Question about Breville Kitchen Appliances - Others
How to replace lid on glass kettle Model BKE 260 (Breville)
4 Suggested Answers
SOURCE: Spares for Breville Electric Kettle
Okay. I took the base off the kettle (made a special screwdriver). Saw that one of the contacts was loose on its 'swage'. Used a pin punch to re-swage it. Bingo! it worked.
Jeff.
Posted on Sep 15, 2008
SOURCE: Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Posted on May 09, 2010
  • 2187 Answers
SOURCE: I have a Breville Kettle
This could be just an issue with the contacts of the base not meeting the contacts of the kettle and no power is delivered. Cleaning may help it. This could also be an issue with the switch. Internally the switch completes the circuit by 'bridging' the conductors found inside. It could be the conductors are not touching each other. If refitting the switch will not help yo may have to replace it. If you have a continuity tester you may check continuity of the circuit from the end of the coil down to its corresponding terminal on the pot while the switch is at the 'on' position. Same goes with the other to check if the switch is good. Test also continuity from the switch to the plug to test of contact between the kettle and base is good.
Posted on May 17, 2011
Where can I find a replacement filter spout?
About 683,000 results (0.79 seconds) Search Results
    Buy Kettle Spare Parts ' Calcium filters, Lids and More ...
    www.espares.co.uk/browse/at1102/kettles/small-appliances
    Buy spares for your kettle; kettle filters, kettle lids, kettle descalers and more. We carry parts for all home and garden appliances. ... Find Kettle Spares. Black & Decker. Bosch. Braun. Breville. Brita ... Kettle Spout Filter. Genuine spare part for ...
Feb 05, 2016 | Kitchen Appliances - Others
What are the advantages of using clear glass kettle?
Clear glass kettle are attractive, easy to pour from, and refill because of its large top opening. You will find many good functions on the advanced clear glass kettles like Breville and Cusinart. Cleaning the scale deposits from the inside is easy and much more.
Get some more details here: Top 5 Best Electric Kettle
Jul 28, 2015 | Kitchen Appliances - Others
How to descale a breville one cup
NOTE: Not my instructions i just found something similar.
According to the instructions for Breville Hot Cup (presumably similar to yours - the adjustable flow one):
1. Fill it to the max and dispense one cup of water.
2. Add a citric based descaling product into the cup and stir.
3. Tip contents into kettle and close lid.
4. Dispense water from the kettle, discarding the water until it reaches the 'min' mark.
5. Empty remaining water into sink, rinse out with clean water.
6. Fill kettle with fresh water and dispense cups of water until it reaches the 'min' mark. Empty the rest into the sink, then refill ready for use.
Nov 24, 2011 | Breville Coffee Makers & Espresso Machines
Cushion lid release button sticks and the lid does not close
Over time the heat can causes the plastic parts to swell until the button that releases the lid gets stuck. The button can be easily & carefully pried completely out of the hole with a knife **note the orientation of the button and spring for replacement. Clean the button & hole but expect the button to still stick when re-inserted back into the kettle. Take the button back out and if you take a knife and gently carve/scrape away some of the plastic round the inside of the rim of the 'hole' and around the edge of the plastic button, you can remove enough of the plastic so that the button now moves easily back and forth in the hole releasing the lid. Good luck.
Jul 05, 2010 | Breville "Ikon" Tea Kettle Electric Kettle
Siemens porsche kettle on/off switch problem
Hi
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
Feb 14, 2009 | Breville SK500-XL Stainless Steel Cordless...
Filter for breville kettle jk155
Contact Breville on 0161 652 1211 and they will mail out one
Feb 09, 2009 | Breville Kitchen Appliances - Others
Automatic switch off not working when water reached boiling.
There is no do it yourself fix for this problem. However, placing a folded cloth on top of the kettle (covering the spout) will cause it to switch off quicker, as it increases the pressure inside the kettle.
Apr 21, 2008 | Breville SK500-XL Stainless Steel Cordless...
Kitchen Appliances - Others Logo
60 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
