longer do timer recordings. Setting the clock and doing an autoprogram will fix it, but both the remote and the remote receiver must be working. If the original remote is not damaged and has good batteries in it but does not work on that set and you cannot get any other universal remote to work, then the remote receiver (the IR "eye") inside the set has failed and needs to be replaced. I have seen many of those little receivers failing recently. If you do not have experience changing electronic parts on small PC boards then have a qualified tech change it for you.
Jul 26, 2007 | Panasonic PV-DM2093 Triple Play 20 in....
Heating & Cooling Logo
222 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
