Question about Toshiba 32A60 32" TV
Random black rectangle in bottom half of viewing area. temporarily disappears when you click on menu or change the volume.
    Top Expert:
  • Toshiba Master
  • 74,136 Answers
Hello
It is due to some misalignment fo your side, and cannot be predicted wihich fucntion overlaps the software. You just reset it to factory settings. It will make all your V-Chip settings out, and you shoud reset it after factory reset.
To reaet it to factory settings go to V-Chip menu and do the following.
Press RECALL four
times within five seconds from the V-CHIP
menu. This allows you to proceed to the
BLOCKING menu and reset your PIN code.
OK
Posted on Dec 30, 2010
  • The Knight
    The Knight Dec 30, 2010
    Hello
    There is an other way too to set it to factory settings. To reset the picture adjustments to the factory
    settings, select RESET from the PICTURE
    menu
    menu
Black rectangle appearing in lower half of screen on 32" Aquos
did you turn off the close caption settings in the set up menu.
Sep 15, 2012 | Televison & Video
Black rectangle at lower center of screen that blocks most of the tv. adjusting volume takes it away temporarily and then it reappears. don't know if we inadvertently turned on a funcion from the remote.
Take your remote, go into menu, scroll down to captions, right arrow to 1,2,3,off, when cursor is over off press enter on the remote, that should clear the black box and give normal tv viewing.
Feb 02, 2011 | JVC AV-27D302 27" TV
Black Box in the lower portion of the screen will not disappear
Check your Closed Captioning settings in the menu. I would bet money you have the "Text" feature enabled. Change it to OFF and you should be all set. I hope this was of some assistance.
Mar 25, 2010 | JVC AV-32120 32" TV
Daewoo DTQ-27U4SC Display Problem
Sounds like your closed caption may be on and here is how to turn it off..
1. Press the menu button until you get to the "SPECIAL" menu.
2. Make sure that Closed Caption and CC on mute are both set to OFF.
This should make that black box go away...
Good Luck and please rate this solution...
Jan 06, 2010 | Daewoo DTQ-27U4SC 27" TV
Black Rectangle appears on screen for no reason
Just use your remote or the tv menu to turn off closed captioning.
Jun 03, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Black rectangle on bottom half of screen
The "Caption" mode may be on and set to "Text". To fix press MENU button on the remote then use down arrow to select "Setup" and press ENTER. Select "Caption" and press ENTER. Select "Off" and press ENTER. Press MENU again to exit setup.
May 09, 2009 | Televison & Video
Blackout area on screen
Make sure the TEXT and CAPTION options are turned off.
I am not sure about the Sonny's, but on my Toshiba a black box appears when I inadvertently leave one of the close captioning (CC) on for text or captions on (such as CC1, CC2, etc.).
Feb 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Black Rectangle appears on bottom half of screen
Go into your setup menu and turn off closed captioning. The box is there for some channels even though no text is being sent. If you need to keep the closed captioning, try selecting a different mode for it.
Sep 15, 2008 | Toshiba 24AF43 24" TV
Black menu-like box randomly appears, covering the picture
This is a problem with closed-captioning. What you are seeing is a closed captioning box with no captioning in it. Usually this is being accidentally transmitted by the cable company "head end". Just make sure your closed captioning function is completely turned off. if you are seeing it randomly, it may well be coming from your cable company. Is it just on certain channels?
Sep 05, 2008 | Toshiba 15DLV76 Television
Black rectangle blocking view
SOUNDS LIKE U HAVE THE CLOSED CAPTIONING ON, CHECK IN YOUR MENU AND TURN OFF
Dec 11, 2007 | Polaroid FLM-3225 32 in. LCD Television
Toshiba 32A60 32" TV Logo
74 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
