Question about Frigidaire GLEB27S7A Electric Single Oven
Oven only goes to 175 degrees - Frigidaire GLEB27S7A Electric Single Oven
  • Frigidaire Master
  • 43,501 Answers
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Dec 30, 2010
How do I remove the sabbath function on my gas range
sadly without knowing a make , there is not much I can look for.
has to be something to do with the clock I would suspect
Oct 23, 2016 | Ovens
Gas Pizza Oven - Heat issues
Many of the Pizza ovens require ceramic plates that line the bottom surface of each oven. These ceramic plates absorb the heat and retain the temperature. I never used our ovens with a bare lower surface, always applied the plates for even heat and distribution.
Mar 05, 2014 | Ovens
The lowest setting on the dial of our Imperial oven is 175 degrees F. If we set the dial below the 175 mark, could we get the oven to level out at a lower temperature? We're looking to achieve a stable...
The temperature figures on the dial are a guide only. Play with the dial, you will pick up where the thermostat cuts in and out. 130 deg. is rather low, but it could be achievable. You will only find out through experimentation - nothing will be damaged.
Jan 31, 2011 | Imperial ICV-1 Turbo-Flow Single Oven
It takes 28 minutes for the oven to reach temperature of 375 degrees. The ready buzzer goes off in about 15 minutes. The temperature is 300 degrees. Is there any adjustments to be made.
what is your oven if is gas or electric, if is gas easy to preheat by using lower heating element, if electric? that your unit have convection? or not? coz some probelm of the oven is, 1 if the oven is no convection or your oven is single heating in upper element,if your oven have a timer and cut off in 15minute? dont use timer,use a manual timer by it your self,if you want to reach the degrees that you want check your oven if der a lower and upper heating element with convection function,that the one is the most easy way to reach the degree that you want to reach.
Dec 17, 2010 | Ovens
If my grandmothers cookbook says to bake something at 175 Celcius, what is that in farenhite?
175 degrees Celsius is equal to 347 degrees on the Fahrenheit scale.
The conversion formula is
Fahrenheit temperature = (9/5 x Celsius temperature)+ 32
http://www.trueknowledge.com/q/what_is_175_degrees_celsius_in_fahrenheit
Good Luck
Nov 22, 2010 | Ovens
My jenn-air self-cleaning electronic wall oven model w131 is heating up very slowly. It took 1.5 hours to get to 175 degrees.
One of the 2 hot wires is out. Flip (hard) the oven circuit breaker to the off position, and then back on. If it did not help - verify 220-240v between the two hot wires on the terminal block behind the electronic control. If there is less - call electrician.
Oct 13, 2009 | Ovens
Oven heats to 200 and indicator dings
Try to set it at 500 degrees and see if it goes off at 350. If it does, then it probably needs calibrating. You can calibrate it by taking the knob off and finding a set screw in the stem where the knob sits. If this is not the problem, you may have to replace the thermostat. By the way, check to see if your temperature probe is not touching the wall of the oven. It will give it a false reading. Let me know if any of these things work and we will go from there.
Jan 29, 2009 | Whirlpool RBS245PDS Electric Single Oven
Upper oven not working
thismay be caused by a few issues, either the bake elemnt has gone bad, or a high temp thermo has gone bad not allowing element ot come on.. have to remove the oven from the opening and acces t he rear panel to check either
Nov 25, 2008 | Ovens
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Frigidaire GLEB27S7A Electric Single Oven Logo
79 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
