Question about Toshiba E-STUDIO 450 Copier
Freezes when we turn it on. It was working, no changes to network but when it try to ping the IP address from another machine it times out. any ideas on how to reset this without having to call a technician or any other ideas. No error messages are shown except Please wait and Network Initialising
    Problem Solver:
  • 5 Answers
This problem is due to lose conection at controler board.
Turn unit off, reach the board where a lot of wires coming to, then unplug and plug back each one of them. Notice that each connector have to be set right, you will feel it in your finger at plugging back.
Do the same with the ribbon cable. Turn it on and let it reset. There is NO major problem but a lose conection, be glad!. If you wonder where is the controller board, most likely you will have to take of a plastic or metal cover to expose it. Good Luck!!
Keep me posted. JORGE
Posted on Dec 30, 2010
Problems big problems
Verify that TCP/IP (or other appropriate protocol) is properly installed.
  1. Open Control Panel and open Network Connections or Network and Sharing Center, then click Change adapter settings. The wireless card should be present as Wireless Network Connection.
  2. Right-click the appropriate Wireless Network Connection and select Properties. In the Properties window, make sure that the Internet Protocol (TCP/IP) or Internet Protocol Version (TCP/IPv4) is installed.
  3. If TCP/IP is not installed, click Install, click Protocol, and then click TCP/IP.
  4. Once installed make sure that Obtain an IP address automatically, and Obtain DNS server address automatically are checked (if using DHCP). To verify this, highlight the TCP/IP protocol, and select Properties.
Note: Only use a Static IP Address if your network/Service Provider requires one.
8.Verify the TCP/IP address.
  1. Click Startwindows%20start%20button.png, select All Programs, select Accessories, and then click Command Prompt.
  2. Type the command, ipconfig. This will list the IP address for the local machine.
  3. If this returns a 169.x.x.x or 0.0.0.0 address, then type the following commands;
    ipconfig /release and then
    ipconfig /renew.
    You should then receive a TCP/IP address appropriate to your network, along with a Default Gateway address.
  4. Try to communicate with it by typing this command ping x.x.x.x where x.x.x.x is the IP address of the Default Gateway. (i.e. ping 192.168.1.1)
  5. If this does not give a reply (see the example in step 9) or you did not receive a TCP/IP address, go to the next step.
  6. If you are connecting wirelessly, but receiving an IP address, your wireless router/Access Point might need to be reset (unplug power for a minute, then plug back in), or maybe defective. Please consult your wireless router/Access Point manufacturer for further assistance.
9. Ping the loopback address.
  • Click Startwindows%20start%20button.png, select All Programs, select Accessories, and then click Command Prompt.
  • Type the command, ping 127.0.0.1. This will send a message to the internal network stack on the machine. You should see a response like this:
    Pinging 127.0.0.1 with 32 bytes of data:
    Reply from 127.0.0.1: bytes=32 time<10ms TTL=128
    Ping statistics for 127.0.0.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milliseconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
  • If instead, you receive errors, then there maybe system corruption or malware installed preventing networking from functioning properly.
  • 10. Verify that the hardware is functioning using diagnostics.
    • Check the web site, http://support.lenovo.com. Choose Download Drivers and Software and enter your particular system. Then under Diagnostic choose the download for your system. If diagnostics fail, please contact warranty support for resolution.
    • Run diagnostics for third party wireless card.
      Note: If using another manufacturer's product, then consult it's documentation on how to run the diagnostics for the wireless card.
Mar 10, 2014 | Lenovo ThinkPad R60 with Wireless Wide...
Tip
Printer IP Address Lookup
<span></span><b>Need assistance in looking up for your printer's IP Address?</b><br /><br /> Often times we see a networked printer suddenly stop working and you need to find a static (private) ip address of the printer to diagnose further. How do we find IP address of a networked printer? There are a few different ways to go about finding it. <br /> <br /> 1. A network printer with built-in ethernet port usually provides a menu button that will allow you to display IP address assigned to it. You may also try printing self test or configuration page from your printer. <br /> <br />2. If you can't find an IP address of a network printer from the menu display or your printer is connected to a printer server with no display, you may find its address from any networked computer configured to use the printer. To find the printer IP address from a Windows machine, perform the following. <br /> <ul> <li>Start -&gt; Printers and Faxes, or Start -&gt; Control Panel -&gt; Printers and Faxes <li>Right-click the printer name, and left-click Properties <li>Click the Ports tab, and widen the first column which displays IP address of the printers </li></ul> 3. If your networked printer uses DHCP, you may connect to your router and find the IP address of the printer from DHCP status page. The router displays all host machines that are assigned dynamic IP addresses. <br /> <br /> 4. You may also try pinging your network from a computer connected to the network, and lookup an arp table. On your computer, click [Start] -&gt; [Run...] and type "cmd" and [Enter]. Type "ipconfig" to find your network address. The network address is found by performing a logical AND operation on your IP address and the subnet mask. For example, if you IP is 192.168.1.101 and subnet mask is 255.255.255.0, then the network address is 192.168.1.0. Ping your network using a broadcast address, i.e. "ping 192.168.1.255". After that, perform "arp -a" to determine all the computing devices connected to the network. One of the IP found is your networked printer. <br /> <br /> 5. You may also use "netstat -r" command to find an IP address of all network routes. However, if your printer has problem communicating with other network devices, you may not be able to find IP address of the printer using "netstat" command.
on Aug 05, 2011 | Office Equipment & Supplies
Where do i find the ip address for my lexmark z705 printer
This may help.
