Question about Frigidaire FMV156DC Microwave Oven
Timer works and counts down but micro wave does not turn and turn table does not spin. Fan works. Light works. Is this common? Can it be fixed? Should I buy a new one?
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Dec 30, 2010
Inside light comes on, control panel works, timer counts down, but: table doesn't turn, fan doesn't blow, no microwaves created.
Johnny Appleseed.. hello,
Thnx for all that good nutrition (X-ell-ent companion to cheese)!
Before we start...
An annoying little know trivia about micro-waves...
If used for EMPTY or for softening single pats of butter
they will soon self destruct (eat themselves... burn-out... fail).
When they do... their "micro-wave-generator" (magnetron) will
consume much more energy and cause the primary (most likely solitary fuse to operate)... "blown fuse".
Would that you had included a model number... (but alas).
Looking up your own model number on eBay or better GETTING your REAL PART NUMBER off of your original parts sheet will allow you to shop for the VERY BEST PRICE.
Sears has an excellent reference library... but if you want the same part you can get everywhere else for the HIGHEST price
SEARs ($$$$) is your place... (3 estimates... always!).
Don't forget to get that SPARE FUSE...!
Happy hunting.
appliancepartspros...
Search Over 2 1 Million Appliance Parts
- repairclinic.com
- ezapplianceparts.com
- partssellect.com
Mar 31, 2016 | Microwave Ovens
GE JVM1850 turns on but turn table doesn't rotate & light doesn't come on even though timer counts down. Doesn't heat & has low hum noise. Is it worth fixing or should I buy new? It is 8 yrs old.
if you like your micro fixe it, becouse even do new micros look better when it comes to work they suck they hardly last the warranty period thats if you are lucky...
Oct 19, 2013 | GE JVM1850 1000 Watts Microwave Oven
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
The motor will not work. The interior light comes on, but the turntable does not go around. The cook time counts down, but no cooking occurs.
the turn table motor could have failed, but the counting down will be the monitor switch or a micro switch located behind control panel
Feb 24, 2011 | Amana ACO1860 Microwave Oven
The timer counts down but the microwave doesn't work?
it sounds like the light is on, the table spins, the lcd panel works you just have no heat
it could be many things !
BAD MICRO-SWITCH on the doors
BAD DIODE
BAD CAPACITOR I must warn you if you open it you must discharge the capacitor, because the capacitor stores a large amount of voltage , you coming in contact with it can really hurt you, so you might want to find to discharge it or leave it to a pro
BAD TUBE.......if the tube is bad you might as well purchase another one since the parts an labor will run you about the same.
GOOD LUCK LEAVE SOME FEEDBACK!
THANKS!
Feb 01, 2010 | Jenn-Air Microwave Ovens
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Frigidaire FMV156DC Microwave Oven Logo
273 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
