Question about Akai Mpc1000 Music Production Center
Hi, i currently have a mpc 1000 the black edition and i have the new pads. Everything was working ok and one day I powered up my mpc and the pad was working for around 5 seconds and then it seems to trigger a pad automatically and there is no more respond from the pad. Everytime that I powered up my mpc, the pad works for 5 seconds and then become stuck. I tried to reset the mpc to the factory state and it didn't work. What i should do to repair that? thx
4 Suggested Answers
Hugh fulton
  • 62 Answers
SOURCE: I can't get my mpc 1000 to play chopped samples on
Have you checked it out from the manual. If you have get in touch with www.akai.com and ask them. they are the manufacturer and YOU ARE THE CUSTOMER.
Good Luck
Posted on Sep 13, 2009
  • 1138 Answers
SOURCE: mpc 1000 beginner
Here is an excellent source of info:http://www.mpc-forums.com/viewforum.php?f=15 Consider joining and posting any questions you have. Forum members are happy to help and have usually had the same problems at one time or another.
Posted on Jan 21, 2010
  • 1138 Answers
SOURCE: My MPC play back something entirely different from
Here is a link that may help you:http://www.akaipro.com/tipsmay09 Here is a link to the latest updates, manuals etc:http://www.akaipro.com/mpc2500
Posted on Oct 25, 2010
Some keys on mpk49 do not play unless hit hard
sounds like dust, if you know some one with an air compresser ask them to give it a blow through, if not then it is down to caned compressed air, if that is not enough, you need to open it, and clean the contacts (DVD cleaner is cheap and good)
Aug 29, 2014 | Akai Mpk49 Mpk 49 Midi USB Keyboard With...
How to fix usb port on keyboard controller
I am assuming that you broke the connector off the pcb board? you need a soldering iron about 30W and solder and flux, to remove and short circuit after you solder them back on, using a magnifying glass to make sure none of the 5 termnials are shorted
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Mpc 1000 loud static
Maybe try adjusting the MASTER level?
Good Luck
Other settings
Adjusting the master level You can adjust the level of the headphone and the stereo out by turning the MAIN VOLUME knob. The MAIN
VOLUME changes the analog signal level. This will also adjust the entire level of the MPC1000 digitally.
01. Press the [MODE] key and then the [PAD 10] (OTHER).
It switches to the OTHER mode.
02. Press the [F1] (GLOBAL) key.
The GLOBAL page will be displayed.
03. In the Master level field, set the level.
You will set the digital signal level, which will be sent out to the DA converter. The MPC1000 can output up to
32 sounds simultaneously. There is the great difference in the level when you play single sample and play 32
sounds. If you increase the value in the Mater level field, you can increase the entire level of the MPC1000 to
create more powerful sound with less noise. However, if you playback many sounds at the same time, the
level may be overloaded, which may cause distortion. If you decrease the value in the Master level field, you
can prevent distortion when you play many sounds at the same time. However, you cannot have a good
result in respect to the noise or punch of the sound. Set the appropriate value in the Master level field
depending on the application.
Mar 31, 2014 | Akai Mpc1000 Music Production Center
Which system do I need to be able to trigger loops/textures/pads from the lower 2 or 3 strings of my guitar (kinda like one finger accompaniment on cheap keyboards), while soloing on the higher strings?
You could hook the output of the GR33 to something like an AKAI MPC (http://www.akaipro.com/mpc) assigning different notes to trigger different samples or sequences.
Sep 19, 2011 | Roland Gr33 Guitar Synthesizer
My dd55 work well if i play gently and simple. But if i play something more complicated, then, after a few seconds, it restart power. It look as there some problem with polifone tones and power. Adapter,...
Whatever is the problem is probably vibration sensitive. The adpater connections are notorious and you would have to use test equipment to verify they are OK. Looking at them you cannot verify they are OK. Try to see if the display blinks right before it stops. If it isn't the connections, then it is possible one of the buttons is marginal and is vibrating down and restarting. Instead of complicated stuff, just do everything on one pad at a time to see if you can create the problem. Try different pads as the vibration may need to be neaar a particular point. Myself I would open the unit and inspect for loose wires etc.
Jul 09, 2011 | Yamaha DD55 7 Pad General MIDI Digital...
Hey, I have had used the Roland PD8's for a while but recently 2 of mine have just stopped working. Maybe I hit them too hard but I'm not sure because the rest of my pads work. One will work if I hit it...
Check the connections on the undersides of the pads--they sometimes get loose as the vibrations rattle them around. Tighten the nuts that hold the pads inputs in place and reinsert the cables until they sort of "click." If that doesn't work, it might be the cables themselves, so try switching them with one you know is currently working. It'll change which sound is triggered where, but you'll know it's just the cables that need to be replaced, not the pads.
Feb 18, 2011 | Roland Pd 8 Dual Trigger Pad
I NEED TO KNOW HOW TO SET UP MY ROLAND JUNO D WITH MY AKAI MPC 1000, PARTICULARLY HOW TO SET UP THE MIDI ON THE ROLAND.
Simple way is MIDI out from Juno to MIDI in on MPC, then (depending on how you want to work), connect MIDI out from MPC to the in on the Juno. If you do this you MUST turn local control off on the Juno or else you'll get double triggers (internal + msg in from MPC). Now to record sequences on MPC , set MIDI to as track in setup window (on the 2500, this is accessed by pressing MODE then pad 9, then press button under the corresponding tab [on LCD]) then set your MIDI channel by port, meaning if your MIDI cable is physically connected to out A, in your LCD in bottom right corner it will show as follows: 1A. This indicates you are transmitting on MIDI channel 1; port A. Remember, MIDI IS NOT AUDIO!!!!! Since the Juno is a synth and not a workstation, all transport controls are handled by the MPC, that's pretty much it... Hope this helps a little, enjoy!
P.S. Go to mpc-forum.com its THE sh**! They also have links for their e-book I have one for the 2500 and its awesome!!!
Aug 16, 2010 | Roland Juno-D
Mpc 1000 beginner
Jan 21, 2010 | Akai Mpc2500 Music Production Center
I can't get my mpc 1000 to play chopped samples on the pads
Good Luck
Jul 05, 2009 | Akai Mpc1000 Sampling Music Production...
Akai Mpc1000 Music Production Center Logo
26 people viewed this question
Top Akai Music Experts
Michial Gueffroy
drivealot
Are you an Akai Music Expert? Answer questions, earn points and help others
