Question about Toshiba 42H81 42" Rear Projection Television
Bad picturre on toshiba tv
We have a toshiba big screen older model and a few months ago the pic starting gettin bad as far as it was very shaky and lines in it as soon as it got turned on but after bout 15 min it all went away! well now its stays that way..the color and sound are good just the picture is all over...Any idea what it could be? thanks
  • 1 more comment
  • pieps57 Jul 11, 2008 there anywhere i could get like a picture diagram of these components? just so i dont mess it up...and wheres the best place to get the replacement parts?
  • katcandoto Aug 02, 2008
    the pic is wavy at turn on then clears up
  • jcromley Aug 15, 2008
    Fuzzy picture on my Toshiba until it warms up. Then it gets clearer. It has been doing this for a few months. Over time the fuzziness is getting worse.
We have a 48 " Toshiba rear projection TV( Dramatic Theatre) and its picture is flickering from the last 1 year. We are unable to find any repair centre in Maharastra.(Nashik).
Pl provide help to find a repair centre in Maharashtra
Posted on Jul 17, 2008
  • 927 Answers
Good Day, pieps57;
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040. It’s recommended that all of the capacitors identified be replaced (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.) CAPS: cx178, cx221, cx230, cx241, cx250, cx261, cx270, cx541, cx670 & c514, c5030.
Good Luck, Big Irish.
Posted on Jul 10, 2008
The convergence going bad again on my Hitachi 51swx20b
Sounds like loose solder on the chips. Either that or they are failing. You can save money next time by doing it yourself with a kit from
Jan 10, 2010 | Hitachi 51SWX20B 51" Rear Projection...
When the screen has a light picture you see pink color bloches all over the screen, when the picture is darker it's not that bad. It all started a few months ago with different colored spots on the screen.
The problem is with the EEPROM in the TV that needs to be reprogrammed. But you need to have the proper Correction Tool (LSUQ0100).
I don't think it's available to the public. Call a Service Company, but make sure they have the “Correction Tool”.
Thanks for using FIXYA, big IRISH.
Dec 27, 2009 | Panasonic PT-44LCX65 Television
I have a 36 inch toshiba tv model # 36A50 and i have black bar at the top and one at the bottom i only have approximently 3 or 4 inches of screen in the middle to watch. what would it be? that problem...
For one thing you have a vertical problem and since it got that way gradually you can bet that there is a bad capacitor in the vert. circuit(pump-up cap) as far as the price goes it depends on your local servicemen, i`m in canada and that sort of problem fixed at home would run around a 100.00$. good luck
Nov 02, 2009 | Toshiba 36A40 36" TV
My toshiba big screen tv is shaky and blurry
most likley your problems are on the hyper board in the set
it will sorta dance at the top and be shaking back and forth at a fast rate
it would require the hyper board being repaired or exchanged
you would most likley wont to locate a professional in your area to assist with this repair
average repair is 280 to 320 in my area
Jan 20, 2009 | Toshiba 57H81 57" Rear Projection...
Big black box on screen
It has something to do with the closed captioning. He must have hit the closed caption button on your remote. You need to either turn the closed caption off or make another selection under closed captioning like cc1 cc2. Just keep making selections until the box goes away.
Jul 09, 2008 | Toshiba 57H82 57" Rear Projection...
Shaky Picture only during Advertisement or... Mitsubishi SC 27403
If you have cable then put the cable wire directly in the TV, bypassing the cable box. If the pix is Ok it proves that the problem is the cable box. If the problem is still there then it proves the the TV needs parts inside.
Mar 24, 2008 | Televison & Video
Mitusuhuibi big screen
start shopping around for new TV
good deal jan 1
Dec 14, 2007 | Mitsubishi WS-55807 TV
No picture, only sound
The set has a shorted vertical output IC, probably a TA8427k. The capacitors around the heat sink of this IC dry out and cause the IC to run hot. The correct repair is to replace the vertical output and the electrolytic capacitors near it. Also use 105 centig instead of the original 85 centigrade. The is some time a pico fuse or current limittng resistor which must also be replaced. This a common problem with Toshiba and is not a bad picture tube. The usual cost of this repair is around $120-150 depending on the integrity of the technician. Scrivitron
Jun 18, 2007 | Toshiba 27DF46 27" TV
Very wavy picture- gets worse when show has fast-cuts
First thing Do not beleive peeps about a bad card. Modules are not used in TV sets any more unles your talking about a complete board change out for a Zenith TV set. Toshiba sets do not have a card or board changeout!.. These peeps are crooks! A Toshiba set is repaired to componet level. It sounds like you may have a convergence problem or a problem inj the power supply involving the filter or couping capacitors. Seek out a pro whos an authorized servicer for Toshiba.
Sep 09, 2006 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
414 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
