Question about Canon Office Equipment & Supplies
Hello, I have a canon pixma printer iP1500 and it has been working fine until yesterday. I keep getting a paper jam message but no paper is stuck. Then the paper will go in off sided and the paper does not go into the printer. What do I need to do to fix this?
  • 1,218 Answers
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Posted on Dec 30, 2010
My Canon ip2600 keeps getting jammed. It takes
Lol!!! I was having the same exact problem--- looked in it, didn't see a thing, opened it, still didn't see a thing! I turned it over-- and sure enough, a pen fell out!! lol
Jul 21, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Printer cannon ip1500 says paper jam
just open the catridge cover and remove all the catrdiges and check is there any pices of paper is stuck inside.
Jan 21, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Ip1500 showingjam when there is no jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 12, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Paper jam showing when no paper in the printer
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 06, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Keep getting a service error 5100 notice
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 21, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Canon PIXMA paper jam
Hi there ok gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Mar 16, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma iP1500 printer indicates paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 22, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Pixma ip1500 permanent paper jam-with video showing
the problem is with the software of your printer.. here's what you should do.. install back your printer, and then turn on your computer.. press ctrl + shift + escape.. this will open the task manager.. on the task manager, look for spool.exe and end its process... afterwards, try to reboot your computer.. i just hope this will work.. and please don't disassemble your printer again.... if this won't work, send your printer back to the manufacturer and they will have it fixed for you.. ok?
Jan 23, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
PRINTER CANON PIXMA IP1500
your printer maybe long period of time does not use , the head already dry , replace w/ " original canon ink" not a generic.
Dec 28, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
108 people viewed this question
old marine
old marine
