Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
I have the same problem. The wireless printer can't be recognized on the network even when plugged in via USB and the buttons are frozen. Have tried reinstalling multiple times. Now I'm dead in the water.
  • 1,218 Answers
In this situation your wireless printer might require a power reset before you print each document. Though the printing activity will take place efficiently you will have to physically go and power the printer to enable it to print. This problem might require you to reload the firmware of the router and set the wireless printer to manual IP address in order to make it work seamlessly no matter how many documents you have to print.
Posted on Dec 30, 2010
    Genius:
  • HP Master
  • 1,274 Answers
Run this http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-77759-1&lc=en&dlc=en&cc=us&product=3795406&os=4063&lang=en
then run this: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-74066-3&lc=en&dlc=en&cc=us&product=3777182&os=4063&lang=en
should clear up your problems :) good luck!
Canon PIXMA MG6320 works via USB but not wirelessly
first you must have a links sys.
go to your control panel on your computer and go to view network
status and task, there you can see if your are connected if not set up a new wireless connection.
Mar 05, 2014 | Canon PIXMA Office Equipment & Supplies
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
Linux driver
Printing via USB:
  1. Get the samsungmfp- repository.
  2. Install samsungmfp-driver (samsungmfp-data will be installed automatically as a dependency).
  3. Go to Administration > Printing and delete previously created printer device(s).
  4. Connect printer via USB.
  5. Once new device has been created, go to Properties and change the Make and Model to Samsung SCX 4521F All-In-One.
For wireless printing:
  1. Connect to your printer. To get the IP address of your printer:
    1. Hold down on the printer power button for about 5 seconds; light will start to flash and when it begins to flash even faster let it go. This will print out the Configuration and Network Report.
    2. Locate the IP address on the Network Report and type it into your web browser.
  2. Once you are in the SyncThru Web Service, go to Network Settings and than to Wireless.
  3. Configure your Wireless Setting through the Wizard and follow the setup process (note that if your SSID contains space your network will not be displayed).
  4. Once the printer is connected to your LAN go to printer setting (Administration > Printing; Properties).
  5. Click the Change button for the Device URI.
  6. Go to Network Printer > Find Network Printer and type in the IP address of your printer.
  7. Apply the settings when it find the PASSTHRU. Device URI should looks something like this: lpd://[IP Address]/PASSTHRU.
Nov 04, 2013 | Samsung SCX 4521F All-In-One Laser Printer
My lexmark x6650 printer will not connect back online
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via USB cable to your computer, simply disconnect the printer from your computer, reboot your pc and unplug/re-plug the printer into the power source to reset it. When everything turns back on, reconnect the printer into the pc. Wait for the computer to fully recognize the USB connection. Try to print again.
If you're printer is wirelessly connected to your computer through your wireless network, please refer to this article for a more comprehensive instructions on how to identify and fix the communication problem - Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 06, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Lexmark all-in-one x4690. I am trying to set it
Turn on the wireless on printer , Go to printer option in control panel , Clicked on add printer , Then click on wireless and bluetooth device , Let the wizard detect the printer, once detected put the disk and run software installation Post reply if you need any help, You can contact me for any help +91-9958531192
Chandan
Sep 10, 2009 | Office Equipment & Supplies
Can't seem to print thru wireless network anymore.
Follow the instructions in this document for setting up your printer in a wireless environment.
Aug 31, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Canon MP620 is not recognized by PC
Make sure you do not have it plugged in before you start the install. Also for the next install attempt, plug the cable in to a different USB port than the one you;ve previously tried.
May 23, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Lexmark X4850 wireless how to make it find the wireless network. I've had this printer working with my Vista laptop till recently; then I moved to another area, configured my new home network and Internet...
If the printer itself is wireless, it does not need to recognize your wireless computer network. Call Lexmark to walk you through proper installation. Lexmark's manuals are not adequate regarding setup, in my opinion.
May 07, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
How to wirelessly access HP Laserjet 1320n via Apple iBook
You need to disconnect the USB cable and set it up wireless on both units:
Since it is plugged into the router, it should already have an IP address.
Un-install the printer from the computers.
Then re-install the printer from the cd or from HP's website. When you get to the point where it ask you is the printer is attached to the computer or is it over the network. Choose over the net work and the software will find the printer IP and finish setting it up wireless.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | HP PhotoSmart 1215 InkJet Printer
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
85 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
