Dear Sir, I have a document that is hung up in the printing que and will not allow it to be deleted Optional Information: Make: HP Photosmart D7260 Already Tried: I have gone to the printer icon but all have gone to vain.Please help as soon posssible as its too urgent. Regards, Chandrachur
  • Chandrachur Bose Dec 30, 2010
    Thank you very much for the solution.Season's Greetings in advance
  • 921 Answers
XP: Open Start Menu > Run, type "services.msc" and press OK
Vista or &: Open Start Orb (menu) and type "services.msc" and press Enter
Find the "Print Spooler Service", right click on it and select restart.
Now go back and right click on the printer in Printers and select Cancel All Documents.
The should clear the print queue.
For more information Google: Windows Print Spooler
I hope this helps. Good luck!
Posted on Dec 30, 2010
How can I clear the print que? I tried to cancel printing a document, and now the que says cancelling, but won't let anything else print
1) Try to restart you system with the printer unplugged.
2) Try to Pause the printer and then delete the items in the que
3) If this doesn't help Delete the printer and re-install it.
Aug 29, 2014 | HP Photosmart C6180 All-In-One InkJet...
Documents in printer que, but does not print
If a print job get hung up in the print que it may stop and not be able to be deleted, this will also block other print jobs from printing. Here is a link to an article that shows how to clear the print que and purge the stuck print jobs so printing can resume. I hope it helps.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Dec 10, 2012 | Sharp Mx-2310u Color Copy/print/scan
I have an HP printer. There is a full page photo that will not print. When I try to cancel the job is states deleting but does not delete. It deletes other added print jobs but not that one which is...
You have to clear out all documents one by one in the print que before you can delete the one causing the trouble. On the bottom right side of your pc screen, find the picture of the printer and right click with your mouse on it. Open your print que and right click on each document and choose "delete" until therer are none left in the print que. If this does not clear that last document, then unplug your usb cord that connects the printer to your pc and wait a few moments, and then plug it back in. This should clear it out.
Sep 08, 2010 | HP Officejet J4680 InkJet Printer
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
Dell 948 printer will not delete a document
try putting a sheet of paper on the printer and hit the print button..
Aug 11, 2009 | Dell 948 All-In-One InkJet Printer
HP photosmart C5280 document stuck in print que
Delete document manually from the path mentioned below:
1) Press windows + R an then type spool
2) Go to PRINTERS folder.
3) Delete the files present in there.
If not able to delete then
1) Open command prompt.
2) type "net stop spooler" and then delete the files
3)Again type "net start spooler"
Your stuck document is now cleaned. You can start printing your document again.
Mar 30, 2009 | HP Office Equipment & Supplies
Printer not printing documents in que
my printer hp psc1315xi all in one printer copier, scanner will not print any documents, not even a test print, there is also a doucument in it that am not able to delet from the printer
Jan 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
I was in the process of printing some pictures when it stopped and only printed half of a picture. I checked the stauess of the printer and it said there was an error. I tried to cancel/delete the printing...
If the job is hung in the print que, and it will not delete, turn the printer off, then shut down the system. Turn the printer back on, and re-start the computer. This should clear the data spool that you were not able to delete.
Nov 20, 2008 | HP Office Equipment & Supplies
Unable to delete print job
Switch off or unplug the printer and then delete it. make sure you have administration rights to delete print cue if your under active directory.
Dec 12, 2007 | Office Equipment & Supplies
Lexmerk Z600 Series Printer won't delete document after printing
check your allowed programs in your security suite to see if your print programs are allowed
Nov 14, 2007 | Office Equipment & Supplies
29 people viewed this question
k24674
