Where can I obtain a repair manual for a Hoover 750LC?
3 Suggested Answers
  • 713 Answers
SOURCE: hoover top loader 750lc about 8 years old
Hi just read your posting.Now the only way to drain your machine if it is not draining is to do it by hand with a small pot or bucket. Do you hear a small click when you close the lid slowly?If you do then that is the lid switch.It will not drain if your lid switch is not activating.Did you wash a big load before the problem started?Also could be a faulty or jammed drain pump.I can guide you throe the removal of the pump to see if it is the problem if you have some tools available.Please reply after you have tested the lid switch and I can guide you throe the rest of the repair if needed.
Posted on Jun 05, 2010
SOURCE: How can I obtain any
www.2ndwave.co.uk/manual.htm
A manual above.
Also by contacting Hoover washing machines direct and asking for a copy of the manual. link below.
www.hoover.co.uk/products/18/laundry/22/washing-machines/ -
Posted on Nov 09, 2010
Where can i obtain a manual for hoover steamvac?
Call Hoover and they will direct you to your nearest service station. 1-800-944-9200
Aug 19, 2014 | Vacuums
I have lost my instruction book on my hoover Vac;- mosel no U4617-906 is it posable to get a copy SamGlen
http://homeappliance.manualsonline.com/manuals/mfg/hoover/hoover_all_floors_vacuum_product_list.html
Jul 12, 2008 | Hoover Vacuums
Hoover core plus manual
If its a recent model the main factory website probably has one on download. If not slip into a retailers and see if they have a spare.
Apr 14, 2014 | Vacuums
I have a Hoover 750LC and it makes a wrrrring sound when it drains and it only drains alit bit of water at a time can anyone help me
Yes...Yes..Yes..I can help you! You have a bad Drain Pump. Order a New Replacement and install it. Problem with water...Gone! Washer is a Once again Happy Machine...chugging along
Mar 15, 2014 | Washing Machines
Need instruction manual
Send an e-mail request to Hoover Customer Service to obtain your manual. The ilnk for their e-mail form is here:
https://hoover.com/contact/
Jan 02, 2012 | Hoover Vacuums
The filter chamber, pleated filter, and lid of my Hoover fold-away U5163-950 was accidentally thrown out. Can I replace it? The vacuum is still working well.
You should have no problem replacing the items noted. The below information was located in the "Service" section of the manual for this unit (found here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000052463.pdf). The manual also has extensive information describing your unit.
To obtain approved HOOVER service and genuine HOOVER parts, locate the nearest Hoover Factory Service Center or Authorized Hoover Warranty Service Dealer (Depot) by:
• checking the Service section of The Hoover Company on-line at www.hoover.com OR -
• calling 1-800-944-9200 for an automated referral of authorized service outlet locations (U.S. only).
Mar 09, 2011 | Hoover U5163-900 Upright Vacuum
Hoover top loader 750lc about 8 years old
Jun 05, 2010 | Washing Machines
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
