Question about Sony ZS-H10CP Radio/CD Boombox
Need to purchase a power adapter for Sony ZS H10CP Boombox. Where can I find this?
4 Suggested Answers
  • 159 Answers
SOURCE: I have a Sony" Personal Audio System" /boombox.
Hi, this is a pretty common problem with C.D. players, the laser has lost a bit of its intensity. This possibly can be fixed by adjusting a very small " semi-variable resistor " this should be located on the laser assembly or on the ribbon cable just before the laser. It may be a colored plastic dial with an arrow on the top, or a metal looking screw type looking adjustment ( probably has a bit of enamel to lock in place-this breaks free easily). It may even be labeled " bias ". Use a small phillips jewelers type screwdriver for the plastic kind and a slotted jewelers for the metal. move the adjuster in very small increments one way then or the other if need be. Make note of the original position in case you need to adjust different semi-variable resistors. also its even possible to have a dirty lens, use a jewelers loupe or equivalent to check. a very light touch with a Q-tip dipped in rubbing alcohol should do the trick. use opposite end to dry, be sure to not apply excessive pressure-the lenses suspension is extremely delicate. I hope this was useful-let me know if so or even if not so I may try again. Thanks for asking FixYa-good luck, Prodzilla
Posted on Apr 23, 2011
SOURCE: I need a power cord for a Sony ZS-S2iP portable cd
I'll mail you my power cord for $10.
Posted on Oct 29, 2011
  • 4234 Answers
SOURCE: broken antenna
The Sony part number is: 175422611 and the part is available for $15.95 from tritronicsinc.com or any other Sony parts distributor.
Dan
Posted on Oct 08, 2008
Sony boom box
There are a couple of things that come to mind, poor solder connections on the main board, or the audio output ic has a thermal related issue causing it to break down under load, a tricky problem to prove.
Apr 02, 2012 | Sony ZS-H10CP Radio/CD Boombox
I need to find a new ac adapter or at least the model number for it
Hello
buy a 9VDC output AC adapter. You can use anu company's adapter, provided the voltage rating shoule be 9VDC 2Amps. OK.
Dec 23, 2011 | Sony S2 Sports ZS-XN30 Radio/CD Boombox
Does the sony s2 sport boombox play an ipod?
It has no inputs for external devices.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=ZSX3CP&LOC=3
But just in case you're still shopping...
For just listening, any audio device with a headphone/earbud output can be connected to any available analog Line Level input (except PHONO) with a simple adapter. They don't tell you that in the manual because they want you to purchase expensive accessories like docking stations.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
Mar 12, 2011 | Sony S2 Sports ZS-X3CP CD Boombox
It does not read my audio cds keeps saying no disc
its either you do have a defective pick-up lens assembly or spindle motor.
Aug 04, 2009 | Sony ZS-H10CP Radio/CD Boombox
Not powering on
More than likely.. unscrew the back cover and check near the power supply. Be sure to replace with the same rated fuse..
Jul 12, 2009 | Sony ZS-H10CP Radio/CD Boombox
Broken antenna
Dan
Sep 27, 2008 | Sony S2 Sports ZS-X1 Radio/CD Boombox
Sony ZS-H10CP Radio/CD Boombox Logo
325 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
