Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
My disposal just humms and I tried to turn the bottom with an allen wrench but it will not spin...I tried to turn the allen wrench in both clockwise and counterclockwise direction.
Put wooden broomstick in sink opening.
Wedge broom against edge of opening and see if you can unstick the disposal.
You can use a vacuum cleaner hose to help clean out blockage.
I also wrote tips for replacing disposal in worst case:
http://www.fixya.com/support/t6995519-badger_1_2_hp_in_sink
Posted on Dec 30, 2010
How do I unjam it?
On the very bottom of the disposal there is a small opening in the very middle of the disposal. If you shine a light under the sink and put a mirror down on the inside of the cabinet you should be able to see this. You'll need an Allen wrench to put in the 6 sided hex hole and turn counter clockwise until the disposal turns freely. This should unjam your disposal. Don't forget you may have to hit the small reset button on the bottom too.
Jan 14, 2016 | Garbage Disposals
Garbage disposal does not even make a noise I pressed the red reset switch, how do I turn the blades inside to see if they are stuck? Is the allen wrench place on the bottom in the middle? if so which...
The allen wrench set is underneath in the middle. Turn it clockwise. Also, make sure your circuit breaker did not throw. It should be located in your main circuit breaker box. Some places put a switch under the counter for the disposal. Check that as well.
Jun 18, 2011 | Dishwashers
Disposer is making a humming sound.
If your disposal is humming but not grinding then shut unit off and use a 1/4 allen wrench in the opening on the bottom of disposal in the center and turn it back and forth with the wrench till you get it freed up. There should be a offset wrench that came with the disposal for this purpose but if you don't have it a regular allen wrench will work. Try running hot water thru disposal while you are turning with allen wrench to help loosen up grease. After you get it turning freely remove allen wrench and turn disposal on . Hopefully this will take care of it but if not repeat until it frees up.
If your unit stops look on the bottom of the disposal for a small red button. This is a reset button. Push it and see if it will run. Hope this helps you. Thanks and have a good year.
Jan 04, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Describe how to use the garbage disposer- currently it doesnot work- humming sound, no grinding
Look on the bottom of garbage dosposal in the center you will see a allen type fiitting. I believe it takes a 5/16 inch allen wrench to fit it.Insert proper size allen wrench and turn it manually back and forth. It sounds to me like you have something in there that that is not allowing it to turn. By using the allen wrench to turn impeller you should be ably to free it up.Sometimes it helps to run very hot water thru it as you are trying to frree it up. If you can get it turning freely with wrench remove wrench and turn disposal on. If it still is not free try above procedure again. If it trys to start and stops buzzimg look closely at bottom of disposal there will be a small red button. This is a reset switch. Push it in and continue trying to free blockage. Hope this helps you. Thanks
Nov 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Humming noise when turn on insinkerator badger 5XP, and it is not disposing food. After it is on for a while the reset trips
Your disposal is stuck. Sounds like something either fell in it, or perhaps a bone got inadvertantly tossed in. Do you own an allen wrench set? The garbage disposal did originally come with one, but it usually gets lost. The one that came with it will look like two hockey stick stuck together. In any event, you need one for the fix. There is a hole on the bottom of the disposal, directly in the center. Find the correct size allen wrench and place in this hole. Twist clockwise and counter clockwise until it is free. Once this is done, you most likely will need to hit the reset button on the bottom. Good luck!
Jan 18, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
GARBAGE DISPOSAL, IN SINK ERATOR JUST HUMS, DOES NOT GRIND
Try inserting an allen wrench in the hole at the bottom center of the unit and turning clockwise. Once you feel the resistance give way, the blades are turning freely. Hit the re-set button (also on the bottom of the unit). Run water and pulse a few times to clear whatever was blocking the blades.
Jan 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
BADGER 5 HUMM WON'T RUN BECAUSE SOMETHING OBVIOUSLY STUCK
It is located on the very bottom of the disposer, and can be seen from under the sink. The pin is actually an allen wrench, and mates to the socket.
Best regards, --W/D--
Aug 16, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Humms but blades don't move. the blades move freely. the reset button did not fix it. thank you.
Try placing the allen wrench into the socket on the underside of the disposer and working it back and forth, then trying it electrically. The blades can appear to be free, even with a jam. The moving of the inner workings with the allen wrench should free it all up. Flush the disposer with a potful of ice and water when it turns freely.
Aug 12, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a badger 5 plus garbage disposal (5-6 years) it humms
Yes, it sounds like you have a bad motor winding, not allowing the motor to actually work. It is time to replace. Hope this helps
Jul 16, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
157 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