How do I find IP address of a network printer?
  • Start -> Printers and Faxes, or Start -> Control Panel -> Printers and Faxes
  • Right-click the printer name, and left-click Properties
  • Click the Ports tab, and widen the first column which displays IP address of the printers
4. You may also try pinging your network from a computer connected to the network, and lookup an arp table. On your computer, click [Start] -> [Run...] and type "cmd" and [Enter]. Type "ipconfig" to find your network address. The network address is found by performing a logical AND operation on your IP address and the subnet mask. For example, if you IP is 192.168.1.101 and subnet mask is 255.255.255.0, then the network address is 192.168.1.0. Ping your network using a broadcast address, i.e. "ping 192.168.1.255". After that, perform "arp -a" to determine all the computing devices connected to the network. One of the IP found is your networked printer.
Thank you for choosing FixYa! have a good one!
Aug 05, 2011 | Lexmark PhotoJet Z705 InkJet Printer
I have by cannon 6570i moddel ihave continew error {chek the network conection chek the tcp ip the defalt key is curruptedor invelid}
1) Select the following service mode COPIER>TEST>NETWORK>PING, and select PING.
2) Enter the IP addressof your PC using the numeric keys on the control panel, and press OK.
3) Press the start key.
- OK is displayed if Ping succeeds, but NG is displayed if it ends in failure.
Perform this procedure only when connecting the machine to networks.
If the machine fails to be connected to networks, any of the following causes is probable.
a. Connection failure between networks and the machine
b. TCP/IP setting failure of the machine
c. User network failure
d. Main controller PCB failure
The detailed check methods are as follows.
Checking with Loopback Address
you can check whether TCP/IP settings of
the machine are appropriate by executing Ping with this address.
1) Enter the loopback address (127.0.0.1) in PING.
- If NG is displayed, check TCP/IP settings of the machine again, and re-execute Ping.
- If OK is displayed, perform the next check.
Checking with Local Host Address
The local host address is the IP address of the machine. Since the local host address returns in response to the network controller by executing Ping with the address, you can check whether the network controller (main controller PCB) is in a normal condition.
1) Enter the IP address of the machine in PING.
If NG is displayed, take the following actions, and re-execute Ping.
- IP address error of the machine: Check to see again if the IP address settings of the machine are appropriate. Ask the system administrator whether the allocated IP address is valid.
- Failure in the main controller PCB: Replace the main controller PCB
If OK is displayed, a cause may be user's network environment. Inform the system administrator of the current situation, and ask for measures.
Apr 16, 2011 | Canon imageRUNNER 5570 Copier
My printer is not communicating with my network? I have tried to ping the IP address several times and it results in timed out. HELP, How do I reset the IP address in the system. I had to replace our...
Go to Additional Function > System settings > Network Settings > IPv4 Settings >
* IP Address
* Subnet Mask
* Gateway
Or you can turn ON the DHCP on the machine, Additional Function > System settings > Network Settings > IPv4 Settings (you can explore on these menu). Once the machine has detected an IP Address, turn OFF the DHCP. View the IP Address and use this during installation of the driver to set the Port.
Nov 01, 2010 | Canon imageRUNNER 1023iF Black and White...
I changed internet providers and now my wirless printer doesn't work
STEP1: Print "Network Configuration Page"
  • Make sure paper is loaded.
  • Push the Setup Button on the all-In-one.
  • Use the Down Arrow key to highlight the Network menu.Push Ok
  • Push Ok again to select View Network Settings .
  • Push Ok again to select Print Network Configuration page .
  • A network configuration page will print.
STEP 2: Check the Printer Connectivity
  • From the printed Network configuration page, note down the printer IP address, (example : 192.168.1.6).
  • Click start, and then click "RUN".
  • In the RUN box, type "CMD" press OK.
  • In the command screen, type "Ping IP address" (Example: Ping 192.168.1.6). Hit Enter.
  • You must get output similar to below.
Pinging 192.168.1.6 with 32 bytes of data:
Reply from 192.168.1.6: bytes=32 time=1ms TTL=64
Reply from 192.168.1.6: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.1.6:
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
STEP 3: Configure Port.
