Question about Teac PD-H570 7-Disc CD Changer
MY PC-D895M CD PLAYER ONLY PLAYS CD OR MP3 PLAYER FOR ABOUT 6 MINUTES THEN STOPS. HAD PROBLEM WITH IT BEFORE NOT WANTING TO PLAY AT ALL. TEAC 'OPEN RE-SOLDER CCT/CLEANED/LUBED AND RAN OK FOR A WHILE - IS THIS A PROGRAM PROBLEM OR A DITCH THE CD PLAYER PROBLEM?
tripletauto
  • 1450 Answers
SOURCE: Plays CD 107 minutes and goes back to start
plays 107 minutes or 1minute7 seconds of first track?
Posted on Aug 22, 2008
SOURCE: TEAC CD player jammed
I had the same problem in 2007: I removed the cover and manually encouraged the cd drawer to open. It has been working ever since.
Posted on Sep 14, 2009
  • 3 Answers
SOURCE: Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Posted on Nov 21, 2009
  • 65 Answers
SOURCE: Teac CR H100 CD player just clicks when I press
it sounds like it is the motor that spins the disk most likely not worth replacing unless the unit has high sentimental value to you
Posted on Sep 23, 2010
  • 99 Answers
SOURCE: TEAC CD P1120 wont play
replace the loading tray belt as this also lifts the laser mechanism up to the level of the disc once loaded.
the humming sound you hear will be the motor trying to lift the mechanism up to read the disc but can't because the belt has lost its tension and is slipping.
Posted on Sep 24, 2010
My TEAC CD-224E plays some DVDs and I don't now how 2 make it play the others like DVD optains one movie or more
If your DVD player is set to a DVD region, then it cannot play DVDs from other regions. You are allowed to change the DVD region only four times, then the DVD player will lock permanently on that region.
If your DVD region is locked then you can install a program that will allow you to play DVDs from any region.
Please click on this link for details of a DVD region program :-
http://www.fixya.com/support/r3559135-playing_dvds_from_other_regions
Nov 10, 2010 | Teac CD-224E Plug-In Module 24x CD-ROM...
Teac CR H100 CD player just clicks when I press play and if it plays, it stops very soon. Is this teminal
Sep 23, 2010 | Teac Audio Players & Recorders
Put a cd in playey, plays for around 20 seconds stops playing then restarts playing and keeps doing the same
sounds like the laser tracks might need regreased to me, does it also skip when playing ?
Feb 07, 2010 | Teac PD-H300 CD Player
How to copy CD from Laptop to empty cd
Sounds like you made a data disk with MP3s and not an audio cd.
To play on a "regular" CD player, you should burn an audio cd.
Different burning programs have different options for this.
Jan 21, 2010 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Burning a CD/DVD wil not play in player
Hello drear sir
you have this ploblem because u burn your DVD or CD wrong if u want ur DVD movie play on player u have to burning by (for example if u use nero) DVD video file and it will convert file that a player can play it
Apr 10, 2009 | Microsoft Computers & Internet
My teac dvd/cd player wont play some cds
Probably a codec problem on the notebook. rather than a drive problem. Try a 3rd party media player such as Real Player or Quicktime
Feb 15, 2009 | Teac CD-Rewritable W28E CD-RW Burner
Teac pdh-300
Generally something that is time related with a CD player indicates that there is something stuck in one of the gear teeth that drive the laser back and forth to play different areas of the disc. A very small piece of dirt/sand can get inside and stuck in a gear tooth preventing the laser from moving past that point on the CD, in your case it's about the 40 minute mark........you can try skipping to say the last song on the CD which will advance the laser unit a bit more quickly than if you were to let the disc play through, that might dislodge the piece.
Another scenario could be a cracked gear in the same drive area. This is not as likely as you say it plays for 40 minutes or so. There is a piece that is attached to the laser which has gear teeth in it that mesh with the gears that move it, I'd suspect it's in there.
Make sure you do not have the player plugged in when you open it, the laser is capable of damaging your eyes.
Oct 07, 2008 | Teac PD-H300 CD Player
Teac PD-H570 7-Disc CD Changer Logo
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
