Question about Dell Computers & Internet
I have been given another hard drive to put into my tower but i can't figure out how to open the tower to put it in there, can you please help me?
  • 1 more comment
  • Azrael SRL Dec 30, 2010
    What Dell model and what version?
  • scorer2 Dec 30, 2010
    It is a dell 4500
  • scorer2 Dec 31, 2010
    I Put in what I presumed was a webpage that is under your name and it came up with nothing, I can't see with your comment what the answer to my problem is, can you please make your solution clearer so that I know what the answer is please?
  • Dell Master
  • 11,800 Answers
Http://support.dell.com/support/edocs/systems/dim4500/replace.htm#1101572
Posted on Dec 30, 2010
  • Azrael SRL Dec 31, 2010
    The address works, just Copy / paste it entirely , it's the official tutorial on how to replace the parts in your desktop.
    Thank you for the link to the advice I will try it now that I hav e bookmarked it and I will let you know how I get on. I didn't think to copy and paste. Thanks again.
    Bruce
How to Replace a Hard Drive in a Dell Computer Tower?
You need the model of the Tower to be more specific but here is the general instructions:
  1. Locate how to OPEN the Tower and search for a drive that looks like photo
  2. Unplug the cables
  3. Note if you are replacing the drive because it's damaged you may have to order the Operating Disks from the Manufacture if they still offer it.
  4. Or just start fresh and install an operating system find all the drivers on your own.
Oct 18, 2016 | Computers & Internet
Replace hdd
turn off the computer and unplug from wall
open the case/tower
remove wires from hard drive
remove screws from hard drive
remove hard drive and replace with new hard drive
replace screws
replace wires
close up the case
turn on the computer
Does that help?
Dec 27, 2012 | Computers & Internet
HELP MY HARD DRIVE HAS GONE!
Ok to understand this , you dropped a 1 TB hard-drive external hard drive on the floor? Well considering that it is a external, the cases in most externals are meant to take a beating as well as the hard-drive it self. There is two possiblities I can think of, what could of happened. When the Hard-Drive hit the floor, it could of is disconnected the connection on the hard-drive itself inside the casing, which you will have to pop it open and reseat it. Or the hardrive, arm inside the hard-drive it self snapped or is misplaced, which is unrepairable. Open up the casing and looking for the hardrive it self. Towards the back of the hard-drive is where the connection of th drive is, it is eather sata or orginal set up with his pins based. Take the connection off and put it back on and see if that works, if it didnt, best advise would be is take in in and have the drive tested, see if its still operable.
DrakeTech
Feb 25, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Need to replace the hard drive
Very easy to do. You will need an antistatic wrist strap. Unscrew the screw/thumb screws on the side of the case which slides off. slide the case door off, connect your anti static wrist strap to you and a metal part of the case, to ensure you are grounded and don't fry any parts. Check what sort of hard disk your motherboard supports, it could be IDE or Sata. Older ones use IDE. Get a hard disc to match and plug it in where your old hard drive was. The hard drive is probably held in by clips or screws. remove them and place the new hard drive in the hard drive bays. Wire it up. You will need to install an operating system on your new hard drive. This can be done by getting a windows boot cd, entering the bios on startup by hitting the delete or f12 key/ the specified key. Then in the bios go to boot device priority set it to CD. Then reboot and it will install it on your new hard drive. Hope that helps.
Aug 16, 2009 | Dell Dimension 2300 PC Desktop
Need a bios password on the hard drive for a dell lattitude 600
To reset Bios Password
  1. Turn your computer off.
  2. Unplug all the cables.
  3. Open the tower.
  4. On the System Board, you can find PSWD jumper placed in pins.
  5. Remove it and from pin 1 and 2, then put it in 2 and 3.
  6. Turn the computer on.
  7. turn off the computer and put the jumper back to the same pin.
  8. Start the computer and your BIOS password is reset.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 21, 2009 | Dell Lattitude D600 Notebook
Hard Drive - Adding 2nd Hard drive
Try re-setting the CMOS setting, use the jumper to reset.
-mrsolution
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
Lacie hd problem
This is a pretty old thread, but I just figured out the work-around for my Lacie drive with the same symptoms. I took the Lacie case apart to find a pretty standard 3.5" Seagate Barracuda drive inside the case. If you pull the actual hard drive out of the box, you can either purchase a new external hard drive adapter box ($30-80) or install it into a tower computer. I installed it into an older G3 tower and it mounted right up. I decided it wasn't worth investing in a six year old hard drive, so I will be purchasing a new drive and pulling the data off the old one.
Mar 05, 2008 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
D Drive / E Drive
try to cange cable if not buy new unit 20 bucks pop in easy they fail often thx nick
Feb 04, 2008 | Maxtor Hard Drive
Computers & Internet Logo
52 people viewed this question
Alun Cox