  • Click on start >> Control Panel >> Printers and Faxes.
  • Right click on printer icon, select "Properties".
  • Click the PORTS tab on the top.
  • Select your product under the Printer column, and then click Configure Port . The Configure Standard TCP/IP Port Monitor dialog box opens.
  • Look in the Printer Name or IP Address box. This value should match either the MAC or IP Address on your network configuration page. If the values match delete the printer and install it again.
  • If the values does not match,Click inside the Printer Name or IP Address box, and then type the appropriate value (IP address / MAC address) as listed in network config page.
  • Click OK , and then try printing again.
Regards
Riztech
Mar 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printer communication error
check the network cable... disconnect the network cable and ping the copier... if you can get the copier IP address to respond... then you have an IP conflict... if you plug the network cable back in... turn the copier off and on and still cann't print from any pc... then reset the copier... if you still cannt print from any pc then you need to try changing the IP address... and try again... still doesn't work... change the network cable and try again... still doesn't work... plug a laptop into the network cable and ping the laptop... if the laptop works... the print card is bad...
Dec 12, 2009 | Canon imageRUNNER 7200 Copier
Networking 2 windows 7's
Make sure that you have a good subnet mask as well, such as 255.255.255.0. Also set your router IP address at 192.168.111.1 and try to ping it with the ping command in DOS. If you get the the router but not to the other machine, try pinging from the other machine to the router and troubleshoot that way. Next go to your router's interface at the router's IP address and check to see if the router sees the computers. If not reboot the router and check again. If that doesn't work, reset the router to default setting and do the setup from scratch and restart each machine again and check connections. It oftentakes patience, but you'll get it. If no, luck, try another router and one machine at a time.
Sep 16, 2009 | VMware Workstation 4.x (WS4-ENG-W-CE) for...
Cannot get on the internet ,network adaptor is not working
First you want to make sure that you network adapter is truly not working and if not what part of it isn’t working.
First we need to check some settings. Open the start menu and then network connections, then show all connections. Some computers have been configured with out this option set, so to get to the open the “My Network Places” the on the right hand panel click “View Network Connections”. Insure that the network adapter that you use to connect to the Internet is enabled. If it is then we will move on, if not then double click the icon and it should enable the adapter (check to see if you can connect to the Internet).
Moving on, open the start menu and click the run button. In the box, type cmd.exe and hit enter. At the command prompt we will enter some commands to find out where the problem is. First type “ipconfig” and hit enter. If your IP address (the first IP address listed) is ok (anything not starting with 69) then that part is working on and we will have to move on. Next type “ping 127.0.0.1” and hit enter. This tests your operating system to see if it’s working. If you get a response then the problem isn’t your OS. If you get an error then we will need to trouble shoot that later. Now type “ping” then your IP address; this tests your network card to see if it’s working correctly. If you don’t get an error then you network card is working. The last command will test your network, type “ping” then your default gateways IP address. If you don’t get any errors then your problem might be with the network configurations in your router or you ISP.
If your IP address starts with 69 the there is something wrong with the way your computer is getting its IP address from your network. One easy way to fix that is to force it to accept a different on. In the “view my network connection” box, right click on the network adapter icon the properties. In the center box, scroll down to the internet protocol (TCP/IP) and highlight it the click the properties button. In the following box select the “use the following IP address” button. In the IP address area type “192.168.0.1” then hit tab and enter “255.255.255.0” the click ok. Now go back to the previous box and click the “obtain an IP address automatically” and click ok. Now try to connect and see what happens.
If you received an error from your ping test (127.0.0.1) then you need to reinstall the TCP/IP stack. To do that, all you need to do is highlight Internet Protocol (TCP/IP) and click uninstall. Then click the install button, locate the Internet Protocol (TCP/IP) and then click install. Try to connect and see what happens.
If you received an error from your ping test (your IP address) then you can assume that your network card is bad and should buy a new Network Interface Card (NIC) at your local computer store. To install it, turn off your computer and you remove the screws (or push a button on the back of the computer depending on you computer). If you’re looking at the back panel it should be on the left side. The card should snap into place and install automatically. You should install any drivers that came with the hardware to make sure it operates properly.
If you got an error from your ping test to the “default gateway” then you network hardware is having problems. Try unplugging everything plug it back in. You need to make sure that you plug the modem in first and insure that all the lights turn green before you plug your router back in. If that doesn’t work you will need to replace your network hardware.
The last thing that it could be is your firewall. For that you may need to contact the manufacture to get proper configuration information.
If you’re still having problems, post a comment.
Good luck,
Eryk V
Mar 21, 2009 | Compaq Computers & Internet
Driver installation software can not locate image runner 5000 on network
Normally when you change a IP adress you just have to change the last digit.....
Mar 26, 2008 | Office Equipment & Supplies
73 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
