Question about EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18)
There is no booting , just a black screen without any mark about the problem
  • EliteGroup Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Dec 30, 2010
  • Mohamed Salah al-Din Dec 30, 2010
    thank you very much bronk50
    but i have changed the PSU
  • Brian Sullivan
    Brian Sullivan Dec 30, 2010
    only glad that i could help
    happy computing 4 u
W701 ds black screen
It should work without a battery just a good power supply plugged in.
Jan 09, 2016 | IBM Lenovo ThinkPad W701ds 25003CU...
When i sign on i get error message specified module cannot b found referring to c program system menu dll can you help
On Start, type in "cmd} without the quotation marks. A new backdoor screen with open... it's black, don't worry. type in "chkdsk/f" without quotation marks. and hit Enter on the keyboard. The computer should repair itself for you... be patient, it takes time. Re-boot and it should be fine.
Oct 01, 2014 | Gateway Computers & Internet
My laptop keeps locking up. What can I do
Boot in "safe Mode" using the proper function key for your Gateway... usually F6. Just old it down when booting up until the safe boot screen appears. Select "Safe Boot with Networking". At "Start" type "cmd" ... a new screen will appear, type in "chkdsk/f" without the quotation marks and wait until your PC fixes itself, be patient. Reboot and it should be fine!
Jul 10, 2014 | Gateway Computers & Internet
,my lg p970 cannot boot. it simply shows lg logo and flickering lights on menu buttons...what seems to be the problem?
Hi let me introduce my self, I am (BRYAN).
to solve this problem. Remove battery from phone keep aside then connect charger to phone and power on let the phone display a battery with an ! mark over it then remove charger and replace battery and switch on. You are done. (bryan.ryle@gmail.com)
Nov 29, 2012 | LG Optimus Black Smartphone
My evo does not run bios
Maybe you have a Static Charge Buildup. Remove thePower Cord, then Press and Hold thepower button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots. Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 04, 2012 | Computers & Internet
Why screen is black out.
On my Windows 7 laptop, I got problem of Black Screen of Death, Windows Boot Genius fix the problem without data loss! I vote it!
Jan 26, 2011 | Computers & Internet
Dell Inspiron 1545. When booting to vista the screen goes black. When booting to safe mode the screen works normally.
Please reinstall the Video Driver and check if the same issue persists. If the issue started within last 90 days, you can try the System Restore
Jul 01, 2010 | Computers & Internet
I need to purchase an internal power unit for my Philips LS1400 - how can I find out the technical specifications for the unit?
1. Load the first system recovery disk into the CD-ROM drive
2. Press R for the recover console
3. Press Alt + D to bring up the command prompt*
4. at the C:\minint\system32> prompt, type "del h:\hp\bin\configcheck" (without the quotation marks) and press Enter
5. At the "Are you sure?" prompt, type "y" (without the quotation marks) and press enter
6. At the prompt, type "exit" (without the quotation marks) and press Enter
7. Press Alt + Q
8. Press Q to quit the Recovery Window (The PC will automatically begin to boot. You should now be free of the Vastly Evil Code Purple.)
*I have found that there is no need to Select "Advanced Options" prior to pressing Alt + D.
Procedure to recover from "Code Purple" WITHOUT a Recovery Disk Set:
If the Recovery Partition on your hard drive is intact, this should work:
1. Turn on PC and repeatedly press F10 (pause for a second between key presses) until the Recovery Screen comes up
7. Press Alt + Q (The PC will automatically begin to boot. You should now be free of the Vastly Evil Code Purple.)
Jul 24, 2009 | Computers & Internet
Turn on goes to black screen
Can you access F10 bios - if you can access bios you have a hard disc failure - remove you hard drive - boot the system without the hdd and see if the pixie boot boot goes through - seen it before - your hdd is unservicable.
May 16, 2009 | Computers & Internet
After downloading windows xp service pack 3: screen turned black boot failure/won't bootup without CD old files missing screen flickers hardware missing
you will have to restor it to factory stetings there is nothing else i can think that you would be able to do
please rate my help to you
thank you.
Apr 22, 2009 | Computers & Internet
EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18) Logo
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
