I can't install any new games or even play some games. My dvd player is loading and loading all the time. It never stops loading. When i press the reject button and pick up the dvd it's hot. If I go to "Computer" and press on D: (dvd-player) there are no files in it! Please help me!
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Dec 30, 2010
Why does when set up loads and when you press play it goes to stop every time?
mechanism jammed.
or faulty power amplifier side or power supply side in circuit board.
Aug 20, 2014 | Televison & Video
HOW DO I TYPE NAMES OF CD OR DVD ?
You can't add a title to a disc from a player (such as this). You can only add a title on a disc writer before finishing the disc. (The only exception is RW (rewritable) disc which can be unfinished.) If a title (disc, chapter or track) is on the disc you can display it. Press Title on the remote. If you want to read all of the information on any disc, insert the disc and press Load on the player (when in Stop mode) or press the TV/DiscExplorer/DVD button to set the unit in Disc Explorer mode. It takes about 30 seconds to load the data. Press Stop to cancel the data search. Then use the folder buttons (ALL,DVD,CD,A,B,C,D) on the remote or the player to read the various items. Press Return to leave the folders. If you enter the Disc Explorer while playing a disc, the playback will stop and you will have to press Play to restart (Resume is not an available option).
Once loaded the player will store the data even after you remove the disc. It will clear when a new disc is inserted or you press Load.
The manual for this unit is available at: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPCX850D .
I hope this helps.
Oct 12, 2010 | Sony DVP-CX850D DVD Player
Dvd DOES NOT PLAY MOVIES AND UNABLE TO LOAD GAME SOFTWARE
The standard version has Windows Vista® Home Basic Edition SP1. This version do not have native support for decoder to watch DVD movies. Install a good DVD player like WinDVD or any other DVD player software. This will install the necessary decoder. Once this is done even if the installed trial version expire, your windows media player will still play the movies. However, if you like the software, make it fully licensed version on-line. Hope this helps.
Feb 06, 2010 | Dell Inspiron 1545 Notebook
Dvd won't play or eject
If you want to get the dvd out
you can try this:
First turn of you dvd player at the mains, Then power it up, But the moment it powers up press the eject button a few times so it doesn't start to load. If it doesn't work the first time try it one more time since you may not get the hang of it at first.
then you dvd should eject.
With dvd players like this, corrupt, copied or really scratched dvds may make your dvd player do this.
Regards
Jul 25, 2009 | NexxTech DP3222 DVD Player
Xbox 360 not loading games
no, before taking apart anything from the console do this
check the time and date settings,make sure that the timezone is correct as well, after you corrected it, restart the console
try to load the game without the hard drive or memory unit inserted
if these work, delete any corrupted file on the hard drive or memory unit, then perform system maintainance, system settings>>memory, press y for device options, then press x, x, left bumper, right bumper, x, x, then press yes..
Jun 30, 2009 | Microsoft Xbox 360 Console
DVD player start to load and then stops
display driver malfunction.. no solution
May 26, 2009 | Pioneer DV-37
DVD player wont play just says loading and than stops
there might be dust on the lens. try cleaning both the lens and dvd itself.
Mar 28, 2009 | Durabrand PDV-709
DVD stopped working and cannot do setup.
You probably need to reset your DVD/VCR/Combo. Go to www.samsung.com. Go to <Support>. In the search box, type in the model of your DVD/VCR/Combo. Or type in, >how to reset DVD/VCR/Combo<. Each model has different reset method and there are hundreds of models!
853. How To Reset Your Samsung DVD Player STEP 1
STEP 1. DVD Reset List
Samsung DVD players have a built-in reset procedure that resets the DVD player to the factory defaults. You can use the reset procedure to reset settings that don’t work with your TV or to resolve issues such as unit lock up. To run the reset procedure, you press one or more buttons on the front of the DVD player and hold them for at least fifteen seconds. The buttons your press depend on the model you have.
Important: For the reset procedure to work, you must press the buttons on the front of the player, not on the remote control for the player.
Below is a list of all Samsung DVD players and the buttons to press to run the reset procedure.
DVD511 - Stop / Play
DVD611 - Stop / Play
DVD709 - Stop / Play....
Many, many other models follow but cannot be listed here because of this site's text limitations.
Jun 15, 2008 | Samsung DVD-V4600 DVD Player/VCR
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
No picture on screen
looks like you need a new player, but first try anothere t.v if it does the same then you need a new player
Oct 03, 2017 | Blaupunkt DVD-MER
Computers & Internet Logo
David Payne
David Payne
