Question about Sewing Machines
My sewing machine clutch knob won't release so I can wind the bobbin without the needle going up and down. It used to release and suddenly froze. How can I release it?
    Genius:
  • 1,788 Answers
Try taking a hair dryer to it and see if that will free it up. Sometimes heat can make things move. If, it is old, you have nothing to lose taking the cover off and seeing if a belt slipped off or a broken part is in there.
Posted on Dec 30, 2010
Bobbin winder is engaged and shows up on screen correctly, but sewing mode is still engaged and bobbin winding keeps stopping.
check the drive knob on the end of the machine
it should be loose when winding a bobbin
if it is tight or seized then that will drive the needle
Sep 20, 2015 | Janome Sewing Machines
Needle still goes up and down when winding a bobbin
this is common with some machines
check that there is a knob in the centre of the pulley on the end that can be released so that the needle shaft will not drive when winding bobbins
if there is and you have released it then may be it is time for a service .
May 08, 2015 | Sewing Machines
I have a Mega Quilter and would like to stop the needle from working up and down when I wind my bobbins. Do I do this in the menu of the read out?
Most machines with a bobbin winder on them have a round knob inside of the machines flywheel. That's the wheel that turns when you sew.
TURN the inside knob forward or reverse to lock or unlock the main gears from turning the needle bar in the sewing motion.
Easy
Cheers,
Kelly
San Diego, CA
Apr 27, 2014 | Sewing Machines
Release stop motion knob won't move
What are you calling a stop motion knob? Are you trying to stop the needle from moving while winding a bobbin?
Jan 31, 2014 | White Sewing White 3032
LED that illuminates the stitch selection bar quit working as did the up/down needle button.
Check your bobbin spindle. If engaged (pushed toward the right) LED will not light. When the clutch knob is pulled out, when you wind a bobbin, the up & down needle will not move. So you must push the clutch knob in again to let the up & down needle go up and down. The clutch knob on my machine is in the large hand wheel upper right side of my machine.
Jul 17, 2011 | Janome 4623 Mechanical Sewing Machine
My bobbin will not refill but motor is turning over fine. The machine sews well, too.
Do you have your thread wound around the guide the right way so that there is the proper tension? Do you also have your bobbin resting against the bobbin winder all of the way? Have you released the knob (clutch) to stop the needle bar from going up and down? If, all these things are correct and it still does not wind the bobbin, call Sears.
Sep 17, 2010 | Kenmore 15202 Mechanical Sewing Machine
Needle is moving when bobbin is winding & lights are flashing
Check the clutch at the knob on the right side of the machine, where you tighten it to sew & loosen it to wind a bobbin. It could be very loose and when you start to wind a bobbin, it tightens itself up.
Apr 06, 2009 | Singer 7436 - INGENUITY
Clutch Release Problem
You will need to remove the clutch release knob and the 3 eared positioner (the clutch) under that knob. Reposition the clutch on the shaft, put the knob back on and see if you can put the screw back in the hole. If it hits something, remove the knob, remove the clutch and turn it 180 degrees. This will reposition the ears. Put the clutch back on the shaft, put the knob back on the shaft and screw the screw into the hole. Test to be sure the knob releases the hand wheel to wind the bobbin.Be sure the thread is under the thread guide when you wind the bobbin and that there is a slight tension on it.
sewman7
Jan 16, 2009 | Brother Sewing Machines
Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Jun 16, 2008 | PfaFF Creative 7570
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
154 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
