Question about Clothing Accessories
My acer aspire 5720 the cd drive does not display and it does not read flash drives when installed
    Scholar:
  • 103 Answers
Hi
i think there is problem in cd drive when did you buy this one ,if you bought it recently then it will have warranty so please replace or get it repaired . if it is not uderwarranty then you need to meet the dealer and get it repaired it may cost little because this is not a serious problem . but be sure that a professional does it .
thank you
Posted on Dec 30, 2010
My cd drive is not working (ACER 5720-4126). and cd drive is not opening which i click button the drive
Try using with safety pin and by pulling the knob
Put the pin inside the small hole on the left bottom of the cd drive
After pushing pin inside the hole the cd player will come out and then Drag it
You can open the cd drive
Nov 26, 2010 | Acer Aspire 5720-4230 Notebook
I lost my CD Erecovery or something like that of my acer 5720 and 1 week ago i cleaned everything to install windows 7 and now when i turn on my computer it ask for the Erecovery CD
Hi, I would suggest that you call the acer tech support hotline for assistance and you could ask them for a another copy of the recovery cd. or try again reformating your system and do a clean install using the windows 7 disc that you already have. hope this helps
Jun 02, 2010 | Acer Aspire 5720-6661 Notebook PC
Cd/dvd drive not displayed in Bios or Device Manager
Your drive has failed and needs to be replaced. The controller in the drive is probably the culprit, the drive is still receiving power but cannot communicate with the computer.
Dec 23, 2009 | Acer Aspire 5100-3357 Notebook
How do I remove the CDROM in an acer 5720
Hello
From what I have found it appears that the CDROM is "integrated" into the laptop - i.e. not in a modular bay that can be easily removed from the unit.
Verify this by looking at the bottom of the laptop. You should see tabs that you push to remove the battery. Look for any other similar tabs on the bottom near the CDROM drive. If there aren't any, then you would have to dis-assemble the laptop to replace the CDROM drive.
Here's the service manual for your laptop.
http://printer1.blogspot.com/2009/01/acer-aspire-5720-service-manual.html
Just in case I read the question incorrectly - if you are trying to remove a CD disk from the drive, use a straightened paper clip, find the small hole next to the eject button and put the paper clip into the hole until the tray opens.
Dec 03, 2009 | Acer Aspire 5720 Notebook
MAY U PLZ ASSIST ME WITH MY ACER LAPTOP ASPIRE 4330 THE DRIVE IS UNABLE TO WRITE ALL THE DVDS BUT IT IS ABLE TO READ DVDS THE ONLY PROBLEM IS BURNING DVDS. HOW CAN I ENHENCE MY DVD/CD-RW COMBO TO WRITE THE...
No Sir, Acer Aspire 4330 comes with different Optical Media Loadings, ( You can see a pdf file here )
Like;
  • DVD/CD-RW combo drive
  • 8X DVD-Super Multi double-layer drive.
But you have the first one, The Combo drive not the super so you can READ both CD's DVD's but can write only CD's.
Hope this removes your dilemma.
If helpful, kindly do Rate!
Jul 18, 2009 | Acer Aspire 5720-6661 Notebook PC
Ive got an acer aspire 5720 and the dvd/cd drive aint workin where can i get the driver for it
Have you tried the manufacturers website (i.e. Acer) and looked for the drivers there. They should definitly have them if you make sure you put in the make and model of your computer into the specific drop down boxes.
good luck
Apr 22, 2009 | Acer Aspire 5720 6497 Laptop
Acer Aspire 5720-6438 recovery cd/driver cd
if you need drivers, you can download it from www.acerpanam.com.
for recovery cd, i don't think acer have it online, you need to order it from them.
FYI, if you haven't delete the partition in your hdd, you can use alt+f10 to re-install your Operating system and after that, you can create your own recovery cd.
Mar 08, 2008 | Acer Aspire 5720-6661 Notebook PC
How to downgrade acer aspire 5720 vista to xp
I just got my 5720-4126 so once I had to test the Factory re-install (ALT-F10 at the ACER screen) and knew I could get back to where I started (Vista), tried to install XP from CD. It couldn't even see the disk drive :-(
Jan 20, 2008 | Acer Aspire 5500 5570-2609 Laptop
ACER Aspire 5720
Hi All,
We are a workshop in Spain & I have had several problems with "Down grading" to XP. There is essentially one problem which causes an issue with the XP installation & that is if the the BIOS has a "Fixed" sata configuration. By that I mean you cannot change it to some sort of IDE or P-ATA (Symantics). Our current problems are with an Acer 5720 & an HP Pavilion DV9700. The Acer solution is exactly as "kraken3000" had mentioned before:
1. On POST (Powerup). enter BIOS by pressing F2
2. Tab along to the second option "Main"
3. Goto last option "SATA mode" & press enter.
4. From the small selection display select "IDE mode"
5. Save & exit the BIOS. This will then set the SATA mode for XP to be recognise.
DONOT set this back to SATA Mode after you install the XP as it will NOT boot. This setting must be kept untill you "Upgrade" (If ever) to Vista. The HP is another story...
Visit the Acer Panam site & download & install the XP drivers & your good to go...
I hope that this was of help...& good luck folks
Nov 23, 2007 | Computers & Internet
Clothing Accessories Logo
71 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
