Question about Amana Dishwashers
ADB1400 diswasher. Installed, ran for first time using the 1 hour cycle and everything seemed to run fine but the Cancel/drain red light won't stop flashing and it won't shut off.
  • 112 Answers
SOURCE: won't get off drain/cancel cycle
It sounds to me like you may have a float switch that is registering water in the unit when you try to start it. If the unit "registers"that there is water in the sump before starting a new cycle, it will try to drain it before starting. The switch is located under the lower acess panel. Sometimes, you can bounce the float (depending on model) inside the unit a couple times and dislodge it. If not, you will have to pull the lower acess panel and check the switch out.
Posted on Oct 28, 2008
  • 2976 Answers
SOURCE: Brand new dishwasher will not drain at end of cycle.
Check your manual. Some dishwashers actually do leave water in them after the final drain cycle. It has to do with the type of seals they use. Some will leak the very first time they are used but not after that. The seals in these types must remain wet. If this isn''t the issue, wait about 5 minutes fir the timer to finish. Sometimes there is quite a lag at the last cycle. If all else fails, call the customer service number in the manual.
Posted on Feb 02, 2009
  • 220 Answers
SOURCE: the clean light is blinking diswasher won't start
Push these buttons in this order High temp wash > Heated dry>High temp wash >Heated dry all the lights will come on and this will reset the board and run it through a short test cycle but more than likely it will come up again,It's a failure in the heating cycle either the heater itself or the turbidity sensor which sits mounted up into the tub right behind the drain pump...hope this helps
Posted on Sep 13, 2009
Testimonial: "i tried the sequence of buttons that was suggested and my dishwasher reset itself and is now washing!!!"
rylee_smith
  • 8619 Answers
SOURCE: My diswasher does not drain.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 08, 2010
heatman101
  • 43501 Answers
SOURCE: I have a 13ish year
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on Jun 28, 2011
Model MDB7749AWB. Why does it stop mid-cycle?
Defective washer control board is the most common fault.
Mar 15, 2017 | Maytag Dishwashers
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
The clean light is blinking diswasher won't start
Sep 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Blocked drain message on GE GSD2800 dishwasher
pull the bottom tray out, in the back portion of the center of the dish washer there is a plastic screen looking thing, you will need to take a 1/4 inch nut driver and take out the screw pull off the cover and clean out the drain,, there is probly some food particals in there , it does havea small blade inside there to help sut up fine food that gets thru but it doesn't do it all the time ,, make sure you put the cover back on before runnig the unit
Jun 27, 2009 | GE Profile PDW8400J Built-in Dishwasher
Kenmore model 66516352301 diswasher flashes Wash but won't start
I had a simular problem with my Kenmore. I unplugged it for an hour or so and it worked for a while. (Disconnect dishwasher from power befer attempting this procedure!) I ended up removing the inner door panel and removing the circuit board. I used a clean damp (distilled water preferred) paper towel and wiped down the entire circuit board surface. I paid special attention to the areas between the closely spaced component leads. I dried the board with a dry paper towel and re-installed the board. The dishwasher has preformed flawlessly for the past 4 months.
I believe that the mist and steam deposites a thin film of very conductive detergent and minerals on the board surfaces over time. The resulting electrical leakage paths "scrambles" the control's "brains".
I also noted that prior to my repair, most of the led cycle indicating lights were very dimly glowing with the room lights out. Also, the wash cycle ran for a much longer time.
Jun 16, 2009 | Kenmore 24 in. 17372 / 17374 / 17379...
Feb 02, 2009 | Haier ESD300 / ESD301 Built-in Dishwasher
Won't get off drain/cancel cycle
Oct 28, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch SHU43C installed in 2003
My Bosch SHU43C had the same exact problem. I found the below solution on this site. Perhaps you already seen it.
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Aug 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43C
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwashers Logo
151 people viewed this question
Top Amana Dishwashers Experts
Cleverer2
Charles T Nevin
Charles T Nevin
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
